Offline bygger01
#1 Posted : 23 November 2008 19:08:31(UTC)
bygger01
Do any know the trick, so I can solder wire to a normal K track
Steff
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
Offline WelshMatt
#2 Posted : 23 November 2008 19:24:49(UTC)
WelshMatt
I don't know if K track uses separate rail joiners like M track did, but if so you can make the connection to the rails by unclipping them and soldering the wire to them before refitting it. I'm not sure about the contact studs - you might have to do something like scraping plastic away underneath to find the metal to solder to. You can repair the damage with modelling putty, or it'll probably be hidden after you ballast and weather the track.
Matt from Wales.
Offline perz
#3 Posted : 23 November 2008 21:09:08(UTC)
perz
The contact figners that connect the center studs between the track pieces can easily be soldered with standard solder. No need for scraping plastic or anything
For the actual rails I think it is more difficult, but I haven't tried.
#4 Posted : 23 November 2008 21:15:47(UTC)
To connect "brown" to the rails themselves, solder the wire to the rail joints - the easiest way. It is possible to solder directly to the rails themselves with a good scraping & using acid solder flux, but the rail joiners are much easier.
Offline bygger01
#5 Posted : 23 November 2008 23:12:22(UTC)
bygger01
Brown to the rail joints - Do You mean the outer tracks, where it is possible to solder.
And for the center You will recommend buy Märklin 7504
Steff Smile
Offline Tivvy
#6 Posted : 24 November 2008 03:34:15(UTC)
Tivvy
I think Juhan meant these Steff wink
It is easier to solder to the rail joiners than it is to solder to the rail. It also means that you dont melt the plastic sleepers accidentally as you should remover the joiners from the track when you solder.
Ep IV / V Marklin Layout
Under construction.
Offline Macfire
#7 Posted : 24 November 2008 06:12:09(UTC)
Macfire
Hi Steff.
Two great forum topics to choose from :
Dales: https://www.marklin-user...ault.aspx?g=posts&t=5272
Ross's: http://members.ozemail.c.../~rossstew/rms/tips.html
Hope that helps
Lord Macca
#8 Posted : 24 November 2008 18:11:03(UTC)
Hi and welcome to the forum, Steff.
Offline Rowan
#9 Posted : 24 November 2008 21:18:24(UTC)
Rowan
Macfire has given you two good threads.
The only thing I would emphasise is the the area you solder must be clean; as in really , really CLEAN.
Smile
#10 Posted : 24 November 2008 21:29:16(UTC)
What you shall do by soldering at K-tracks,is by doing like this:
For the rail,i use 2 pieces of 7500 and connecting it or and solder at it on the copper-metal.
For the centre,i use clips under K-tracks and solder on it.
If you have undergrounds tracksstanding-line,you can using powerfeeder 7504 and just connecting at it.
If you want to use 7500 in the visuell tracks,you can bending 7500 slighting down and using ballast to covered over it.
If you are using corkunderlay...
Offline bygger01
#11 Posted : 25 November 2008 00:01:07(UTC)
bygger01
To all who had tried to help me - thank You
How can You find time to do it ........
Steff Smile
My next item will be automatic block system just for one direction by use of brake moduls from Viessmann / which forum is for this ??
This page was generated in 0.491 seconds.
