Offline tpedroni
#1 Posted : 03 May 2002 03:35:38(UTC)
tpedroni
I'm wondering if others share my enduring experience of poor performance by Marklin Z locos. Specifically, even though I clean my track frequently (following a previous suggestion in this forum) my locos still seem run "fitfully" around my layout. That is, they start and stop in fits... never really obtaining a constant velocity. There are specific sections of the layout where this is most common; they are small sections (not even entire track sections, so I don't think it's a "contact" issue with a given individual track piece). I've given these sections particular attention with cleaning, but that doesn't really seem to alleviate the problem. I guess my primary question is-- Is this experience typical in Z? I never experience this in Marklin Ho, were option seems to be invariably smooth and even, and least as far as current conduction is concerned.
Offline KLB
#2 Posted : 03 May 2002 23:23:35(UTC)
KLB
Ok,I don't know much about DC or Z but maybe just a few things to check,....
Are all sections of the track getting enough power,check with a meter.Are the loks wheels also clean?If not the dirt on the wheels will be redeposited on the tracks.
Lok maintenance,is everything lubed,cleaned?
Good luck!
Kevin!
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline lassepd
#3 Posted : 24 July 2002 14:50:49(UTC)
lassepd
Actually, I've also got a question regarding z-locomotives.. About 'lubing' the locos; what oil should I use to do it? Does everyone recommend märklin oil or will normal sewingmachine oil do?
thx,
-L
Offline KLB
#4 Posted : 24 July 2002 22:12:18(UTC)
KLB
Hi L,all,
I wouldn't use Märklin oil,because IMHO it has high viscosity and dries out much too quickly.For my HO loks I use Labelle's 108 oil.Many also say that the Faller oil is very good also
Kevin!
Kevin!
Offline ztrains
#5 Posted : 28 July 2002 07:41:35(UTC)
ztrains
I agree,
Labelle 108 is a great choice. Also in order not to over oil, see if you can get a hypodermic needle. I actually brought one of my locomotives to my dentist to show him what I was using the needle for! It makes small, single drops of oil a breeze!
http://www.ztrains.com
Poor performance in Marklin Z (H0-scale)
by tpedroni 02/05/2002 10:31:58(UTC)
This page was generated in 0.702 seconds.
