Offline Eisenhower
#1 Posted : 03 August 2004 23:35:05(UTC)
Eisenhower
How do I construct a Helix?
The wood peaces underneeth the track - how long is each section - 4 sections per 360 degrees?
I have looked at Ron's great work http://www.sem-co.com/~rschaffr/trains/helix.html but cant see the details.
Could NE1 give me the materiale list used for building a helix?
(Maybe Ron could explain how he has build his? Smile )
Steen
Digital | C-Track | Epoche II-IV | Railroad & Co. 7.0 Gold | IB 1 | LocoNet
Offline rschaffr
#2 Posted : 04 August 2004 00:46:12(UTC)
rschaffr
Eisenhower:
We cut circles in plywood to the right diameter, then split them across the run of the track, expanded the circle into a helix, then joined the ends together. Each circle had eight "ears" (four inside and four outside) which we drilled holes in for the support. The support is threaded rod ("allthread") and nuts and washers. You can adjust the hight of any quadrant (and the tilt) by turning the nuts. Each nut was a double to lock it in place when we were satisfied.
-Ron
Offline rugauger
#3 Posted : 04 August 2004 04:51:51(UTC)
rugauger
Richard
Offline Eisenhower
#4 Posted : 04 August 2004 10:45:28(UTC)
Eisenhower
Great ! Smile
many thx to Ron and Richard wink
Steen
#5 Posted : 04 August 2004 12:19:09(UTC)
Thanks from me too... It was always something that I wanted to know, but I was afraid to ask.. Thanks for asking, Eisenhower..
Offline daveblackburn
#6 Posted : 05 August 2004 20:55:15(UTC)
daveblackburn
Just an added tip - the easiest way to size the helix is to lay out the flat circle (or oval) of track, tape it down, and trace it with a good black marker. Then use a jigsaw or bandsaw to cut around it with enough room to spare to catch the inevitable derailments.
Offline HueyCE
#7 Posted : 06 August 2004 03:16:21(UTC)
HueyCE
Great timing. I'm in the process of working out a helix on my layout right now, thanks for the links rugauger.
This page was generated in 0.303 seconds.
