Offline perz
#1 Posted : 23 March 2004 01:25:23(UTC)
perz
I have made this power connection device for M tracks:
The other side:
I made these circuit boards for an IR train detection system (similar to Uhlenbrock Lissy) but I had to order more boards than I needed, so I also made them useful for power connection. I use a 4-pole pin header that is wired symmetrically. That way I do not have to worry about the polarity.
Why didn't anyone invent this device 30 years ago ? Now when M-track is almost history it is a bit late wink.
Offline jorge_vilarrubi
#2 Posted : 23 March 2004 02:46:32(UTC)
jorge_vilarrubi
Good job, Perz!
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#3 Posted : 23 March 2004 10:31:32(UTC)
Hello Per,
As I use lots of m-track, I am really interested, but I can't see the pictures..
Offline perz
#4 Posted : 23 March 2004 20:51:18(UTC)
perz
Oh no! Not again! I guess it is some DNS problem (it usually is when you can't see my pictures). Try these links instead:http://home.swipnet.se/perz/track_power.jpg and http://home.swipnet.se/perz/track_power2.jpg
That is on my other ISP.
#5 Posted : 23 March 2004 22:09:10(UTC)
Ah yes... Very simple.. I addresses the earth/ground supply much better than the 5004 solution.. Can I assume that they slide underneath the third rail and do not require solder?
Why do you have four pins on the plug?
Offline perz
#6 Posted : 24 March 2004 16:53:17(UTC)
perz
No soldering to the track required.
I use a 4-pin plug because I want it to be symmetrical. Ground ("brown") is on the two outer pins and power ("red") on the two inner. No risk for wrong polarity that way.
This page was generated in 0.249 seconds.
