Offline Caplin
#1 Posted : 31 October 2008 20:49:57(UTC)
Caplin
I am getting fed up with my old soldering station. It is a Weller one temparature only station, iron with magnetic field that clicks the heating on-off. Although I clean the tip it sometimes surprises me the time it takes to melt two thin wires together ie.e holding the tip on the spot too long. I have no idea what the tip temparature is. Nowadays the stations have selectable temp. settings.
I will be looking for one, but what temp. range should I select for MMR work (mainly decoders, leds and so on)?
Any suggestions - thank you.
Benny - Outsider and MFDWPL
Offline sudibarba
#2 Posted : 31 October 2008 21:13:07(UTC)
sudibarba
<br />Hi
I havefound that sometimes a new tip works wonders.
Offline dikken
#3 Posted : 31 October 2008 21:53:59(UTC)
dikken
soldering on prints or wires abt 320°C should be enough. Soldering wires on rails 420°C! why? heats the spot where to solder quicker so heatspread is less. This way your plastic beams don't melt.
Dikken
Check out my site:
http://www.modelspoorhobby.be
#4 Posted : 31 October 2008 23:24:24(UTC)
I have digitally controlled Velleman soldering station and use about 320-450 degrees while soldering, depending on the tip used... Sometimes you want a quick heatup of a very small spot or a longer period for a larger spot with lots of lead flowing... Type of tip, heat, soldering area and type of wire - all make a difference on what temperature to use...
Offline hgk
#5 Posted : 01 November 2008 00:15:49(UTC)
hgk
If it's any help, I would also recommend one of these type cleaners for anyone doing more than a couple joints at a time.
It does the best job on keeping the tip clean which makes for better faster joints. Also lasts forever.
http://www.hmcelectronic...cripts/product/0460-0001
-George
Offline Legless
#6 Posted : 01 November 2008 00:55:01(UTC)
Legless
Thanks George, great link.
Legless
Offline Caplin
#7 Posted : 01 November 2008 01:51:39(UTC)
Caplin
Thanks for the link. That cleaner looks great. I found the Danish company that represents Hakko, but they deal only with registered firms - no sale for privat persons. [:(!][:(!][xx(]
Offline laalves
#8 Posted : 01 November 2008 02:22:45(UTC)
laalves
I use the Viessmann soldering station for normal MRR electronic work.
When I'm doing my hifi stuff, I sometimes use something bigger.
#9 Posted : 01 November 2008 03:26:47(UTC)
<br />Thanks for the link. That cleaner looks great. I found the Danish company that represents Hakko, but they deal only with registered firms - no sale for privat persons. [:(!][:(!][xx(]
Benny,
I got one similar at Dick Smiths electronics. Most electronic supply shops should have them.
Nev
Offline sudibarba
#10 Posted : 01 November 2008 04:14:22(UTC)
sudibarba
I use a local electronics store that has everything. I don't know if they ship international but they have various solder guns and the metal cleaners. About 5 for $10 I think. I bought a variable solder station from them in the store for about $30.
www.youdoitelectronics.com
Eric
Offline mmrcnzjohn
#11 Posted : 01 November 2008 05:37:41(UTC)
mmrcnzjohn
I got my temperature controller soldering at Dick Smiths as well
#12 Posted : 01 November 2008 11:22:41(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by mmrcnzjohn
<br />I got my temperature controller soldering at Dick Smiths as well
Me too.....this one here:
http://www.dse.co.nz/cgi...b06db/Product/View/T2250
And this is the cleaner Nev refers too, similar to the one hgk has:
http://www.dse.co.nz/cgi...b06db/Product/View/T2007
Offline DamonKelly
#13 Posted : 01 November 2008 13:20:51(UTC)
DamonKelly
The Märklin Soldering Station 70910 is actually a surprisingly good unit. It is a re-badged unit also sold by Veissmann as #7822.
One of the big German hobby electronics chains also re-badged it (can't remember the name...[:I]).
It has up to 3 pre-set temperatures with digital control (no swapping tips), and seems nice and stable.
Damon
Offline Ranjit
#14 Posted : 01 November 2008 20:36:33(UTC)
Ranjit
Hi All,
For MMR and other hobby reloated work, what is the recommeded wattage? Is a iron better that a soldering station? Is it advisable to obtain a non-temperatre controlled system vs. a temperatre controlled one?
How is Velleman compared to Weller systems?
Ranjit
#Get Vaccinated
Offline DasBert33
#15 Posted : 02 November 2008 10:39:50(UTC)
DasBert33
Always use a temperature controlled one for electronics (decoders etc)! It is a lot safer (for your electronics) and easier to work with.
Wattage depends on what you want to solder. I use a 30W weller solder station which is ok for small electronics but it is more difficult to eg. easily solder big metal areas like catenary.
Like already said the tip to be used is also important. While a very small needle like tip might seem easy to solder small things like wires to a decoder, keep in mind that such a small area can not transfer a lot of heat. You will need to heat up the solder/wires/pcbs longer giving the heat time to spread and thus more risk of damaging/melting things nearby. Therefore use a relatively big tip, for me the screwdriver shaped ones work best.
Bert
Bert
#16 Posted : 02 November 2008 12:45:02(UTC)
hello
IMHO, if you have decided for the temperature controlled version, take the highest wattage you can.
This way your solder joints will be more uniform and for larger ones, you won't have to wait a long time to get the parts to the right temperature.
Needless to say, use the solder as the heatsink to transfer heat to the pieces, and therefore, the more wattage you have at your disposal, the faster you can work, avoiding oxidation as much as possible.
My two pennies
#17 Posted : 02 November 2008 15:02:24(UTC)
I use the Märklin Soldering Station 70910. I am very happy with it, and it has a nice price.
Normally I set the temperature to 300 degrees.
Offline Darren W
#18 Posted : 02 November 2008 18:29:47(UTC)
Darren W
A little tip to help your soldering. When you place the iron on the items to be soldered try to apply a small amount of solder into the gap between the solder iron tip and the item. This creates a solder bridge that really helps with the heat transfer. Keeping your tip clean really important. Keep it tinned with extra solder when it is idle. Using the right size tip and right size solder will also help.
Cheers...
Darren
This page was generated in 0.564 seconds.
