Offline frankv
#1 Posted : 18 February 2005 16:18:03(UTC)
frankv
All,
After all the new discussions around the MS, I finally broke down and bought the 60652. Using the 6001 transformer from my 6021 setup, I got the 1.9va. Right off the bat, I was able to run 4 locos with lights and sound, and I have to admit, that I really like the way the MS works.
The only negative that I can say about the setup, is that now I cannot use my Postal wagon (49962)with the same address of the loco I run it with. There is no way to change the PW address and if you change the Loco’s address to the PW default, that does not work either. (To bad there was no provision for consisting built into the 60652.)
But this brings up another question.
I see that M* is offering MFX upgrade kits for locos with the high performance motors.
So, if you upgraded two locos with these kits, and can not set the addresses manually, how would the MS or the CS for that matter be able to tell them apart?
Frank
Offline Lars Westerlind
#2 Posted : 18 February 2005 17:36:54(UTC)
Lars Westerlind
My conclusion from disccusions read so far (Märklin don't tell anything) is something like this. Regarding mfx decoders only:
1. Central regularly asks locos it has in its list, if it't still there, and if the registrered identity (serial number) is correct. It uses an interal "address" to do this. If not correct, it understands it's a new loco present, and assigns a new internal address for this serial number. If no answer, it assumes that the loco will show up later.
2. In some way central also asks if there are any locos present that have not been called for. If so it assigns an internal address for the communication, and gets all info from the decoder about serial number, function layout and so forth. In case of two new foreign locos at the same time, it's a little more difficult; however, not impossible to solve.
This goes on with rather low frequency, assuring that there is always an interal address to communicate the high speed info, like speed and funtions etc.
So it doesn't really matter if you have bought two identical locos, or it happens that your friends loco had the same address when it last was run; each decoder wordwide has a unique serial number, which makes it possible to identify them.
/Lars
Offline frankv
#3 Posted : 18 February 2005 18:04:39(UTC)
frankv
Thanks Lars.
That makes sense, in the long run this will be a nice feature.
Offline Sam
#4 Posted : 19 February 2005 03:51:40(UTC)
Sam
I am using the 1.2VA version of the MS, it can run 2-3 (3 slows it down).. and I'm waiting for the CS to upgrade.
I currently only have regular Digital locs, but I just pre-ordered the 39834 with the mfx and I can't wait to see how well it integrates, and how you can control the behavior thru the controller without ever opening up the loc.. I wonder, do you think Marklin will make upgrades for the majority of digital decoders? Seems like they would have announced this already if they were going to.
Era I-V / HO & 1 Gauge / C-Track & Mobil Station, with Central Station.
Offline frankv
#5 Posted : 19 February 2005 15:39:57(UTC)
frankv
Sam,
According to the website of one of the vendors I use, you can already get MFX upgrades. http://www.rocousa.com/DETAIL.ASP?PRODUCT_ID=60921
or
http://www.rocousa.com/DETAIL.ASP?PRODUCT_ID=60922
Frank
Offline Hoffmann
#6 Posted : 19 February 2005 16:23:05(UTC)
Hoffmann
Hello Frank,
All the new upgrades of the decoders are in the New Marklin Catalog (The Book) however delivery of these upgrades are in the 2nd and 3rd quarter of this year(2005)
Martin
marklin-eh
Offline Sam
#7 Posted : 19 February 2005 16:48:24(UTC)
Sam
Wow!, so other than the "autoregister" of the loc and auto address, is there any additional function to the mfx locs? I wonder if it's going to be worth the $150+ cost (I'm sure it's $120 + hr labor at least)
Offline dudok12
#8 Posted : 19 February 2005 17:45:37(UTC)
dudok12
I have been asking myself the same question... To me the advantages of "upgrading" an "old" 6090* lok to mfx are rather small. It may get more silent, because the pulse rate is higher, as compared to 6090* equiped loks. I still doubt if this justifies the high cost...
IB since 2000. Latest loc aquisition: 37554 BR 55 a long time ago...
Offline Davy
#9 Posted : 19 February 2005 18:07:41(UTC)
Davy
You can use also the mfx decoder from esu. Price 60 euro.
http://www.miba.de/neuheit/05/02/esu1.htm
M-track with a CS2.
Offline frankv
#10 Posted : 20 February 2005 14:07:21(UTC)
frankv
The 60922 are out and in the dealer's stores. I was at another M* dealer on Saturday and he had several in stock. The difference between the new ones and the ones that are out is that the new ones have sound the 60922 does not have sound.
