Offline Ranjit
#1 Posted : 31 December 2004 13:50:49(UTC)
Ranjit
Hi All,
I am in the process of learning how to care for Marklin HO locomotives. I have started to dismantle a very old 3000, and begun to get my hands dirty. As the engine that I am working on is over 40 years old, I am sure to run into a lot of muck. My question is: does anyone know when, where, and how should grease and/or oil lubrication be used? What are the recommended types, and what are the specific characteristics (viscosity, consistency, conductivity, temperature resistance, corrosion inhibition etc.) of these materials.
warm regards,
Ranjit
#Get Vaccinated
Offline jaques
#2 Posted : 31 December 2004 14:13:12(UTC)
jaques
I use Singer oil. The Märklin oil is too thin. The most important is to not use too much oil (short circuiting, dirt,...) The oil should be applied on the little sponges next to the motor (if these are gone, I replace them with a piece of synthetic sponge (schuurspons in Dutch, I don't know the English word for it...), and on the gears (one little drop or so). After oiling, you need to run the vehicle a couple of minutes, so the oil can spread. If the engine gets hot, it may need a little bit more oil.
Hope this helps, and a happy new year,
Jonas
Offline Ranjit
#3 Posted : 31 December 2004 16:38:19(UTC)
Ranjit
Hi Jaques,
Thank you for your response.
Shouldn't the gears be lubricated by some sort of grease; and the wheels, armature shaft reseervoir, etc. be lubricated by some light oil? What are the other areas of the locomotive that need grease and/or oil lubrication? Is Singer 3-in-1 Oil really good for locomotive lubrication?
happy holidays and all the best for 2005.
Take care and warm regards,
Ranjit
#Get Vaccinated
#4 Posted : 31 December 2004 16:39:30(UTC)
In our "service" section there's one great article about Smile
Best Regards
Offline Ranjit
#5 Posted : 31 December 2004 16:57:57(UTC)
Ranjit
Service section? Where is this, John?
#Get Vaccinated
Offline Ranjit
#6 Posted : 31 December 2004 17:00:06(UTC)
Ranjit
Found it! Thanks a lot, John
happy holidays and warm regards,
Ranjit
#Get Vaccinated
Offline Ranjit
#7 Posted : 31 December 2004 17:23:23(UTC)
Ranjit
Hi All,
Just read the primer on lubricating locomotives in our service section. I must say that it didn't address the areas that I am concerned about, and I wasn't thrilled. For instance, the article did not mention the use of grease in lubricating locomotives. Surely, the gears, the cogs, etc. need to be greased and other rotational objects like axles, wheels, bearings need to be oiled. Also, there was no mention on the characteristics of these materials and how they aid preformance. I need more specific information andI would appreciate if someone can point me in the right direction.
--> Jaques: be warned of 'Singer Oil'. Just found out that because of its low viscosity, it is not recommended for locomotive lubrication.
warm regards,
Ranjit
#Get Vaccinated
Offline orubias
#8 Posted : 31 December 2004 19:43:05(UTC)
orubias
I once used Singer oil type, just to try and see, and well, the loco smell as a sewing machine!!! For me it´s no good use this type.
Band on the run
Offline HueyCE
#9 Posted : 31 December 2004 19:55:56(UTC)
HueyCE
Ranjit- Do not use any type of grease in your locomotives. It is far to thick. The small engines on the HO locomotives do not produce enough power to overcome the drag of the grease. Also in the newer digital locomotive the grease will get onto the wiring and produce short circuits.
Offline nico van zon
#10 Posted : 01 January 2005 01:48:33(UTC)
nico van zon
[size=1" face="Verdana" id="quote]quote:Originally posted by HueyCE
<br />.......the grease will get onto the wiring and produce short circuits.
This is nonsense. Oil and grease are electical isolators, so cannot cause shorts.
Offline rschaffr
#11 Posted : 01 January 2005 03:02:24(UTC)
rschaffr
Nico: Most greases are conductive. In my business (automotive/truck electrical wiring) we use a special dielectric grease. If you use normal grease it WILL short you electrical system out.
-Ron
#12 Posted : 01 January 2005 03:52:22(UTC)
Oil & grease will suck up carbon residues from the brushes and become conductive eventually, also get their way into the gaps of the commutator, so "over-oiling" is not recommended at all... Regular cleaning and modest oiling at the right spots is the way to go...
My favorite is the Faller oil with added teflon, works excellent for me. Another lubricant I use successfully is ordinary semi-synthetic 10-40 car motor oil of good quality... If there are plastic gears in the gear train, a fully synthetic oil should be used since mineral oil will eat plastic in the long run.
