Offline tomh.
#1 Posted : 12 October 2003 13:09:26(UTC)
tomh.
I am a Marklin beginner,with no experience, although I have been around HO's for a good many years.I would like to build a Marklin layout, and know that C track has five different radii, according to what I have read. However, I have not found anywhere what those radii actually are.What is the largest, the smallest? I can't plan a layout unless I have this info. Any help for this greenhorn would be greatly appreciated. Thanks.tomh.
tomh.
Offline Thanos
#2 Posted : 12 October 2003 13:45:37(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:However, I have not found anywhere what those radii actually are.What is the largest, the smallest? I can't plan a layout unless I have this info. Any help for this greenhorn would be greatly appreciated.
Hi Tomh and welcome to the forum!
The Marklin catalogue has a good explanation of the various radii available for C track so I believe that if you plan to start a layout you should get that as a first step. However:
The standard C track curve (R1) has the customary radius for HO of 360mm and an external diameter of 76cm. R2 has a radius of 437.5 mm and a diameter of 91.5 cm. That's a two track oval with 1m width. R3 has a 515mm radius and an external diamter of 107cm. R4 has a 579.3mm radius and R5 has a 643.6 mm radius.
Thanos
Offline tomh.
#3 Posted : 12 October 2003 14:46:57(UTC)
tomh.
Thanos:
Thank you so much for your incredibly promt reply.I will check the catalog as well, but your information is extremely helpful.Many thanks. Tom
tomh.
Offline tnx jake
#4 Posted : 12 October 2003 18:13:32(UTC)
tnx jake
Hi tomh,
Thanos has given you an excellent explaination of C track. I am in the process of laying out a new layout and am using the R4 and R5 radius for the first time. If you have the room, they really make beautiful curves. C track is really great. It has good geometry as long as you follow it. Good luck and welcome aboard.
Jack
Offline tomh.
#5 Posted : 12 October 2003 20:29:17(UTC)
tomh.
Hi Jack:
Thanks for your input,welcome, and encouragement.I'll see if I can stretch my room a bit.
tomh.
Offline Thanos
#6 Posted : 13 October 2003 10:10:41(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:Originally posted by tomh.
<br />Thanos:
No problem Tom! Let the layout begin... biggrin
Thanos
This page was generated in 0.492 seconds.