Frank
Offline rschaffr
#11 Posted : 20 February 2005 16:12:01(UTC)
rschaffr
Views messages in topic : 5,193
The 60932 sound version is due out in the 3rd quarter, according to my sources.
-Ron
Offline Sam
#12 Posted : 21 February 2005 03:40:37(UTC)
Sam
Anyone have any opinions about the LokSound3 models being sold for mfx? Are they 100% Marklin compatible or will you run into trouble with them vs using the Marklin ones?
Offline kgsjoqvist
#13 Posted : 23 February 2005 09:50:21(UTC)
kgsjoqvist
[size=1" face="Verdana" id="quote]quote:Originally posted by Sam
<br />Anyone have any opinions about the LokSound3 models being sold for mfx? Are they 100% Marklin compatible or will you run into trouble with them vs using the Marklin ones?
Haven't tried yet, but since ESU makes the mfx decoders for Märklin, they should be 100% compatible.
#14 Posted : 24 February 2005 00:27:25(UTC)
<br />The 60932 sound version is due out in the 3rd quarter, according to my sources
Those new mfx - circuits look nice. Unfortunately no word in M's data if engine sounds are speed-syncronized. But since there's also no connection (sensor) to the drivetrain visible ... [xx(]
Offline Sam
#15 Posted : 24 February 2005 04:01:53(UTC)
Sam
Wow! I just found out the Mfx decoders are going for $150+ each! too much for me... When I get my 39834 I'll see if they run all that much better, if I can't tell the difference, then my remaining locs will stay digital fx.
Offline laalves
#16 Posted : 25 February 2005 04:44:24(UTC)
laalves
[size=1" face="Verdana" id="quote]quote:Originally posted by dudok12
<br />I have been asking myself the same question... To me the advantages of "upgrading" an "old" 6090* lok to mfx are rather small. It may get more silent, because the pulse rate is higher, as compared to 6090* equiped loks. I still doubt if this justifies the high cost...
Totally true. I have been converting a few locos for customers, using loksound-mfx (145€), and lokpilot v.2.0 (30€), the last one in DCC/MOT and DCC only versions. You know what? PWM freq is the same in v2.0 lokpilots and loksoundmfx. And M 5* locos become very, very silky smooth and very silent, so, forget about lokpilot mfx (60€) and use the also new lokpilot for half the price and all the qualities..... If you don't care about mfx but do care about sound, you can also consider loksound3 which has all the great qualities of the loksoundmfx (except the arguable feedback) and costs 100€.....
Luis
Offline rschaffr
#17 Posted : 25 February 2005 05:12:23(UTC)
rschaffr
Where are you shopping? 60922 decoder at LokShop is €70.95 vs. €64.99 for the 60902. only €6 more. Now if you want sound, I agree that the LokSound Mfx are rather pricey. The 60932 sound "Nachrüstsatz" will be €127.70 on top of the 60922, as I understand it, and that is a bit much for a sound module and a speaker.
-Ron
#18 Posted : 25 February 2005 14:40:20(UTC)
<br />60932 will be €127.70 and that is a bit much for a sound module and a speaker
Ron, I agree with you. More than that, seems that sound is NOT speed-syncronized. Thus it's simply too expensive ... [xx(]
#19 Posted : 25 February 2005 15:05:37(UTC)
I agreed with john,it was too expensive!
Offline rschaffr
#20 Posted : 25 February 2005 15:55:26(UTC)
rschaffr
John: I've re-read the catalog entry for the 6093x. It is a full decoder, not an "add on" as I inferred from the "Nachrüstsatz" name, therefore one could expect that it is speed dependent as are the ESU loksound decoders from which it is derived. If you follow the "Marklin way" and buy a 60921 set to upgrade your older non-high efficeincy engine and then replace that decoder with the 6093x, it is very expensive, however if you buy just the 6093x (60931 for steam, 60932 for diesel, 60933 for electric) and the needed motor parts (armature, magnet, and motorshield) it is not all that expensive. If you already have an HE motor, all you need is the 6093x and you get the mfx decoder with sound. Not really that bad.
-Ron
Offline rschaffr
#21 Posted : 25 February 2005 16:11:14(UTC)
rschaffr
As a matter of fact, I just got a 60921 set to upgrade the Marklin 3358 red E103 I recently acquired on eBay. I'll post how it goes and how it reacts to my IB.
-Ron
Offline Sam
#22 Posted : 25 February 2005 16:31:15(UTC)
Sam
thanks, that would be great!
