Offline Rocca
#1 Posted : 24 October 2004 19:54:29(UTC)
Rocca
Hello to everybody, Smile
I would like to know if the new Trafo n. 60052 would be used only for light too, without the connection with the Mobile Station.
Thank you very much
With best regards [8)]
Stefano
Offline perz
#2 Posted : 24 October 2004 19:59:17(UTC)
perz
Yes, it can be used for that, according to Märklin.
Offline Rocca
#3 Posted : 24 October 2004 20:25:37(UTC)
Rocca
Hi Perz,
Thank you very much for the answer! Do you have just it?
Offline perz
#4 Posted : 24 October 2004 22:36:45(UTC)
perz
No, I don't have it, but there is a booklet that comes with the "Feuerwehr" set that describes the two new transformers. The 60052 is explicitly stated as suitable for "conventional hookup of model railroad lighting".
Offline Charlie
#5 Posted : 25 October 2004 01:43:09(UTC)
Charlie
Hello Stefano,
We have the new transformer in stock, and Perz is right.
It has only one connection, and you can use that to connect or the Mobile Station, or actuate turnouts etc, or hook up your lights.
Output of the transformer is 16 Volt AC.
Charlie
Offline Noel Loganathan
#6 Posted : 25 October 2004 02:47:58(UTC)
Noel Loganathan
Hi all
Just checking the 60052 trafo - it comes with a special socket and hence has some limitations. For instance the 60052 can be used for additional power output for conventional operations in addition to being a source of power for the MS and the CS.
IMHO - not as versatile as the 6003, but output generates 3.75 amps as against 3.25
Hope this helps
Cheers from a muggy Brissy
Noel
Noel
#7 Posted : 25 October 2004 10:37:34(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Noel Loganathan
<br />Just checking the 60052 trafo - it comes with a special socket and hence has some limitations
Since you can create your desired length of feeder wire and have fat 60VA for the lights I really don't see any limitations. I use one 60052 just for that purpose - great device Smile !!!
This page was generated in 0.388 seconds.
