al_pignolo Offline
#1 Posted : 26 April 2009 21:16:43(UTC)
al_pignolo
Hi all.
I digitalized a 34761 diesel train with the 60760 kit (decoder + 5-pole rotor). The motor and the decoder work good but, when the pickup shoe lacks the contact for some reason (i.e. in turnouts), the motor stops and restarts accelerating from zero, even if the speed was high. This makes the train running very bad, as you can imagine... [:(]
None of my other decoders behave like that. Is this the "alzheimer" problem? What can I do? In the instructions I read that this decoder has only a few of programmable CVs: accelerating and braking delay, maximum speed and loco address.
Someone has tips?
Thank you
Pietro
Webmaster Offline
#2 Posted : 26 April 2009 21:30:09(UTC)
There is an "Alzheimer solution" for this decoder, using a resistor and a capacitor...
See http://decoder.x-train.d...ecoder/digipic/60760.php
Also other modifying tips are on that page...
al_pignolo Offline
#3 Posted : 26 April 2009 21:39:47(UTC)
al_pignolo
Great! Easy to solve (why M* doesn't modify the decoder in the factory?)
And also the other upgrades are useful. Thanks Smile
Pietro
intruder Offline
#4 Posted : 16 April 2011 12:15:30(UTC)
Has anybody in the forum testet the resistor and capacitor solution?
I have, and I am not very happy with it.
From the hint in the x-train site, I read that the capacitor should be from 470 to 1.000 microfarad, and the resistor 10kOhm.
I thought that a big capacitor would store a lot of back-up power, so I used a 1.000uF 6,3V capasitor, and a 10kOhm resistor.
The wiring diagram:
Frankly, I think that it doesn't help at all. Mabye the charging time becomers to long, so a smaller resistor should be used?
My test locomotive is a 3044, where I allready have cleaned the wheels, axels and axel bushings, and reduced the number of traction tyres to one.
It has a new pick-up shoe.
Maybe the best solution is to wait for the new mLD decoder 60942 or 60962 from Märklin. I think the price is quite good.
Suggestions, anyone?
Edited by user 16 April 2011 13:01:06(UTC)  | Reason: Not specified
Best regards Svein
member of MFDWPL for some more months
www.saebonet.com
 1 user thanked intruder for this useful post.
H0 Offline
#5 Posted : 16 April 2011 14:59:58(UTC)
I haven't tried it.
The capacitor is an "Anti Alzheimer" measure to prevent the loco from starting at speed step 0 and accelerating slowly with ABD whenever it finds a tiny bit of dirt on the rails.
It only buffers the "brain", but doesn't supply power to the motor.
A capacitor that supplies motor power would require a different wiring (diode plus resistor) and would be a different type (35 V for digital operation only). And you'd need 2,200 µF or more to see an effect.
Suaviter in modo, fortiter in re
efel Offline
#6 Posted : 16 April 2011 20:07:53(UTC)
efel
The wiring diagram:
Hi svein,
I don't know the 60760 decoder, but I can tell what I made on my loksound 3.5 to avoid alzheimer.
I used a 47000uF 6V "gold cap" (small size in spite of its large value). In order to protect the decoder, I included a 220 Ohm series resistor, that limits the load current. A shotky diode is connected in parallel with that resistor, to supply the decoder with a small drop voltage when necessary.
The connections are as follows, on the 21 pins connector
-Gold cap: "-" wire to Pin 20; "+"wire to the 220 Ohm resistor.
-220 Ohm resistor between "+" wire of the cap and Pin 12
-shotky diode in parallel to the resistor; cathode to Pin 12 and anode to the "+" of the cap.
Alzheimer has completly disappeared.
Fred
GSRR Offline
#7 Posted : 16 April 2011 21:02:28(UTC)
GSRR
Is the new ESU 4.0 decoder with the battery backup, in part a fix for this sort of issue?
