Offline Rocca
#1 Posted : 25 July 2005 00:51:56(UTC)
Rocca
Hi friends,
This evening the rotation of the crane 7051 isn't for me possible[xx(][xx(]. I press as always the corrisponding buttons on the control panel, but the crane isn't slewing. Instead the raising and lowering the load and the switching magnet and lighting on and off are all correct.
All the cable are connected.
Any suggestions, please, to solve the problem?? [:p]
Thank you very much for the help!!
Stefano
Offline franciscohg
#2 Posted : 25 July 2005 02:19:29(UTC)
franciscohg
Chile
Did you check the conytol panel?
It hapens to me once that the contacts inside where a little loose with the use, just rebend it a little and it works fine.
#3 Posted : 25 July 2005 10:05:37(UTC)
Check loose wiring around the motor on base under crane or check loose in control panel.
Offline hmsfix
#4 Posted : 25 July 2005 14:38:21(UTC)
hmsfix
Had the same problem with my crane years ago. Rotation motor didn't work properly. Problem was oil and dirt on the collector plates. After replacing the motor brushes was well again.
The crane motors have no closed casing, so they collect a lot of dust. This may cause bad contact on the collector plates. Also a tiny drop of oil on the crane gear is useful from time to time.
Hans Martin
Offline DasBert33
#5 Posted : 25 July 2005 16:25:27(UTC)
DasBert33
If the motor works but it doenst move:
It could be that it has to do with the fastening screw of the cranehouse. If the screw is loose or the cranehouse is fastened at a slightly wrong angle it can be that it doenst turn anymore. I had something like that after converting to the 'unterflurantrieb'.
Otherwise check the wiring like the others said.
Bert
Offline Rocca
#6 Posted : 26 July 2005 12:43:20(UTC)
Rocca
Hi Hans Martin,
Thank you very much for the useful suggestion. I have cleaned gently the motors and perhaps was the dust which caused the bad contacts!! [8)]
Best reagards!!
Mit freundlichen Grüßen
Stefano
[size=1" face="Verdana" id="quote]quote:Originally posted by hmsfix
<br />Had the same problem with my crane years ago. Rotation motor didn't work properly. Problem was oil and dirt on the collector plates. After replacing the motor brushes was well again.
Hans Martin
Offline Rocca
#7 Posted : 26 July 2005 12:47:04(UTC)
Rocca
Hi Francisco, Steven and Bert,
Thank you very much to you too for the help!!!
Stefano
This page was generated in 0.327 seconds.
