Offline grattieri
#1 Posted : 17 January 2003 15:17:55(UTC)
grattieri
Hi all I'm new to Marklin ,but I'm a experierenced modeller in
DC system . I have built an universal layout using C track
(I have insulated all the tracks and turnouts and I have supplied
the frogs ). At present I have tested the layout both in DC and
AC and the results seem very good ( i.e all Dc small locos I have
tested run perfectly on the turnouts). I have some doubts
about the dimensions of the frogs and the gauge (I know that
Marklin doesn't meet exactly the NEM gauge ), because I have more
than 100 Fleischmann locos ; so I would like to have some
information about the size of frogs and rails in order to try
to solve the problems ( derailments , slow run and so on) in
case they occur. Thank you in advance
Marco
br01
br01
Offline Charlie
#2 Posted : 17 January 2003 15:27:09(UTC)
Charlie
Hi Marco,
I'm confused. You said you are using C-track... Marklin C-track right? In that case all your -future- Marklin purchases will be really happy to run on that track.
You'll have to insulate/isolate your Marklin wheels, they would cause shorts on the DC portion of your track.
A howdy from Texas,
Charlie
Offline grattieri
#3 Posted : 17 January 2003 15:44:33(UTC)
grattieri
Hi Charlie I have insulated the rails and the turnouts of my
layuot in C track ; when I use DC locos I use a DC power supply
feeding only the external rails and when I use Marklin locos
I use the Marklin transformer feeding center pins and shorting
external rails. Obviuosly it's impossible to use Marklin system
and DC system at the same time.
br01
br01
This page was generated in 0.249 seconds.
