Offline MärCo
#1 Posted : 24 May 2008 16:49:31(UTC)
MärCo
Little turntable for Trix C tracks
I have noted on this forum that some members are using Trix C tracks, thus I might publish this here as well.
Accesoiries for Trix C tracks are limited and other items like diamond crossing are not made (yet) for Trix C tracks.
This turntable can be made by yourself, although it need a little work.
For this little turntable you need:
— Fleischmann 6050 manual operated turntable.
— Trix 62951 adapter track (at least 4).
— Roco 42612 fishplates (for code 83/100 rails).
1) Remove the turntable connection, it is simply clicked on the turntable.
2) Remove the fishplate from the turntable connection. Fleischmann rails is code 100.
3) Roco 42612 fishplates can connect code 83 with code 100 rails. The fishplate has 2 sides, low for code 100 rails and high for code 83 rails. The side for code 83 rails has to be made a little shorter or it will not fit onto the Trix C Tracks.
4) Connect Trix 62951 with the turntable connection using the modified Roco 42612 fishplates.
5) Fit this combination onto the Fleischmann turntable.
The Fleischmann 6050 turntable comes with an engine shed. It is made of cardboard, but you might replace it by a Faller or Kibri example.
And last but not least, you can buy Fleischmann 6051 turntable connectors. With this set you can add 4 extra connections to the turntable.
Absolutly AFB-NOHAB fan ;-)
Offline mmervine
#2 Posted : 24 May 2008 20:06:16(UTC)
mmervine
MärCo:
Nice work. One suggestion...use a Dremel to shorten the rails to close the gap between the turntable and the C-track.
r/mark
Offline MärCo
#3 Posted : 24 May 2008 20:29:48(UTC)
MärCo
Thanks.
I still did puzzle how to solve that.
Offline spitzenklasse
#4 Posted : 24 May 2008 20:39:12(UTC)
spitzenklasse
I see two wires. How is it motorised?
Offline MärCo
#5 Posted : 24 May 2008 20:41:35(UTC)
MärCo
The bridge is manual operated. The 2 wires are used to feed the rails with current, or else you can't drive on or off.
Offline TTRExpress
#6 Posted : 28 May 2008 04:22:16(UTC)
TTRExpress
Hi Marco,
Nice work. That is a nice turntable for branch-line or secondary line service areas. I have converted 2 Fleischmann regular 310 mm turntables for TRIX Express 3-rail operation, one older Model 1780 and the newer 6652 which is I believe identical to the Maerklin 7286. I may just have to buy myself a couple of 6050's!!
You could most likely motorize the turntable with an Atlas 12 Volt D.C. motor that is used to convert their manual turntable.
#7 Posted : 29 May 2008 00:58:36(UTC)
1 - Does the manual turning easily "lock/notch" into the exit track positions for accuracy?
2 - It needs paint/weathering... wink
#8 Posted : 29 May 2008 01:22:21(UTC)
But it's cute, especially with the little one on it [:p] - congratulations, Märco !
Offline kbvrod
#9 Posted : 29 May 2008 06:19:07(UTC)
kbvrod
hi all,
<br />1 - Does the manual turning easily "lock/notch" into the exit track positions for accuracy?
no way of telling,but it should,....
CoolAgreed!biggrin
Dr Dirt
Offline Zora la rousse
#10 Posted : 15 June 2008 00:12:19(UTC)
Zora la rousse
This turntable is sold with a cardboard kit for a engine shed. And guess who did plundered the box for it wink ?
The quality of the cardboard is very good, as is the printing. The engine shed is simply to assemble.
I could only find 3 minor points:
1) The doors are not printed on the inside, nor is something provided to glue inside of the doors. So, when the doors are open, you are looking at plain cardboard.
2) The engine shed is quite low. My steamlocomotive does fit, but the old electric locomotive does not.
3) The windows are printed on the cardboard. You can't look through them.
I have solved the last problem, by cutting out all the windows. That are 27 on each side, 54 in total. And to be honest, it took me more time than I thought. But it is well worth the effort. I glued transparent plastic on the inside. As you can see on this picture, you can actually see what is inside the engine shed.
So now this engine shed is part of my layout biggrin !
Offline ulf999
#11 Posted : 15 June 2008 15:00:06(UTC)
ulf999
@M&auml;rco:Nice work
@Zora : That engine house sure looks nice!
Offline MärCo
#12 Posted : 15 June 2008 15:26:02(UTC)
MärCo
1) Yes, it clicks nice in position. I wish Fleischmann would make this for Märklin C tracks as well.
2) Sorry, I am not so good with painting. But it certainly would look like if the turntable is daily used.
Offline kbvrod
#13 Posted : 15 June 2008 18:54:36(UTC)
kbvrod
Hi Märco,all,
[size=1" face="Verdana" id="quote]quote:Originally posted by MärCo
Well,we could adapt it for C-track,...
Ah,but weathering,that you <u>can do!</u>Cool
Dr Dirt(at your service,but not around the corner,...[B)])
This page was generated in 0.465 seconds.
