Offline Bill
#1 Posted : 01 July 2003 07:43:47(UTC)
Bill
In the Marklin catalog most shots with C track layouts show a ballast near the top of the rails, or almost covering the roadbed. For those that use C track, do you ballast the sides with real rock like Noch or Woodland Scenics? What color do you use? Do you keep it loose, or bond it to the roadbed?
Offline Thanos
#2 Posted : 01 July 2003 11:37:00(UTC)
Thanos
Hi Bill,
On my layout I have used the Busch ballast (7069) especially made for C Track! It has the same color with the C track ballast and it blends nicely with the scenery. There is also C track ballast from Heki I think... I put a little on each side of the track and then I use other scenic materials (earth ground, grass, etc).
Thanos
#3 Posted : 01 July 2003 11:49:31(UTC)
Hello Thanos,
Any idea what ballast to use with m-track??
Offline Thanos
#4 Posted : 01 July 2003 13:33:49(UTC)
Thanos
[size=1" face="Verdana" id="quote]quote:Any idea what ballast to use with m-track??
I think that you could use any ballast with m track - haven't tried it myself as I have a C track layout, but it's simple I guess! You can put any ballast that suits you.
Thanos
Offline perz
#5 Posted : 01 July 2003 17:08:10(UTC)
perz
I have found that natural sand from a beach mixed with medium ground black pepper will match the M tracks very well.
Offline perz
#6 Posted : 01 July 2003 17:17:06(UTC)
perz
Regarding c-track ballast, look at the "weathering C track" topic under "painting and weathering".
This page was generated in 0.519 seconds.
