Offline argal
#1 Posted : 07 January 2003 10:58:15(UTC)
argal
Hi everybody!
I am new to the scene and to this forum, although I have been reading your comments for some time.
I wonder if anyone else has come across a problem I have with my steam loco class 81 or has any advice.
Very often the engine gets jerky. Whilst on the move, it has difficulty in mainting its speed, it sort of brakes for a second making a grindy noise and then moves again. In a track of abt 9 meters length, this will happen about 4-5 times. This will mainly happen when the engine is cold, that is in the begining of a session, but sometimes also when has done few runs. I tied to oil her but I overdid it and sent it for cleaning. On her return she worked fine for one week (abt 5-6 hours in total) but then started doing the same again. Any idea what I can do to save her?
Your advice will be highly appreciated.
#2 Posted : 07 January 2003 16:23:10(UTC)
The reason for this behavior is usually dry rotor/cogwheel axle bearings..
One tiny drop of oil from the outside on each side where the motor axle is visible (the metal block, and the plastic motor shield). I also usually put a tiny drop where the motor gear axles are visible, normally 2 small "holes" in the metal block.
Offline argal
#3 Posted : 07 January 2003 16:56:35(UTC)
argal
Thank you very much for your prompt reply.
I will certainly give her a try.
Offline jcegido
#4 Posted : 07 January 2003 19:32:41(UTC)
jcegido
Another thing to do, as comented here before is, to use another oil than Märklin´s, that can be considered a little stiff.
Juan Carlos
Juan Carlos
#5 Posted : 08 January 2003 01:15:05(UTC)
In the good old days when I was a kid, Märklin oil was just plain sewing-machine oil repackaged and it worked very well for those old loks. Nowadays the locos are "finer" in gearing and Märklin also seems to have changed the oil "formula" during the late 80:s-early 90:s.. The new "formula" seems to dry up and become like glue if locos are not run... I had 2 "shelf-warmers" for service from the local hobby shop the other day where the motors were all locked up due to stiffened oil... A thorough cleaning and re-oiling with silicone oil and another oil made them run again... So now the shop owner can sell them... <img src=icon_smile_evil.gif border=0 align=middle>
Silicone oil is great but does not last so long, ordinary 10W-40 motor oil is also very ok to use as long as there are no plastic gears, as well as ordinary sewing-machine oil. I received a bottle of Teflon grease from LokShop today that I will also try to use on gears and such... But as Juan Carlos says, the Märklin oil is not what it used to be and will eventually turn into "glue"...
Maybe our Greek members can advise on what brands to use from the local hobby/hardware store... The thing to remember is that pure "mineral oil" can be harmful to plastic gears. A synthetic motor oil is much better in this case (and cheaper)...
The US guys usually recommend "LaBelle 108", but I haven't seen it available in the EU yet...
Offline steamfriend
#6 Posted : 08 January 2003 02:18:45(UTC)
steamfriend
I'm not an oil expert, but I have always used either sewing machine oil or SAE 20 grade motor oil. I used my machines intensively between 1968 and 1975, then stopped until 2001. 'Off the shelf' operation (after 25 or more years) usually went well, and only a bit of fresh oil sufficed to get them going as smooth as they used to long time ago. I never had sticking parts... so this discussion is quite new to me. <img src=icon_smile_wink.gif border=0 align=middle>
Bob
Offline john
#7 Posted : 08 January 2003 08:47:45(UTC)
john
You can also try oil from Faller.Is very very good.
Offline argal
#8 Posted : 08 January 2003 09:28:12(UTC)
argal
Thank you all for your input.
I tried oiling the motor gear axles, albeit with Marklin oil and it worked much better, but I keep your advice for cleaning and trying the different types of oil you have mentioned.
thanks again
Offline Thanos
#9 Posted : 08 January 2003 13:33:35(UTC)
Thanos
Dear all,
When I asked the Marklin guru, Kevin, when should I add oil to the locomotives he replied: "When she starts to get noisy and cranky!
