Offline I_love_Marklin_37538
#1 Posted : 08 March 2009 01:04:45(UTC)
Ok
I am wondering on some Marklin steam engines some of them have either a Witte or Wagner smoke deflector and by the way what does Witte or Wagner mean?
#2 Posted : 08 March 2009 01:20:19(UTC)
Alex, they aren't Marklin smoke deflectors as such, the names are for the types of deflectors used on the prototypes.
http://en.wikipedia.org/wiki/Smoke_deflectors
http://en.wikipedia.org/wiki/Richard_Paul_Wagner
#3 Posted : 08 March 2009 10:48:08(UTC)
'The DB replaced the smoke deflectors by "Witte" smoke deflectors and moved the pump to the center of the locomotive. From 1950 the DB equiped five locomotives BR 01, the 01 042, 046, 112, 154 and 192 with different heating installations and different smoke boxes.' - dbtrains.
See link http://www.dbtrains.com/...ocomotives/epochIII/BR01
#4 Posted : 08 March 2009 11:49:07(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by I_love_Marklin_37538
<br />I am wondering on some Marklin steam engines some of them have either a Witte or Wagner smoke deflector and by the way what does Witte or Wagner mean?
Mr. Wagner was the the head of the design department in the design office of the Reichbahn and Mr. Witte was his assistant and later his successor.
I think the smaller Witte deflectors look better. And AFAIK they are even more efficient.
#5 Posted : 08 March 2009 22:02:16(UTC)
I like the Wagner Deflectors overall,I think it gave the 01 and 03 a bit character
Offline steamfriend
#6 Posted : 09 March 2009 02:49:43(UTC)
steamfriend
It is all a matter of taste, I believe. The Wagners look more mature, give the loc a real solid image. I particularly like it on the BR01. See pic below
which is the old 3047 with Wagners (and much more improved details)
The Witte's are more elegant, though. I never saw a scientific report on a comparison between the effectiveness between both... In any case, Witte is more economical on steel Smile
Bob
Offline TimR
#7 Posted : 09 March 2009 06:41:22(UTC)
TimR
Indonesia
Just of interest, would a witte or wagner deflectors designed for a particular model can be switchable?
I mean can a model with witte deflector for example, be fitted with wagner? or vice versa?
(not that I want to do it anyway as it actually gives an excuse to buy more models biggrinbiggrin)
Now collecting C-Sine models.
Offline TimR
#8 Posted : 10 March 2009 02:29:56(UTC)
TimR
Indonesia
Thanks for the info, Lutz. Much appreciated!
This might make swappable conversions possible, especially for the "standard" loks.
#9 Posted : 10 March 2009 19:54:15(UTC)
Two examples of the small and the big smoke deflectors, and, as Lutz says, the closed fron skirt:
With Witte smoke deflectors
With Wagner smoke deflector and closed front skirt.
Offline TTRExpress
#10 Posted : 10 March 2009 20:17:16(UTC)
TTRExpress
They are both types of windleitbleche (smoke deflectors). The larger "full" skirted model is the Wagner type (named after the "inventor" of them) and the more streamlined model is the Witte (again named after the "inventor" of them). Witte was a junior engineer under Wagner and Wagner as long as he was around would not agree to the change in deflectors for steam loks. Once Wagner was "retired" the changes to the Witte tyoe deflectors were made! If you are modeling Epoch II and early Epoch III then stick with the Wagner. Late Epoch III onwards you can use the Witte and still use the Wagner!
Offline mmrcnzjohn
#11 Posted : 11 March 2009 08:59:08(UTC)
mmrcnzjohn
Hi Lutz,
I never knew that the class 18 had wagner deflectors.
do ou have a pic of it?
#12 Posted : 11 March 2009 10:22:08(UTC)
I think Lutz is referring to a BR01 road number, as in BR01 18, rather than a BR18.
#13 Posted : 11 March 2009 10:51:04(UTC)
Thanks everyone, and Svein for the pictures.
I was unaware of the subtle differences in the design of the front end of some steamers like the BR 50.
#14 Posted : 11 March 2009 13:14:22(UTC)
Both types of smoke deflectors were also used in other countries.
Victorian Railways in Australia used Wagner type on a 4-6-0 passenger class from about 1935.
British Railways used both Witte type (on Flying Scotsman classes like A3), and Wagner type (on Brittania and A1 classes), but only from the early 1950's.
#15 Posted : 11 March 2009 14:05:44(UTC)
In general, I like the look of the Witte deflectors more, but I love the way the little Br24 seems to peep out from behind it's huge Wagner deflectors!
Smile
Offline TTRExpress
#16 Posted : 11 March 2009 16:01:56(UTC)
TTRExpress
John,
The BR 18 has "Wagner" type deflectors, not what one would classify as the large ones on the BR 01 etc. They are definately not Witte!
#17 Posted : 17 March 2009 01:56:29(UTC)
I have just made a recall (funny how ideas pop up) that on the A3 class British Railways 4-6-2, the Witte style deflectors were called "elephant ears" by the loco men and general public.
I remembered this while perusing a picture of Märklin's new Class 39 Insider model.
Offline DasBert33
#18 Posted : 17 March 2009 22:47:55(UTC)
DasBert33
<br />The conversion to Witte deflectors actually started around 1950 within the area of the DB....
What about kriegsloks? Like the BR42, BR52 or fiction BR53. They already seem to have Witte smoke deflectors in Era 2 (some of them). Or are those of yet another type?
Bert
#19 Posted : 18 March 2009 00:22:03(UTC)
Bert, I think some of them had a simpler type of Witte deflectors.
They were more like a bent steel plate, without the reinforcement along the edge.
Offline steamfriend
#20 Posted : 24 March 2009 02:09:49(UTC)
steamfriend
Code:
The reason is quite obvious : everything had to be trimmed down to the absolute minimum. Witte's used also less steel than Wagners... Less cabin windows, less domes, ....
Bob
This page was generated in 0.761 seconds.
