Offline Karl Pann
#1 Posted : 01 February 2004 16:25:52(UTC)
Karl Pann
Can someone please explain the radius of the Marklin system curves? In the US, a lot of hobbyists believe that 22 or 24 inch curves are the minimum to operate longer cars or locomotives. My question is, how do these numbers like 18 or 24 inch, relate to say the R1, R2, R3 and so on of the Marklin system. Is the R1 curve sharper than an 18 inch curve?
K. Pann
Offline Transfesa
#2 Posted : 01 February 2004 16:45:14(UTC)
Transfesa
Hi Karl,
If you want to compare the radius of the curves, Märklin R1 have a radius of 360 mm, so it's more or less like US 14 inch curves. There's no doubt it's too tight for a main line track, so many modellers only use R1 on hidden areas, and in the visible track they only use R2 (437 mm, like 17 inch curves) and even R3 (515 mm, like 20 inch curves). If you have enough space, the wider the curves are, the more realistic a long-coaches train looks wink
Hope to have helped you.
Julio Castillo
Madrid, Spain
Offline perz
#3 Posted : 01 February 2004 17:25:10(UTC)
perz
It should be noted that all (or at least almost all) Märklin H0 cars and locomotives can be operated on R1 radius. Modellers with lot of space often avoid the R1 radius, but mainly for aestetic reasons. Another reason to avoid R1 could be if you want to use non-Märklin equipment, since not all locos and cars of other brands can negotiate the 360 mm radius.
For C-tracks there are:
R1 = 360 mm (14.17 inch)
R2 = 437.5 mm (17.22 inch)
R3 = 515 mm (20.28 inch)
R4 = 579,3 mm (22.81 inch)
R5 = 643.6 mm (25.34 inch)
And also 1114.6 mm (43.88 inch)
For K-track there are:
R0(?) = 295.4 mm (11.63 inch). Not all Märklin models can handle this, but many anough.
R1(?) = 360 mm (14.17 inch)
R2(?) = 424.6 mm (16.72 inch)
R3(?) = 553.9 mm (21.81 inch)
R4(?) = 618.5 mm (24.35 inch)
And also 902.4 mm (35.53 inch)
For M-track there are:
R0(?) = 286 mm (11.26 inch). Not all Märklin models can handle this.
R2(?) = 437.4 mm (17.22 inch)
thanks 2 users liked this useful post by perz
Offline Lars Westerlind
#4 Posted : 02 February 2004 00:07:14(UTC)
Lars Westerlind
Karl,
please note that this is an international forum, so if you'd be so kind not to use local measures. As well as we normally don't use french or swedish, even if that's also possible to translate.
Lars
#5 Posted : 02 February 2004 00:28:24(UTC)
Karl, welcome to the forum.
One inch is about 25,4 mm, so an 18-inch curve radius should be about 457 mm in the metric system, which is somewhere between the R2 and R3 for C-track from Märklin according to perz's table.
Lars, I understand the quest for international measures everywhere, but as I understand - that is exactly what Karl is asking us to help him with...wink
Offline jorge_vilarrubi
#6 Posted : 02 February 2004 01:05:42(UTC)
jorge_vilarrubi
Hi Karl, I work for IBM/USA and know about the difficulties with translation from/to inches/metrics, as well as temperatures in Fahhrenheit or Celsius, Pounds or Kilograms, etc. However, metrics are the standard in Europe ( and in South America too ), so they millimeters to indicate radii. The good news is that Märklin appends the angle in degrees to curved tracks and the lenght in millimeters to the straight tracks.
All tracks are numbered 24nnn. So, 24 can be ignored...
For curved track: the third digit indicates the Radius, the fourth and fifth the degrees.
So a 24530 is R5, 30 degrees.
For straight track: the last three digits indicate the lenght in millimeters, so a 24229 is a straight track 229 millimeters long.
With the conversion table above, you'll find the measurement for any track you want to use.
In regards to radii, my preference is the largest curves possible. I use R5 and R4 for the mains, R3 only for yards. Long turnouts (24711/12) are ideal for non-Märklin locos and 1:87 coaches (Roco & others).
If you plan to use non-Märklin locos and/or American type locos (big boy...) avoid curved turnouts (24672/72) and the double slip 24624, they are derailment prone...
Hope not to have confused you too much... ;-)
Regards from this hot Buenos Aires.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
thanks 1 user liked this useful post by jorge_vilarrubi
Offline Karl Pann
#7 Posted : 02 February 2004 13:43:39(UTC)
Karl Pann
Thanks everyone. I appreciate it.
K. Pann
Offline Gregor
#8 Posted : 02 February 2004 14:22:53(UTC)
Gregor
Wasn't there some kind of a satelite or moon probe which crashed last year because the engineers used the imperial value for gravitational constant instead of the metric value?? Slightly worse than a model train derailment... (Although maybe the engineers involved now have plenty of time to enjoy the hobby....wink[}:)])
Gregor
Offline McLae
#9 Posted : 02 February 2004 23:12:51(UTC)
McLae
If I remember correctly, it was a Mars probe. Some number was not converted from Imperial to Metric, resulting in a navigation error.[:(!]
I do most MRR calculation in Metric (I even have a metric measuring tapeSmile). The length combination tables in the Operation Related area do come in handy.biggrin
The McLae
#10 Posted : 02 February 2004 23:52:01(UTC)
As I understand, the Pathfinder (ie the Rover...) was supposed to do it all in metrics but that thought had not propagated throughout all the channels at NASA...
Ok, we're a bit off topic now - but it shows how lack of respect to international standards can mess it up also in the most advanced projects sometimes... [B)]
#11 Posted : 02 February 2004 23:57:37(UTC)
jorge_vilarrubi
A Boeing 767 suffered an accident when ran out of fuel because the fuel load was calculated in Kilograms but loaded in Pounds, 454 grams instead of 1000 per Kilogram...
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline McLae
#12 Posted : 03 February 2004 01:22:19(UTC)
McLae
I think that was in Canada. There was a story of how the pilot was able to land on an abandoned airfield.
The McLae
Offline jonnymac
#13 Posted : 03 February 2004 21:29:56(UTC)
jonnymac
true story - landed in a little town called Gimli Manitoba. The 767 has been called the Gimli Glider ever since. Here's the web page. http://www.wadenelson.com/gimli.html
Offline kimmo
#14 Posted : 06 February 2004 11:12:42(UTC)
kimmo
Thanks John,
Really amazing story. Thanks for providing the link. I had never read the story before.
Kimmo
Offline McLae
#15 Posted : 12 February 2004 02:15:19(UTC)
McLae
As an interesting tidbit.....
Go to the Viessmann web site http://www.viessmann-modell.de/.
Click on Produkte
Click on Oberleitungen (catenary), then HO
scroll to the bottom of the pate, and click on Zubehor
scroll down some to find two tables with Track maker, radius, and Catenaty wire length. Also Viessmann part number of the wire.biggrin
This handy reference has the track radius of Marklin, Roco, Tillig, and Fleischmann.biggrin
The McLae
Offline Tamrac
#16 Posted : 16 February 2004 08:00:33(UTC)
Tamrac
For those that need a quick fix!
This website has helped me with many a conversion:
http://www.onlineconversion.com/
This page was generated in 0.374 seconds.
