Offline usta
#1 Posted : 13 March 2009 15:40:33(UTC)
usta
this is Preiser code number 14013
I put smd green light with a light cover .cables are hidden in the back of the crew.
Hat painted red .
abdusta
#2 Posted : 13 March 2009 15:57:57(UTC)
Very nice! Excellent work!
Offline dntower85
#3 Posted : 13 March 2009 17:01:19(UTC)
dntower85
Your good!
DT
#4 Posted : 13 March 2009 17:17:23(UTC)
very nice - did you see my similar effort on water pumps?
http://layout.mixmox.com/1/Water-crane-lamp
these surface mount LEDs are going to make lots of things possible...
Offline MarioFabro
#5 Posted : 13 March 2009 17:21:20(UTC)
MarioFabro
How do you weld the wires of the SMD? I have some that are so very small.
And don't just answer .. "veeeeery carefully!" Smile
#6 Posted : 13 March 2009 18:58:29(UTC)
I just love people like Dale and usta who go on to get those little extra details on the layout...
#7 Posted : 13 March 2009 19:59:50(UTC)
I hold the SMD LED in some tweezers that have a spring to hold them closed. I work with a magnifier light. The wires I use are from old coils - see http://layout.mixmox.com/1/coil-wire
The soldering is pretty easy, once the end of the coil wire has been tinned, the solder pad on the SMD (gold?) accepts the wire very quickly. Use a fine tipped soldering iron.
Offline dntower85
#8 Posted : 13 March 2009 23:33:01(UTC)
dntower85
[size=1" face="Verdana" id="quote]quote:Originally posted by DaleSchultz
<br />I hold the SMD LED in some tweezers that have a spring to hold them closed. I work with a magnifier light. The wires I use are from old coils - see http://layout.mixmox.com/1/coil-wire
I wish my hands didn't shake or I would try it. I use to be able to make a nice solder point.
DT
#9 Posted : 14 March 2009 20:12:27(UTC)
I am impressed, Usta!
Offline FMS
#10 Posted : 15 March 2009 00:45:55(UTC)
FMS
Usta,
I know that Usta is your name, but i'm going to start using it as a word.
For me, Usta, means:
"thin barrier between fantasy and reality"Smile
FMS
Offline usta
#11 Posted : 15 March 2009 01:59:17(UTC)
usta
Dear FMS thanks for comliments
If you check USTA in google translator Turkish-portugal
you will recive a remarkable reply.
Dear Dale I always appreciated your hand works.
here my study for smoking cigar.I use fiber optic cable.
In first picture man lookþng from window
A.Usta
#12 Posted : 15 March 2009 04:17:33(UTC)
optic fiber - yes I obtained some intending to use them but so far I have not done so -- shame on me ! Nice work !
Offline Ranjit
#13 Posted : 19 March 2009 01:22:58(UTC)
Ranjit
Great work, Dale and Abdurahman! You guys are the champs in detailing.
Ranjit
#Get Vaccinated
Offline kariosls37
#14 Posted : 19 March 2009 08:35:45(UTC)
kariosls37
great work once again, Usta.
you are truly a master at bringing scenes to life
thanks for sharing
Offline usta
#15 Posted : 24 March 2009 16:15:58(UTC)
usta
Thanks everybody and your compliments for dale and me
Finally, I present a scene from container yard
with hand lamp.
next project probable will be a lamp on miner's helmet
or a blond lady with Eve cigarette.
Do you have any other idea ?
A.Usta
Offline trainbuff
#16 Posted : 29 June 2009 21:16:52(UTC)
trainbuff
Impressive work. What size smd leds are you all using? Are they on this picture?
Also are these smd leds suffiecent for lokomotive lights?
Offline usta
#17 Posted : 30 June 2009 01:11:29(UTC)
usta
0804 and 1206 I use
a.usta
This page was generated in 0.457 seconds.