The crucial points are the motor axle ends with the classic Märklin motor. In the "newer" motors as the DCM the sponge containers are gone for some obscure reason, and they will need a "refreshment" now and then with a drop of oil before the next "full service". I also put a tiny drop of oil at the points where the gear axles are visible in the motor chassis. Makes wonders for the mechanical smoothness of the whole gear train. It is really the gear axles that are directly in contact with the metal motor housing together with the rotor end axle points that cause the most friction. The gears themselves are not the main culprits here as long as they are kept free of dirt, cat/dog hairs and such.
A small drop on the gears themselves is however useful too, but not too much since then it will splatter onto the tracks and make it slippery as well as destroy the efficiency of the rubber tires..
Offline Ranjit
#13 Posted : 01 January 2005 08:08:38(UTC)
Ranjit
Hi All,
It seems like grease should not be used at all. Even the gears should only be lightly oiled. Is this correct? Well, if the Marklin oil is too thin and the Singer oil is not recommended, what then? Juhan seems very satisfied with the Faller oil. Is this the only other make and type that is appropriate for small motors and gears?Juhan, is it the Faller Spezial-Öler (Item #489) that you use?
Apart from the wheels, axles, bearings, gears, armature shaft reservoirs, are there any other part that needs periodic lubrication?
Also, is Isopropyl Alcohol suitable for the cleaning of the wheels and other metal parts?
best regards,
Ranjit
#Get Vaccinated
#14 Posted : 01 January 2005 12:18:40(UTC)
A lot of oil and a lot of dust together destroy the
motors.I destroyed a 216 diesel with delta decoder
doing this.I thing that the different climate condi
tions all over the world have their importance.
#15 Posted : 01 January 2005 14:08:28(UTC)
Offline jaques
#16 Posted : 01 January 2005 14:21:27(UTC)
jaques
Well, actually the singer oil is doing a greeeaaat job over hereSmile
A little drop of oil here and there and the loco's run smoother than ever before. I don't know why I shouldn't use it? Neither I know why Marklin sells too thin oil...
Jonas
Offline Ranjit
#17 Posted : 01 January 2005 17:35:35(UTC)
Ranjit
Hi Juhan,
When you mentioned in the 'locomotive maintenance' thread that alcohol is not safe on paints, did you mean ispropyl alcohol? Is it true that even the purest (99.9%) anhydrous varieties can dissolve paints and be harmful to the plastics?
best regards,
Ranjit
#Get Vaccinated
Offline Ranjit
#18 Posted : 01 January 2005 17:40:06(UTC)
Ranjit
Hi Jonas,
If Singer Oil works for you now, Great! Maybe you just want to look into the long term effects.
best regards,
Ranjit
#Get Vaccinated
#19 Posted : 01 January 2005 18:17:19(UTC)
Maybe this is too simple but I follow the Marklin instructions with their locos and use their oil. Never had any problems whatsoever and if you use only a little oil very rarely then everything runs perfectly. Too many people like to open Locos and play about with the mechanism and unless you are replacing a part or repairing a second hand loco etc then keep the body on and run your trains.
David
#20 Posted : 01 January 2005 20:10:47(UTC)
nico van zon
<br />Nico: Most greases are conductive. In my business (automotive/truck electrical wiring) we use a special dielectric grease. If you use normal grease it WILL short you electrical system out.
Ron, after reading your posting I was a bit puzzled at first, but I decided to put it to the test. So I collected all the greases that I could find in the house and put the probes of my ohmmeter into a blob of each. I tested 4 types:
rollerbearing grease (for bicycles)
molybdenium grease
special grease for small instruments
the grease that Roco uses in the gearboxes of their locomotives.
All appeared to be non-conductive. So, if you state: most greases are conductive, I would change that in: most greases are non-conductive.
Don't know why greases in the automotive branch are conductive (do they contain carbon particles?) but I certainlty would not consider conductive greases the general rule.
Offline rschaffr
#21 Posted : 01 January 2005 20:19:34(UTC)
rschaffr
Nico: Most automotive greases are a lithium based compund (Lithium Oxide, maybe?) which is a metal. I know from experience that they are conductive. Before I got into my present line of work, I was replacing a lightbulb in an American car and noted that the socket was filled with a grease to inhibit corrosion. I put some wheel bearing grease in with the new bulb and shorted out my electrical system. Since I got into the automotive wiring business (about 10 years ago) I learned that there are special dielectric greases for that purpose.