Offline rschaffr
#23 Posted : 25 February 2005 17:42:46(UTC)
rschaffr
I was planning to put a LokSound and motor upgrade in a Be 6/8 III (Marklin 3356) tonight (I also just received the magnet for the motor upgrade) but I think I'll do the mfx in the red 103 instead tonight. I am curious about the performance of that decoder with the IB, and I'll be on a business trip all next week.
-Ron
#24 Posted : 25 February 2005 18:49:55(UTC)
Ron:
ALL my new engines are factory original with nice sounds [^][^][^]. After operating my trains in analog mode since 1958 (when I was seven) I've jumped on the digital bandwagon very late (2004) - and then there were SO MANY nice locos available WITH sounds already !
Thus it simply didn't make much sense for me to still buy one of those first generation soundless digis. Overtaken by electronic evolution they frequently can be seen sitting on dealers shelves - nailed down forever due their high price tags biggrin. Only few dealers were so clever to discount'em in time ...
No, I'd welcome such new digital decoder with sounds (the 60932 Diesel version) for my beautyful old analog Swedish GM/ASEA XP800 NYC Gas-Turbine Loco. Perhaps ... [:p]
Offline rschaffr
#25 Posted : 25 February 2005 18:59:49(UTC)
rschaffr
To be honest, sound never really excited me. I have converted a few (V200 diesel with a loksound and a BR003, also with a loksound) and acquired a BR18 with sound, but I still run and love my silent loks just as much.
-Ron
#26 Posted : 25 February 2005 19:03:39(UTC)
Well - I like it cause it's more realistic playing. Especially chuff-chuff sounds on steamers Smile
Offline Guus
#27 Posted : 25 February 2005 21:31:34(UTC)
Guus
[size=1" face="Verdana" id="quote]quote:originally posted by John Black:
It seems once again we agree John,besides a steamloc with sound I have two E-locs that make very convincing sounds [:p] and I must admit it all makes playing more pleasureable.
[size=1" face="Verdana" id="quote]quote:originally posted by John:
Overtaken by electronic evolution they frequently can be seen sitting on dealers shelfes - nailed down forever due their high price tags . Only few dealers were so clever to discount'em in time ...
I'm still waiting for a pricecut on a very nice crocodile(M 39561) in brown livery ,that a local dealer still has on his shelves [xx(][xx(].
Best Regards
Guus
Kind regards,
Guus
#28 Posted : 25 February 2005 23:37:55(UTC)
<br />I'm still waiting for a pricecut on a very nice crocodile (M 39561) in brown livery that a local dealer still has on his shelves [xx(][xx(]
Guus: Since it's a buyer's market ... YOU will win in the long run Cool
Offline rschaffr
#29 Posted : 26 February 2005 06:52:17(UTC)
rschaffr
Done the conversion. I started with a 3358 E103 in the red livery:
Here it is opened up to get started:
Motor ready for conversion:
Conversion done:
And here it is in my station:
Conversion was identical to the 60901 conversion. The wires are the same color scheme. It runs beautifully with the IB, but I can't get it into programming mode with my IB. I have the Uhlenbrock instructions, but the lok won't go into programming mode (blinking lights). Anyone have experience with this?
-Ron
#30 Posted : 26 February 2005 12:14:15(UTC)
Beautyful work, Ron - congratulations [:p]!
Offline Mikael
#31 Posted : 26 February 2005 12:25:59(UTC)
Mikael
<br />It runs beautifully with the IB, but I can't get it into programming mode with my IB. I have the Uhlenbrock instructions, but the lok won't go into programming mode (blinking lights). Anyone have experience with this?
Yes. I recently did a 60921 conversion on the swedish lok from the 28703 set. I don't remember any particular problems programming it, but of course the special procedure described by Uhlenbrock (going out of programming mode while pressing the reverse switch) has to be followed.
Offline Guus
#32 Posted : 26 February 2005 12:47:31(UTC)
Guus
Congratulations Ron Smile.Nice pictures.
Once again ,that station looks awesome [:p][:p]
Guus
Kind regards,
Guus
Offline Sam
#33 Posted : 26 February 2005 17:27:31(UTC)
Sam
Good work Ron. One day I'll try my own hand at this kind of work, and save a few dollars and some time at the dealer's shop!
