Offline Zora la rousse
#1 Posted : 24 November 2008 15:34:37(UTC)
Zora la rousse
Saterday 22 November a train derailed at Amsterdam Muiderpoort. 9 from the 25 wagons of a goods train left the rails. The total weight of the train was 2138 tons. The total damage is not known at the moment. After the tracks are cleared ProRail can see the rails and signals, and can decide how to repair it.
I must travel over another route the coming days to my work.
#2 Posted : 24 November 2008 16:36:30(UTC)
Wow! Thanks for the info Zora!
Was the loco also derailed?
Offline tekin65
#3 Posted : 24 November 2008 17:06:20(UTC)
tekin65
Turkey
Wow Zora, tough stuff. It must be hard to get them all off the tracks [xx(]
Cem.
Now all eras but no ICE
Offline DasBert33
#4 Posted : 24 November 2008 19:08:21(UTC)
DasBert33
Look at those nice NMBS cars...
Offline Rinus
#5 Posted : 24 November 2008 20:53:48(UTC)
Rinus
[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33
<br />Look at those nice NMBS cars...
More pictures of those nice cars on this site:
http://gespot.at5.nl/2008/11/23/ontspoorde-goederentrein/
By the logo's on their jackets it seems that the Strukton company will be clearing the mess.
Would be an interesting idea for a diorama together with the strukton train from Marklin.
Offline al_pignolo
#6 Posted : 24 November 2008 22:51:29(UTC)
al_pignolo
I hope nobody got injured in this accident. Fortunately it is a goods train and not a passenger one.
Has someone told why this happened?
Pietro
#7 Posted : 25 November 2008 04:52:23(UTC)
or was it SNCB cars?
(NMBS is the Flemish name for the railway, but SNCB is better known internationally.)
Were the cars full or empty at the time of the incident?
It seems that it is lucky that none of the cars went over the parapet of the bridge and down onto the street below.
Offline Troy Yang
#8 Posted : 25 November 2008 05:23:59(UTC)
Troy Yang
Must be the ROCO wheels they used.
Offline al_pignolo
#9 Posted : 25 November 2008 10:25:01(UTC)
al_pignolo
[size=1" face="Verdana" id="quote]quote:Were the cars full or empty at the time of the incident?
In the 3rd picture you can see some gravel on the rail. Maybe cars were loaded with gravel, but they could also have raised some ballast when they derailed
I found other pictures here: http://www.flickr.com/photos/erwyn/3051941937/
Pietro
Offline WelshMatt
#10 Posted : 25 November 2008 12:43:49(UTC)
WelshMatt
Actually, on the prototype the flanges aren't the primary means of keeping the stock on the rails apart from on tight curves. The wheel treads are slightly coned, which keeps the wheelset centred on the rails. You can tell when the flanges are hitting the rails because of the very loud screeching noises!
That's why we need to have overscale flanges in HO, because they are far more important to us than they are for the real thing. Some real steamers even had one or two flangeless driving wheels to help them around tight curves. You can get away with scale flanges but you would need to make everything else perfectly to scale, including the minimum radius of curves.
Matt from Wales.
#11 Posted : 25 November 2008 20:24:22(UTC)
Zora la rousse
I still had to make a detour today. As far as I can tell, the bridge is also damaged.
Offline Rinus
#12 Posted : 25 November 2008 20:49:00(UTC)
Rinus
[size=1" face="Verdana" id="quote]quote:Originally posted by al_pignolo
Pietro
The cars were filled with white chalk powder, which is also causing the white dust cloudes on Zora's first picture. In the Netherlands ballast and gravel are usually transported in smaller cars like these, which are easier to unload during rail construction works.
#13 Posted : 25 November 2008 21:50:43(UTC)
Thanks for the report, It might be hopper wheels damage before came off the rails?
Offline Rinus
#14 Posted : 25 November 2008 22:44:28(UTC)
Rinus
Possible.
Especially because it seems a accident with only one train involved. The Amsterdam area is being struck with several accidents in the past few years. One of which was caused my defects in the wheels.
Most of them however where caused my human factors. With the present safety system on the dutch trains, called ATB, it is possible to ignore a "red" signal when driving below 40 km/h, allowing trains to pass a signal which they shouldn't pass. For this reason the system is much critised recently. The National Transport Safety Board will investigate this accident, as usuall and report their findings.
Offline al_pignolo
#15 Posted : 26 November 2008 20:26:54(UTC)
al_pignolo
[size=1" face="Verdana" id="quote]quote:Originally posted by Evil R
How many drivers has got a train in the Netherlands? One or two?
#16 Posted : 01 December 2008 14:11:33(UTC)
Zora la rousse
5 of the 6 tracks are now available. The trains have to run slow over the bridge because of the new rails. But all is better than the diversions last week.
Offline pab
#17 Posted : 01 December 2008 18:47:37(UTC)
pab
Just one driver and one or two conductors for ticket checking, closing doors, etc. Ticketchecking is only done when the conductor is able to move through the train, which isn't possible in a lot of trains during rush hours. [:p]
Offline Rinus
#18 Posted : 03 December 2008 21:35:55(UTC)
Rinus
Some pictures of the derailment and the recovery works last week.
Enjoy!
Edited by moderator 11 January 2011 13:23:44(UTC)  | Reason: Not specified
#19 Posted : 03 December 2008 22:00:20(UTC)
Thanks for posting the pictures, Evil.
Offline Macfire
#20 Posted : 04 December 2008 04:14:46(UTC)
Macfire
Oops [:I]
Buggar[:I] [:0]
Lord Macca
Offline Pavle
#21 Posted : 06 December 2008 01:23:45(UTC)
Pavle
I had a similar derailment with those same cars (Langer Heinrich) on my layout a while ago. Only damage was a wheelset that I could easily put back in position Cool. Compare that to all those loose bits in the pictures above.
Conclusion: Marklin quality is much better as it's prototypes...biggrin
Offline Rinus
#22 Posted : 06 December 2008 18:25:07(UTC)
Rinus
[size=1" face="Verdana" id="quote]quote:Originally posted by Pavle
<br />I had a similar derailment with those same cars (Langer Heinrich) on my layout a while ago. Only damage was a wheelset that I could easily put back in position Cool. Compare that to all those loose bits in the pictures above.
Don't forget these were Belgium cars ... wink[:o)]
Offline Macfire
#23 Posted : 07 December 2008 04:36:55(UTC)
Macfire
ROLF biggrin biggrin biggrin
Lord Macca
Offline Tivvy
#24 Posted : 10 December 2008 08:36:59(UTC)
Tivvy
Any news on what caused the derailment? I see there was a turnout nearby, was that related to the derailment?
Ep IV / V Marklin Layout
Under construction.
#25 Posted : 10 December 2008 13:05:08(UTC)
Zora la rousse
What caused the derailment is still not known.
The bridge is damaged, still one track is not in use.
All the switches on the other bridge are broken.
Guest (6)
This page was generated in 0.808 seconds.