-Ron
#22 Posted : 02 January 2005 03:11:22(UTC)
Ranjit, the alcohol used was "industrial alcohol" that you can buy in shops for cleaning up spots like tape glue residues, ballpen marks, rubber marks and so on, as well as using it in you camping kitchen burner... The red Märklin color will be dissolved, take my word for it...
Offline Ranjit
#23 Posted : 02 January 2005 08:11:59(UTC)
Ranjit
Hi Juhan,
I am still not sure if the 'industrial alcohol' that you are referring to is the same as the pure, high grade isopropyl alcohol that is safe on plastics (don't know about the paints) that I am talking about. I won't go near that stuff, if they are one and the same.
Apart from the wheels, axle end points, armature shaft reservoirs, bearings, are there any other areas that need periodic lubrication?
best regards,
Ranjit
#Get Vaccinated
#24 Posted : 03 January 2005 11:50:41(UTC)
<br />Also in the newer digital locomotive the grease will get onto the wiring and produce short circuits.
Many thanks Smile, Ira, learned something new, again - you surely got very rich experience from your airplane & chopper business ...
#25 Posted : 03 January 2005 12:00:35(UTC)
<br />Oil & grease will suck up carbon residues from the brushes and become conductive eventually, also get their way into the gaps of the commutator, so "over-oiling" is not recommended at all... Regular cleaning and modest oiling at the right spots is the way to go...
Since I've ever read Juhan's instructions (and more) in our Forum's "Service Area" I've got no single loco-related malfunction anymore - even my oldest engines run just fine Smile
It's so simple. Just read and learn ... biggrin
Offline Ranjit
#26 Posted : 03 January 2005 17:23:19(UTC)
Ranjit
Hi All,
After dismantling, cleaning and lubricating two of my 3000's, I find that one of them runs faster than the other. Although, I do not have an accurate speed tester, I noticed this by running them both simultaneously in an oval track. The faster loco caught up very quickly with the slower one! Why is this so?
Oiling at the axle ends really works wonders to the running performance, Juhan! Thanks a lot for letting me know.
best regards,
Ranjit
#Get Vaccinated
#27 Posted : 03 January 2005 21:40:49(UTC)
Just wait until I have tested to put a ball bearing instead of the plastic bearing that sits in the metal block of a DCM motor... biggrin
Offline HueyCE
#28 Posted : 05 January 2005 01:29:32(UTC)
HueyCE
John- You would be amazed at the number of electrical and avionics problems are solved with a little bit of cleaning. Now if only my experience would make me rich.biggrin
Offline Tamrac
#29 Posted : 05 January 2005 21:38:27(UTC)
Tamrac
Grease vs oil
I have always used Marklin oil. One small drop on the main gear and then on the motor bearing sponge. Spin the wheels by hand to distribute the oil between the gears. Then wipe off any visable excess on surfaces where it does not belong. I can not count how many older models I've serviced and found that the previous owner over oiled. It seems to accumulate under the pick-up shoe also,[xx(] so make sure you remove it and clean any oil you find. Also a pencil eraser should be used to clean the contacts for the pickup shoe.
The only place were grease has been called for is in the Flying Hamburger 37770/1. QUOTE:"Motor and gears should not be oiled. Use special grease TRIX 66626. Axels may be oiled as usual."
Lighter fluid was recommended to me some time ago as a good cleaning agent. I have used it with much success. I remove all wheels and gears, soak them in the lighter fluid for a few minutes, brush lightly, clean with a paper towel or cotton swab, then rinse with lighter fluid, allow to dry completely, reassemble, then lubricate sparingly. Wheel assemblies that I almost could not get to turn with my thumb, now spin freely.biggrin
Offline Guus
#30 Posted : 05 January 2005 22:32:20(UTC)
Guus
I've read the discussion in this topic with great interest.I know from experience in my work (aviation), that grease and electronics don't go together very well [:(].
I have a question though: Is it safe to use a non silicon based product like WD 40 to free sticky or oil hardened mechanical parts of a locomotive confused.
Thanks in advance Smile.
Best Regards
Guus
Kind regards,
Guus
Offline rschaffr
#31 Posted : 05 January 2005 23:56:51(UTC)
rschaffr
WD40 works fine in most applications, but I haven't had the nerve to try it on any of my precious loks. I use isopropyl alcohol and, if necessary, a VERY LITTLE BIT of lighter fluid on a q-tip for a particular tough spot.
-Ron
#32 Posted : 06 January 2005 00:55:26(UTC)
I sometimes use the CRC "555", which I suppose is the equivalent of WD-40 in Sweden... Really stuck gears/wheel axles loosen up and it solves hardened oil efficiently so further cleaning can be done.
