Offline PeFu
#1 Posted : 23 May 2003 12:08:14(UTC)
PeFu
WIthout opening the locomotive, how would one know if there is a permanent magnet (i.e. a DC motor) in Roco AC engines, and other non-Märklin three-rail non-digital AC engines? If there is a permanent magnet, what is your experience installing a Märklin 60902 decoder (or any other Märklin-Motorola compatible decoder) into the engine?
<img src=icon_smile_question.gif border=0 align=middle> Peter
Offline Lars Westerlind
#2 Posted : 23 May 2003 14:21:02(UTC)
Lars Westerlind
To be corrected: I don't think that any manufacturer beside Märklin and HAG use all current motors. When they make a AC model they only install a slider and insert a direction relay. Nowadays I think they only supply the latter; inside is a NMRA plug with 2 diodes for the light when running DC, this simple plug is replaced by the plug of the relay (or decoder with plug).
I'm not thinking of installing a 60902; I would install a Lokpilot instead. Which has the plug. I see no reason to pay for a 60902, and the extra work with installation (if NMRA socket). OK; here is an answer to your question: if the box is marked with the NMRA plug symbol it certainly is a DC motor.
BTW, the 5 pole motor of Roco is really good!
Good luck.
Lars
Offline GDamen
#3 Posted : 23 May 2003 16:50:56(UTC)
GDamen
Peter,
Roco engines are already DC, so no need for conversion. As for the decoder, use a LocPilot. They are a perfect match (Roco uses LoPi's in their AC-models).
Gino Damen
__________
IB Digital,EP-III, DB&ÖBB
Märklin DB - DC USA UP/BN - IB Digital
Offline perz
#4 Posted : 24 May 2003 01:07:54(UTC)
perz
There is one disadvantage with the LokPilot though: It does not apply any speed / acceleration control in conventional AC mode. The Märklin 60902 actually applies the maximum speed and acceleration delay in conventioal AC mode too.
#5 Posted : 24 May 2003 02:55:33(UTC)
And so does the Lenz 930 (that Roco used as their "AC"-decoder just prior to the Lokpilot)... It also has a relay on board so it remembers the last direction. Nice decoder, even if it has its own issues of implementation considerations... With Roco 5-pole motors, it works fine though...
Offline PeFu
#6 Posted : 25 May 2003 23:59:15(UTC)
PeFu
Thanks for your comments! So, anything else than Mä or HAG (like Rivarosso, Brawa etc.) actually has DC motor.
<img src=icon_smile_cool.gif border=0 align=middle> Peter
Offline Peter Neumann
#7 Posted : 26 May 2003 07:46:33(UTC)
Peter Neumann
I'd like to come back to the original question again because it is of considerable interest to me...the conversion to digital of ROCO AC engines.
Specifically, I have a ROCO E140, E112, and a Rivarossi E17 - all the rail.
What say you to the conversion of these engines with the LokSound2 decoder?
I have one former Marklin HAMO engine - the BR 86173 that was converted to three rail using the Lokpilot.
Peter Neumann
This page was generated in 0.434 seconds.
