Offline Doodlebug
#1 Posted : 24 September 2005 01:49:47(UTC)
Doodlebug
Hello!
If I install a 6603 Delta decoder to a loco, is its telex
still going to work? I know this decoder is already out of
production and has been replaced by 66031 which should work
with telex, but the 6603 is cheaper.
Mikko
Offline franciscohg
#2 Posted : 24 September 2005 04:15:59(UTC)
franciscohg
Chile
It will function the same way that it does with the analog reverse unit. Not try it but i remember to have read that somewhere
Offline perz
#3 Posted : 24 September 2005 12:10:15(UTC)
perz
No, I don't think so. On the 6603 decoder, there are no outputs for Telex. See http://home.swipnet.se/perz/d6603.html for a schematic of the 6603 decoder.
Offline jorge_vilarrubi
#4 Posted : 24 September 2005 16:27:56(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
<br /> On the 6603 decoder, there are no outputs for Telex.
That is correct. No F1 output on 6603, only directional lights proportional to speed. For Telex control, you need a 66031.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline Doodlebug
#5 Posted : 25 September 2005 00:58:39(UTC)
Doodlebug
Hello!
Thank you to all of you. Now I know what I need.
Mikko
Analogue to Delta (6603) Conversion- Solder Points on the motor? (Digital)
by 5HorizonsRR 04/11/2021 04:42:05(UTC)
Question concerning Delta Chip 66032 (Digital)
by Chris6382chris 02/03/2011 07:34:48(UTC)
Problem converting a 3088 with a 66032 (Digital)
by mascagni 30/09/2007 17:39:35(UTC)
Conversion using 66032 (Digital)
by mascagni 23/08/2007 16:01:17(UTC)
Decoder 66032 Dip Switch Settings? (Digital)
by Karl 15/05/2006 13:22:52(UTC)
The new 66032 decoder ! (Digital)
by pa-pauls 30/06/2002 18:51:03(UTC)
This page was generated in 0.357 seconds.
