Offline WelshMatt
#1 Posted : 03 November 2008 11:48:57(UTC)
WelshMatt
Just taken delivery of my ebay find 6022, which still works perfectly after twenty-odd years. Why can't they make them like this any more?
One query, on the back of the unit below the heatsink there is a five pin socket. Does anyone know what this is for? I worked out what to connect to the yellow/red/brown terminals and know that the sockets on the sides are for 6035/6 and keyboard/memory units.
Matt from Wales.
Offline mmervine
#2 Posted : 03 November 2008 17:50:17(UTC)
mmervine
Matt:
This is the connection for a 6015/6017 booster.
r/mark
Offline WelshMatt
#3 Posted : 03 November 2008 17:58:43(UTC)
WelshMatt
Thanks Mark - guessed it might be that but was just checking.
Matt from Wales.
#4 Posted : 03 November 2008 22:01:27(UTC)
Is the 6022 manual booket with the unit, Matt?
Offline WelshMatt
#5 Posted : 04 November 2008 02:00:55(UTC)
WelshMatt
No - not a problem as I found the decoder addresses for the buttons on one site and have now figured out what all the sockets are for. It's a really simple bit of kit - the brown/yellow terminals go to the 16v AC output of a transformer and the red/brown terminals go to the track.
It was happily shuffling a couple of locos up and down on a quickly assembled test track within 5mins of opening the box, so I think all is well. Now waiting for a 74444 digital point control kit so I can test that side of it. I plan to upgrade four strategic points, probably those which will be hardest to reach.
Edit, data for anyone else who has one with no instructions:
The loco control buttons - 1 is address 10, 2 is 20, 3 is 30, 4 is 40
Edit, after further playing:
The point control buttons are 253, 254, 255 and 256, after a bit of testing button 4 turned out to be address 256 so I assume 1 is 253 and so on.
Yes it does work perfectly with the "built in" decoders for C track points, I've fitted one to my track pack double slip (which lacked a motor as it was from a pack, so used the combined motor and decoder kit) and it behaved perfectly on test. Now to convert another three strategic points.
Matt from Wales.
Offline mmervine
#6 Posted : 07 November 2008 17:45:18(UTC)
mmervine
the protocol for accessories has not changed over the years, so you should have no issues. You are correct. Button one is 253. If you ever get a 6023 (same as 6022, but with a computer interface), it starts with address 1 instead!
Offline WelshMatt
#7 Posted : 08 November 2008 01:00:25(UTC)
WelshMatt
If I see a 6023 at a price I can afford (and a seller that will take Paypal) I may well buy one - can they do the same things as 6051 in terms of receiving feedback signals from contact tracks via a module? The idea of replacing my 6600 with a computer controlled shuttle line is very appealing!
Matt from Wales.
Offline mmervine
#8 Posted : 08 November 2008 01:01:25(UTC)
mmervine
Matt:
Yes, you can plug an S88 directly into the 6023.
r/mark
Offline mvd71
#9 Posted : 08 November 2008 10:19:44(UTC)
Hi Matt,
Not only will the 6023 do the same thing as a 6051, it will do it much faster, although I'm not sure you get access to F1-F4.
Cheers.....
Mike.
Offline WelshMatt
#10 Posted : 08 November 2008 15:45:55(UTC)
WelshMatt
F1-F4 won't really matter on a simple end to end line. That said, I am pretty sure they will work if a 6036 is plugged in. The instructions for my 49960 Messwagen say that you can either use a 6020 and 6036 or 6021 to switch between the functions, and these are simply 6020s with some extra buttons added.
Matt from Wales.
Offline Lars Westerlind
#11 Posted : 08 November 2008 22:38:50(UTC)
Lars Westerlind
To be precise, f1-f4 is available, but can't be sent in the new format. f1-f4 differ very much in old and new format, so as most deocders understand the new format, barely none exist that can use the 6020/22/23. However, there are a few out there: Tanzwagen, Gesellschaftwagen, measure car, old stationary crane... And home built decoders based on the original Motorola IC.
Offline WelshMatt
#12 Posted : 09 November 2008 00:02:20(UTC)
WelshMatt
So it's worth buying the 6036 rather than 6035 - I can always replace my 6022 with a 6021 later on...
Matt from Wales.
This page was generated in 0.394 seconds.
