#1 Posted : 12 May 2005 10:03:39(UTC)
I have an old delta decoder and motor those i take from my crocodile
3356.I put the 60901 to the crocodile and it is great.Can i convert
them to my old loco 3000 from my first starter set.Where i can found
help for this??
Offline Gregor
#2 Posted : 12 May 2005 12:02:50(UTC)
Gregor
It should be possible to install the decoder into the 3000, although running characteristics might not be optimal for the SFCM motor.
There are different versions of the delta decoders. Are there still coloured cables connected to the decoder ? If so, red is pick-up shoe, brown is mass, black to motor where red wire used to be in analog mode, blue+gree (or blue+blue) to the two field magnet connections where the reverser relay used to be.
In fact, the connections should be identical to those in your crocodile before you removed the decoder.
Good luck,
Gregor
This page was generated in 0.225 seconds.