When they are not running right(sluggish,more motor noise) then add 1 drop of oil to the two points of the motor Marklin suggests"!
That is the only way to avoid overoiling and it is a rule I am following ever since. I am using Faller oil exclusively and I am satisfied.
Thanos
Thanos
Offline jcegido
#10 Posted : 08 January 2003 16:15:15(UTC)
jcegido
I bought yesterday two diferent oils in my usual dealer, one teflon based and another one "ultra fine". I´ll try both of then and will write comments here. Anyone of you has tried teflon based oil before?
Juan Carlos
Juan Carlos
Offline steamfriend
#11 Posted : 08 January 2003 22:25:36(UTC)
steamfriend
No Juan Carlos, I did not and probably will not. Teflon is a strong, even hard material, which comes suspended in a liquid for lubrication purposes (usually for plastics). The idea alone gives me the creep (if this is the right English expression) : possible clotting danger if the suspension liquid dries out. Tell us how it REALLY works <img src=icon_smile_big.gif border=0 align=middle>
Bob
#12 Posted : 08 January 2003 22:53:16(UTC)
Well, the teflon is supposed to "adhere" to the cogwheels and give them a "slick" surface with less friction but who knows how it really performs in the long run... My "teflon" is Faller oil with a teflon additive in it... Let's see how it works... <img src=icon_smile_wink.gif border=0 align=middle>
Others on Märklin mailing lists have reported good experiences with teflon grease in the cogwheel mechanism, at least as far as I have read...
Offline Philippe Danjou
#13 Posted : 09 January 2003 01:33:58(UTC)
Philippe Danjou
Hello, I am a collector of older Marklin engines (series 800 & 3000) which I buy second hand at swap meets.It is rather often that they whave not not running for many years and that the engine appears "glued". You see that when the headlights work well but the engine does not move or very hardly when applying high voltage.Dont worry when it is the case,you can always solve the problem yourself even without totally dismantling the motor, which is not an operation I would recommend for a beginner.
You can first try to take out the body, apply some oil on the bearings and rotating parts as explained in the forum, then using a soft piece of wood (like a tooth pick) try to gently rotate the rotor through the holes of the stator. It will normally start moving progressively and more & more easily. Do never force too hard otherwise you will damage the rotor wiring. After some time of such hand rotation, put it back on tracks and it should begin to move by itself better and better. It will need some time to get back to perfect working condition, but it usually does happen - at least it worked with me.
If the rotor refuses to rotate by hand, then dismantling and thorough cleaning will be needed.
phil
phil
Offline jcegido
#14 Posted : 09 January 2003 01:45:46(UTC)
jcegido
The two lubricants I bought yesterday are from Woodland Scenics. The one with teflon (HL-652) is not for the loco motors, it´s for turn-outs. The other one, (HL-655 Gear lube) is suposed to be useful for "power transmission gears and loco crossheads". Anyone of you have tried them before? Comments are wellcome.
Juan Carlos
Juan Carlos
Offline tayloma
#15 Posted : 09 January 2003 09:12:17(UTC)
tayloma
Hi all
In South Africa we get a household oil called Q-All-in-One which is for sewing/kniting machines, etc., and I have found it to be very good. I still however find that the motor "bearings" get dry.
I have the 460 Swiss Lok from the Swiss start set and i found it rather noisy. I have tried all sorts of lubrication, but the above oil has sorted this Lok out. It now runs with a gentle hum.
Mark
#16 Posted : 09 January 2003 11:29:14(UTC)
It's definately a slippery jungle out there with different lubricants... For those interested, there is an article called "Loco lubrication primer" by Stephan-Alexander Heyn on the site. It's under "Models & modeling" -&gt; "Service & such".
Guest (10)
Z S 3/6 Locomotive troubleshooting (Small scale)
by Trogbahnen 07/03/2021 19:10:19(UTC)
This page was generated in 0.444 seconds.
