Offline Armando
#1 Posted : 30 May 2005 08:24:23(UTC)
Armando
Hello everyone:
I would like to know which of the following two Seuthe Steam Generators corresponds to the Märklin 7726. Is it No. 11 (16-22 V) or No. 10 (12-16 V)? Which should be used if the smoke function is controlled via the "f1" key on the Control Unit?
Are the any other differences between the Märklin 7226 and the Seuthe? Would one produce more smoke than the other one?
Thank you in advance and greetings from Montreal.
Armando
Armando García
#2 Posted : 30 May 2005 10:46:54(UTC)
I have digital locos with number of 7226 smoke unit with control unit as well.
Offline Eiger
#3 Posted : 30 May 2005 11:14:15(UTC)
Eiger
Hi Armando, I don't know the model no. but when I ordered a Marklin generator it was a Seuthe in a Marklin box.
John F
Cape Town - South Africa
Do your bit: www.greenpeace.org
Offline Sander van Wijk
#4 Posted : 30 May 2005 12:26:32(UTC)
Sander van Wijk
The 7226 is the Seuthe no. 10...
Sander
Offline Guus
#5 Posted : 30 May 2005 12:36:19(UTC)
Guus
Hi Armando,
Indeed you either need the nr. 10 or nr.11 which both have the same size as a Märklin 7226.
It depends on the loc in which you want to install it.If it's a digital loc of the older generation you need the special digital version nr.11(green insulator) and the newer types with more than one function (designated fx) need the "conventional" type nr.10(pink insulator), which produces enough smoke in that case.
Also se this topic:
https://www.marklin-users.net/ap...rchTerms=smoke,generator
Hope this helps
Guus
Kind regards,
Guus
Offline Armando
#6 Posted : 31 May 2005 04:30:44(UTC)
Armando
Thank you to all of you for the above comments to my question.
Greetings from Montreal,
Armando
Armando García
This page was generated in 0.514 seconds.
