Offline Armando
#1 Posted : 12 August 2004 04:53:48(UTC)
Armando
Hi everyone:
Is there a "safe" way to test the operation of a smoke generator (7226 or Seuthe N. 10 and 11) without having to stick it into a locomotive funnel? Could it somehow be connected to the transformer, such as, say, a station lamp to be tested?
Thank you for your help.
Greetings from Montreal,
Armando
Armando García
Offline rschaffr
#2 Posted : 12 August 2004 05:01:53(UTC)
rschaffr
You could test it with a direct hookup to a transformer, however the procedure I use is as follows: First, I measure the resistance across the generator with an ohmmeter. An open indicates a blown heating coil, zero indicates a shorted heating coil. I then hook it up to a variable power supply and apply voltage slowly.
-Ron
Offline jorge_vilarrubi
#3 Posted : 12 August 2004 05:32:48(UTC)
jorge_vilarrubi
Hello Armando, I put a couple drops of smoking oil inside the tube and connect it to the digital track.
If it works, you have instant smoke.
Regards.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline Davy
#4 Posted : 12 August 2004 06:54:31(UTC)
Davy
Will try this my self.
M-track with a CS2.
Offline Armando
#5 Posted : 12 August 2004 07:19:46(UTC)
Armando
Hello Jorge
Thank you for your comment.
How do you connect the little tube? Do you use two cables, say, one at the bottom and the other one on the side of the tube and then one of these cables goes to the center rail and the other to one of the two ground rails?
Saludos
Armando
[size=1" face="Verdana" id="quote]quote:Originally posted by jorge_vilarrubi
<br />Hello Armando, I put a couple drops of smoking oil inside the tube and connect it to the digital track.
Regards.
Armando García
Offline Noel Loganathan
#6 Posted : 12 August 2004 12:29:02(UTC)
Noel Loganathan
Armando
Try using alligator clips - one from the centre track and the other earthed to the outer track.
A clothes peg may come in handy
Noel
Noel
This page was generated in 0.243 seconds.