I only use it with hopeless cases where a total lock-up in the wheel gears/axles is noticable, otherwise I prefer "softer" methods with "lacknafta" and Q-tips, as mentioned in the referred archived topics some posts ago.
Alcohol is ok to use where it doesn't matter regarding paint degradation like inside the motor compartment, but it doesn't dissolve carbon residues as nicely and efficiently as oil-based solvents like "lacknafta" or lighter fluid do...
But I have no negative comments regarding "555"/WD-40 when it comes to disssolve hard-to-reach area gunk-ups where manual mechanical cleaning is not possible... It is better than not being able to clean at all...
Tamrac, regarding your method of spinning the wheels by thumb, I have one word of advice here - NEVER do it if the wheels are stuck on a steamer or any other lok that has side gear that needs quartering to work 100%... If the wheels & gears move freely, then it's ok to do...
I once had a V60 diesel shunter in for service, and the shop owner wanted to show me that the wheels/gears were dead stuck and he tried to turn the wheels quite forcefully with his thumb just to show me... Needless to say, I spent quite some time to straighten bent rods and quartering wheels just because he "did not know better"... If the mechanism is stuck or hard to move, DON'T force it, clear case of where it is better use WD-40/555 instead...
Offline Ranjit
#33 Posted : 06 January 2005 05:34:34(UTC)
Ranjit
Hi Juhan, Ron, Guus, Tamrac and Ira,
Thank you all for your useful comments and expert advice.
Juhan, were you going to get back to me regarding the speed differential of the two 3000 locomotives?
Ranjit
#Get Vaccinated
Offline Tamrac
#34 Posted : 06 January 2005 06:17:53(UTC)
Tamrac
Juhan, thank you for clarifying. I should have been more carefull in describing my "rule of thumb"[xx(]
I was actually reffering to a Diesel Lok I recently cleaned.
I would never, never force my babiesSmile
If it does not move easily then it is stuck and should be properly cleaned.
Offline Guus
#35 Posted : 06 January 2005 10:18:19(UTC)
Guus
Ron and Juhan,Thanks for your advice.
Guus
Kind regards,
Guus
#36 Posted : 06 January 2005 13:26:57(UTC)
Ranjit, I have no idea why your 3000:s run differently... It could be many things - as different brush pressure, gears worn differently, assembly tolerances, condition of the commutator copper plates and so on...
Offline BarneyG
#37 Posted : 06 January 2005 23:33:44(UTC)
BarneyG
I have watched this topic (and others on loc maintenance) with interest as I too had a couple of 40 to 45 year old 3000s that I aquired late last year which needed some TLC. One was completely seized. I managed to get them both running with new brushes, new pickups and a drop of Marklin oil on the gears and motor bearing rod, however neither of them ran particularly well - stop and startin fits etc. I thought it might be a electric current problem, but none of my other locs experience similar problems, so I was at a bit of a loss.
I decided to swap a pickup shoe from one of my other locs onto one of the 3000s so see if it worked (a very long shot). When I unscrewed the pickup on the 3000, I found that the contact surfaces were covered in oil which had obviously displaced from the gears. The other 3000 was the same. So I completely cleaned the pickups and contacts of all oil traces, as well as the gears, and low and behold, both now run perfectly.
Important lesson learnt is to watch the oiling - one drop doesn't sound much but it is more than sufficient for a little loc.
David
M Track, Delta
Offline Ranjit
#38 Posted : 09 January 2005 09:01:31(UTC)
Ranjit
Thanks for the info, Juhan. Do even newly manufactured locos run differently because of brush pressure, tolerances, alignment, etc?
Btw, do you know why my 3000 stalls and automatically reverses direction at high speeds?
David, you are absolutely right about the oil on the contact points above the pickup shoe. It is amazing what a difference it makes if they are clean ans well mainted.
Cheers and warm regards,
Ranjit
#Get Vaccinated
#39 Posted : 09 January 2005 10:15:06(UTC)
I assume you have a relay onboard that need adjustment, sounds like the spring is not "springy" enough. If you have a new relay spring around, change it, you can also try to adjust it but a new spring is generally a better solution.
Yes, also new locos with the Märklin motor can have different characteristics. Faulhaber, C-sine, DC can motors are generally more consistent.
Offline Ranjit
#40 Posted : 09 January 2005 12:59:44(UTC)
Ranjit
I do have a new spring in place, Juhan. In fact, everything is new in this loco -- brushes, pickup shoe, etc. How do I adjust the spring's elasticity to make it work the way it should?
Ranjit
#Get Vaccinated
Guest (6)
This page was generated in 0.996 seconds.