Offline rschaffr
#34 Posted : 26 February 2005 17:46:19(UTC)
rschaffr
Sam: Thanks. It's really not that difficult once you get over the fear of starting to do surgery on a lok. Now if I can just get past this programming thing. I guess I could take it to my 6021 layout and use the Marklin instructions, but I'd really like to figure out what the problem is with progrmming it with the IB. I HOPE someone is not going to tell me to remove all other loks from my layout...that would be a pain. Including my storage yard, I have over 20 loks sitting on the track.
-Ron
#35 Posted : 28 February 2005 09:38:15(UTC)
<br />I HOPE someone is not going to tell me to remove all other loks from my layout...that would be a pain - over 20 loks sitting on the track
Ron: Why not build a short test track - independant from layout - just for servicing and programming. I have such, it's very useful Smile
Offline Olav
#36 Posted : 28 February 2005 13:33:21(UTC)
Olav
So have I. The test track can handle every mode that is possible on my layout: IB control, analog control, MS control and ESU control. Just playing with some switches. And the testtrack is a round going "lay-out", so the loco's can really "go around". And it is NOT connected to the main lay-out, just to prevent any shortcitcuit.
Olav
Offline Sam
#37 Posted : 28 February 2005 21:25:10(UTC)
Sam
Or you can buy one of those test track pieces that allow you to run your loc in place.
Offline rschaffr
#38 Posted : 28 February 2005 22:41:09(UTC)
rschaffr
Guess I'll have to consider setting up a test track. I have a programming track on the layout, but my "test track" on my workbench is strictly analog, just to see if things power up
-Ron
#39 Posted : 28 February 2005 23:16:06(UTC)
You could isolate a small section of track which can be switched on or off from the main layout.
David
Offline Olav
#40 Posted : 01 March 2005 08:14:36(UTC)
Olav
That is tricky David. If by accident a loco is running from one section to the other you'll have a major problem. The best is to have a section which is 100% isolated form the main lay-out.
Olav
Offline Olav
#41 Posted : 03 March 2005 08:22:10(UTC)
Olav
[size=1" face="Verdana" id="quote]quote:Originally posted by Olav
<br />So have I. The test track can handle every mode that is possible on my layout: IB control, analog control, MS control and ESU control. Just playing with some switches. And the testtrack is a round going "lay-out", so the loco's can really "go around". And it is NOT connected to the main lay-out, just to prevent any shortcitcuit.
Olav
And here is a picture of my test track.
http://home.zonnet.nl/bnlrail/p...besturing/testbaan_1.jpg
Olav
#42 Posted : 03 March 2005 14:37:20(UTC)
<br />... here is a picture of my test track
Olav: Test track ?????????? - this is a complete TEST LAYOUT, you lucky guy Smile !!! (mine is really just a track - about 70 cm only, that's all ... [xx(])
Well, is that an opened MS on the left side ?
Offline Davy
#43 Posted : 03 March 2005 15:51:31(UTC)
Davy
Mine test track is almost the same. biggrin
M-track with a CS2.
Offline Olav
#44 Posted : 03 March 2005 22:55:29(UTC)
Olav
No, sorry John. At the back is one of the loopback units waiting for a modification. And as proof that my MS is still intact http://home.zonnet.nl/bnlrail/p...sturing/intellibox_1.jpg Smile
And yes, I'm very pleased with the testtrack.
Olav
#45 Posted : 04 March 2005 08:34:37(UTC)
<br />And as proof that my MS is still intact
Ha Ha Ha - M's warranty department will love you for that ...
Nice switchboard you have there Smile
Offline Olav
#46 Posted : 04 March 2005 13:11:42(UTC)
Olav
Thanks John.
Here you see it from a better side. http://home.zonnet.nl/bnlrail/p...ring/schakelpaneel_1.jpg
On my website there is an explanation, hwoever is it in dutch. Tonight it will be complete, but still in dutch.
Olav
#47 Posted : 04 March 2005 13:50:59(UTC)
Great equipment, Olav [:p] - many thanks for that link !
#48 Posted : 04 March 2005 20:44:27(UTC)
Great pictures and excellent control panel.
David
Offline rschaffr
#49 Posted : 08 March 2005 03:08:34(UTC)
rschaffr
Well, my lok programming problem is solved. I just received my ESU LokProgrammer with version 2.4.7 of the software. When I loaded it, it immediately upgraded to 2.4.8 and it SPEAKS MARKLIN MFX! Really easy screen interface for programming. Works like a charm.
-Ron
#50 Posted : 08 March 2005 04:48:52(UTC)
Ron: Glad for you it needed only the newest software Smile
Guest (12)
This page was generated in 1.017 seconds.
