Offline Ranjit
#1 Posted : 19 August 2004 16:59:59(UTC)
Ranjit
Hi All,
I have loads of 7299 track screws for mounting M-track. I was wondering if this screw is the same as the 74990 suggested by Marklin for C-track and if it can be used for C-track.
Ranjit
#Get Vaccinated
Offline McLae
#2 Posted : 19 August 2004 20:50:10(UTC)
McLae
No.
Not the same size at all. I have both, and the new C-track screws are smaller and longer. The hole in C-track is not big enough for the older screws. Of course, if you are willing to enlarge each hole with a drill.....[:p]
I use the old screws for other things, like holding down my IB and 6040.biggrin
At 100 screws for less that $10, I have more than enough for a layout larget than mine.
The McLae
Offline franciscohg
#3 Posted : 21 August 2004 21:11:58(UTC)
franciscohg
Chile
But screws for M's, i'm certainly interested onbiggrinbiggrin
Offline Ranjit
#4 Posted : 22 August 2004 07:25:31(UTC)
Ranjit
Hi Francisco,
Are you really interested in these 7299 M-screws? I have about 18 boxes (some in cardboard boxes and others in classic plastic red boxes) which have been wih me for a very long time. Let me know off this list so that we can make an arrangement.
Ranjit
#Get Vaccinated
#5 Posted : 23 August 2004 10:11:05(UTC)
The Bazar has opened biggrin
Offline John Kafak
#6 Posted : 17 September 2004 09:01:46(UTC)
John Kafak
I use 15mm brass escutcheon pins to hold down C-track ! Have to be 15mm ! Use needle-se pliers to hold them whilst tapping gently with a small hammer until in place . To remove use a larger screwdriver to lift track gently at the sides. Is this any help, or are you asking for help with fixing K-track ?
Offline piglesias
#7 Posted : 17 September 2004 17:53:40(UTC)
piglesias
[size=1" face="Verdana" id="quote]quote:Originally posted by John Kafak
<br />I use 15mm brass escutcheon pins to hold down C-track ! Have to be 15mm ! Use needle-se pliers to hold them whilst tapping gently with a small hammer until in place . To remove use a larger screwdriver to lift track gently at the sides. Is this any help, or are you asking for help with fixing K-track ?
Doesn't the brass color make it too noticeable?
Pablo
Offline John Kafak
#8 Posted : 18 September 2004 02:00:06(UTC)
John Kafak
Silly Pablo ! You just paint them over with gray paint ! BTW &gt; I use a white marker pen on the depressions before I bang the pins in so as I can find where to put them ,too!( grey on grey is hard to find)
Don't -cha know Aussies are very innovative people !
#9 Posted : 18 September 2004 21:58:08(UTC)
Marklin screws match C track in colour and are not noticable when in place. Why would you want to use anything else.
David
Offline franciscohg
#10 Posted : 19 September 2004 08:01:38(UTC)
franciscohg
Chile
specially if they are cheap enough.............
Track Screws for M yes M Track (H0-scale)
by frickwg 21/04/2024 20:19:36(UTC)
Train Track screws (H0-scale)
by Alex H 25/10/2023 22:55:20(UTC)
This page was generated in 0.339 seconds.
