Offline grae
#1 Posted : 20 March 2002 18:46:08(UTC)
grae
Hi,Can you run LGB locos and rolling stock on Marklin gauge1 track
Offline KLB
#2 Posted : 21 March 2002 15:17:30(UTC)
KLB
LGB is G gauge and Märklin is Gauge 1.
I have seen Märklin loks,etc., run on LGB track,so It should work the other way around ;-)
Kevin!
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline perz
#3 Posted : 27 November 2002 18:44:41(UTC)
perz
G gauge and 1 gauge are the same, both are 45 mm. But G scale and 1 scale are not the same. G scale is 1:22.5 and 1 scale is 1:32. The size (height) of the rails is much different between the two. To run equipment on a higher rail than it is intended for is usually no problem (thus, Märklin runs on LGB track). The other way around could be a problem, but I don't know.
Offline 7gauges
#4 Posted : 10 December 2002 04:07:50(UTC)
7gauges
Actually there is no such thing as "G gauge or G scale". This is simply a manufacturers term.
More correctly the LGB stuff is referred to as 2m or IIm at a scale of 1:22.5. Number 2 scale has a gauge of 64mm.
Offline henk 2002
#5 Posted : 11 December 2002 11:58:22(UTC)
henk 2002
i drive with the trains in a mumuseum
http://www.modelspoormuseum.nl
you can drive with marklin on lgb rails
you can drive with marklin on lgb switch rigt away
some time's vou cannot drive with marklin on a lgb switch
to the left or the right
you CANNOT drive with lgb on marklin!!!!!!!!!!!!!!!!!!
goodbay from holland nederland henk
male
male
This page was generated in 0.214 seconds.
