Offline MarioFabro
#1 Posted : 12 February 2009 00:36:02(UTC)
MarioFabro
I would like to prototypically represent a parallel track in C-track and also stations. The plastic ballasting of the C-track does not do the job and, in real life as in most well made lay-outs, the space is filled and then ballasted. Since ballast is quite expensive, I assume underneat there is a "filler". I was thinking about using styrofoam sheets, paint the top earth tones and then glue the ballast on top.
Is this the best way to go?
Offline perz
#2 Posted : 12 February 2009 00:53:20(UTC)
perz
Styrofoam sheets is definitely a way to do it, but it is also possible to use cardboard. We used both methods on our company layout https://www.marklin-users.net/fo...ault.aspx?g=posts&t=8681.
Offline MARKLIN LOVER
#3 Posted : 12 February 2009 06:46:41(UTC)
MARKLIN LOVER
Here is my C-Track Ballasted!
Keep em on the rails!
Ivan!
Offline mvd71
#4 Posted : 12 February 2009 08:26:23(UTC)
You've definately got the right idea Mario, the tricky part is geting the right grade of ballast to match the plastic, and blending it in smoothly so you don't have the typical plastic to ballast seem.
Cheers....
Mike van Dam.
#5 Posted : 12 February 2009 08:50:40(UTC)
I just used Ballast : As usual as a photo taker I make a good butcher/
Offline davemr
#6 Posted : 12 February 2009 12:30:25(UTC)
davemr
Try Busch No. 7069. Matches the track very well.
davemr
Offline SierraDelta
#7 Posted : 12 February 2009 12:38:56(UTC)
SierraDelta
This highly illustrated thread at Stummi's shows some other fine examples of how to ballast C-track:
http://stummi.foren-city...ttern-des-c-gleises.html
Søren
___________
CS2 60213 version 1.6.4(3)/GFP 1.40
2011 planned purchases - | nothing |
Offline charles Sharpe
#8 Posted : 12 February 2009 17:43:33(UTC)
charles Sharpe
I use Busch. And it called Schotter HO 7069
CHARLES SHARPE
#9 Posted : 12 February 2009 18:17:29(UTC)
I use cardboard to fill the space up to the level of the track, and then ballast, but I can't remember which one right now. I can look it up when I get home. It's a good match for C Track
This is how it turns out.
Offline perz
#10 Posted : 13 February 2009 00:41:18(UTC)
perz
We used Noch 09376 ballast on our company layout.
Offline Caplin
#11 Posted : 13 February 2009 01:30:11(UTC)
Caplin
Very nice, Ray.
Benny - Outsider and MFDWPL
Offline mvd71
#12 Posted : 13 February 2009 08:23:24(UTC)
[size=1" face="Verdana" id="quote]quote:This highly illustrated thread at Stummi's shows some other fine examples of how to ballast C-track:
That is the best I've seen with C track so far. It would be nice to see it in the flesh.
Offline haxpet
#13 Posted : 13 February 2009 09:37:59(UTC)
haxpet
Hi Ray
That looks realy good, do you have any pictures from a little higher perspective and other angels?
Märklin, 3R, Digital (system), C-Track, favourit loco: Baureihe 103 137-6
My homepage: http://home.aland.net/mi...da/MR/modelrailroad.html
I will buy Märklin 4644 BP tankerwagons that have the original box and are in good condition. (No broken details)
#14 Posted : 13 February 2009 10:08:40(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by haxpet
<br />Hi Ray
Not really, sorry. I tend to prefer to photograph my layout from "eye level". I'll try to take a photo from above and post it as soon as i have some time.
This page was generated in 0.848 seconds.
