Offline cos_man
#1 Posted : 18 October 2003 03:04:00(UTC)
cos_man
Dear fellow members,
I have a MA 3680 Kof (I believe is the first Kof that Marklin produced) and I tried it with the IB I recently got.
The IB shows on the display the opposite direction arrow of the way the Kof is running on the tracks.
I have other Marklin Kof's and the direction arrow on the IB follows the correct direction of them.
Does anyone have this Lok and witnessed the same behaviour by using the IB?
Unfortunately I can not remember if I got the same thing happening with the 3680 and an 6021 CU.
Do you thing that by reversing the wires that go to the decoder I can correct this?
Thank you
Costas
Offline digilox1
#2 Posted : 18 October 2003 12:55:54(UTC)
digilox1
Costas,
36xx locos have decoders that only accept "Change Direction" commands,
not "Run Forward" or "Run in Reverse".
So, select the address, push the reversing knob once, WITHOUT the loco
on the track, then put the loco back on the track and the problem should be fixed.
Manfred
Offline cos_man
#3 Posted : 19 October 2003 13:02:58(UTC)
cos_man
Manfred,
You are RIGHT! It works biggrin
Many thanks my friend.
Costas
Offline jorge_vilarrubi
#4 Posted : 15 December 2003 22:26:53(UTC)
jorge_vilarrubi
Hello Costas,
As Manfred said, old Märklin decoders do not recognize the 'absolute direction' because they only accept 'old Motorola format' commands, so the arrow in the display is nonsense.
Please try this:
Have your loco running and check it's direction of travel, then stop the loco.
Now press the 'stop' button.
Change loco's direction while IB is in stop state. The arrow will change direction.
Now press 'go' and have your loco running, you will notice it doesn't change direction if it doesn't recognize 'new Motorola format'.
In these cases, you should change the loco data format to 'Mot old', using 'lok', 'menu', from the IB panel.
Best regards.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
This page was generated in 0.548 seconds.
