Offline Marty
#1 Posted : 16 August 2008 19:13:48(UTC)
Marty
I'm just trying to learn as much about digital as possible, so bear with this analog user: [:I]
Since the track always carries a full 16V on a digital layout, do the wheels of loks and passenger cars with lighting get pitted over time due to electrical arcing?
Marty
Offline perz
#2 Posted : 16 August 2008 19:59:58(UTC)
perz
Generally not. Maybe it can happen in some unfortunate cases, but it is not at all likely.
Electrical arcing is much less probable with a digital lok than with an analog one. The motor contains coils, which can create high voltages if the circuit is broken abruptly. In an analog lok, those high voltages can go directly out on the track and cause arcing. The digital decoders contain protection circuitry, mainly to protect the decoder electronics. But this also stops the high voltages from reaching the wheels and pick-up shoe. There is some protection in the analog loks too, but not at all to the same degree.
#3 Posted : 16 August 2008 21:42:04(UTC)
Marty, digital track voltage is around 22 volts (MS with 18 V DC power supply around 20 volts).
That's why you need different light bulbs or smoke generators for some models.
Offline Caplin
#4 Posted : 17 August 2008 00:43:39(UTC)
Caplin
Also the distance between the wheels on the axle is important. Pls. see further in this topic:
https://www.marklin-users.net/fo...ult.aspx?g=posts&t=10450
Benny - Outsider and MFDWPL
Offline Marty
#5 Posted : 18 August 2008 03:31:18(UTC)
Marty
Thanks for the input.
Marty
This page was generated in 0.260 seconds.