Have a look at these threads, may be informative.
http://www.marklin-users...g-a-330uF-capacitor.aspx
http://www.marklin-users...g-a-2nd-pickup-shoe.aspx
http://www.marklin-users...ly-at-higher-speeds.aspx
r/Thomas
ETE-ENE ECoS iTrain TouchCab C-Gleis German Era Id & IIIb USA Era IIIb SBB Era III SJ Era IV GC Era V
Bigdaddynz Offline
#8 Posted : 16 April 2011 22:33:28(UTC)
That's how ESU seem to be portraying them.
intruder Offline
#9 Posted : 19 April 2011 21:05:05(UTC)
Based on the some information here (thanks, Fred!), I will first of all try a smaller resistor.
Best regards Svein
www.saebonet.com
scraigen Offline
#10 Posted : 03 April 2012 15:33:02(UTC)
scraigen
Hi, does anyone know where the excellent x-train info now resides? I'm having a lot of difficulty finding the extremely useful info that used to be there. eg http://decoder.x-train.d...ecoder/digipic/60760.php now is a 404.
I'm trying to find the layout of the 60760 board so that I can locate the pin's referred to above for the Alzheimer's solution.
Photo of 60760...
but which solder pads are the ones referred to above? the description implies that + is orange whereas the board has clear + signs in the corner next to where the yellow wire connects, there is a spare solder pad in the middle next to the orange wire and there are also 5 solder pads on the opposite side of the board - any ideas anyone?
Stu
Edited by user 03 April 2012 16:41:50(UTC)  | Reason: Not specified
Marklin - Sheffield S6 - Snooker table plus modest Marklin layout or no snooker table and HUGE layout??????
scraigen Offline
#11 Posted : 03 April 2012 20:19:13(UTC)
scraigen
Hi, found my answers here Modify a 60760 decoder.
I tried a 10,000 uF capacitor and a 5K resistor
+ solder pad (furthest in on the batch of 5) to resistor
resistor to the + of the capacitor
- of the capacitor onto the - solder pad (nearest to the edge in the group of 5).
The capacitor is huge so good job its a tender loco.
Seems to work, but then the track is pretty clean and as always with these things now that I've come to modify it it didn't seem that bad in the test run before the mod.
Loc is still running both in analog and digital so hopefully all good.
Stu
Webmaster Offline
#12 Posted : 03 April 2012 20:24:18(UTC)
I have most of the x-train content and can provide pdf views of pages...
File Attachment(s):
60760.pdf (580kb) downloaded 107 time(s).
 2 users thanked Webmaster for this useful post.
pa-pauls Offline
#13 Posted : 05 April 2012 19:57:45(UTC)
pa-pauls
Well, Reinhard Bobzin, the man behind X-train died last january,,,
Pål Paulsen
Märklin Digital, DB and SBB Era III
franciscohg Online
#14 Posted : 06 April 2012 22:50:51(UTC)
franciscohg
Chile
Sad news.........
the site was excellent, even if you dont know much german.....like me :)
Bedroom layout building in progres....
Olav Offline
#15 Posted : 08 April 2012 17:29:36(UTC)
Olav
Are you entittled to "publish" the content somewhere?
Olav
franciscohg Online
#16 Posted : 09 April 2012 00:09:32(UTC)
franciscohg
Chile
Olav
of send it by email?
intruder Offline
#17 Posted : 16 July 2012 23:28:17(UTC)
I have done some more testing with the 60760 decoder installed in my 3044.
Initially I used a 1000 uF capacitor. With the 10 Kohm resisitor, the charging time seemed to be too long.
Later I changed to a 470 uF capacitor, still using a 10 Kohm resisitor.
The new wiring diagram:
A photo of the decoder, with the black and purple wires to the capacitor and resitor unit:
A home made "Anti-Alzheiner" circuit board in the locomotive:
I am satisfied with this capacitor and resistor combination.
Best regards Svein
www.saebonet.com
This page was generated in 0.907 seconds.
Map
See the web site statistics
Bookmark and Share
