In the Marklin catalog most shots with C track layouts show a ballast near the top of the rails, or almost covering the roadbed. For those that use C track, do you ballast the sides with real rock like Noch or Woodland Scenics? What color do you use? Do you keep it loose, or bond it to the roadbed?
Joined: 19/03/2002(UTC) Posts: 1,088 Location: Athens,
Hi Bill,
On my layout I have used the Busch ballast (7069) especially made for C Track! It has the same color with the C track ballast and it blends nicely with the scenery. There is also C track ballast from Heki I think... I put a little on each side of the track and then I use other scenic materials (earth ground, grass, etc). |
Thanos
Joined: 15/03/2003(UTC) Posts: 9,603 Location: Australia
Hello Thanos,
Any idea what ballast to use with m-track??
Cheers Adrian |
Adrian Australia flag by abFlags.com |
Quote:[size=1" face="Verdana" id="quote]quote:Any idea what ballast to use with m-track?? I think that you could use any ballast with m track - haven't tried it myself as I have a C track layout, but it's simple I guess! You can put any ballast that suits you. |
Thanos
Joined: 12/01/2002(UTC) Posts: 2,578 Location: Sweden
I have found that natural sand from a beach mixed with medium ground black pepper will match the M tracks very well.
Regarding c-track ballast, look at the "weathering C track" topic under "painting and weathering".
