Offline al_pignolo
#1 Posted : 26 April 2009 23:16:43(UTC)
al_pignolo
You have been a member since:: 30/09/2005(UTC)
Hi all.
I digitalized a 34761 diesel train with the 60760 kit (decoder + 5-pole rotor). The motor and the decoder work good but, when the pickup shoe lacks the contact for some reason (i.e. in turnouts), the motor stops and restarts accelerating from zero, even if the speed was high. This makes the train running very bad, as you can imagine... [:(]
None of my other decoders behave like that. Is this the "alzheimer" problem? What can I do? In the instructions I read that this decoder has only a few of programmable CVs: accelerating and braking delay, maximum speed and loco address.
Someone has tips?
Thank you
Pietro
#2 Posted : 26 April 2009 23:30:09(UTC)
There is an "Alzheimer solution" for this decoder, using a resistor and a capacitor...
See http://decoder.x-train.d...ecoder/digipic/60760.php
Also other modifying tips are on that page...
Offline al_pignolo
#3 Posted : 26 April 2009 23:39:47(UTC)
al_pignolo
Great! Easy to solve (why M* doesn't modify the decoder in the factory?)
And also the other upgrades are useful. Thanks Smile
Pietro
#4 Posted : 16 April 2011 14:15:30(UTC)
Has anybody in the forum testet the resistor and capacitor solution?
I have, and I am not very happy with it.
From the hint in the x-train site, I read that the capacitor should be from 470 to 1.000 microfarad, and the resistor 10kOhm.
I thought that a big capacitor would store a lot of back-up power, so I used a 1.000uF 6,3V capasitor, and a 10kOhm resistor.
The wiring diagram:
Frankly, I think that it doesn't help at all. Mabye the charging time becomers to long, so a smaller resistor should be used?
My test locomotive is a 3044, where I allready have cleaned the wheels, axels and axel bushings, and reduced the number of traction tyres to one.
It has a new pick-up shoe.
Maybe the best solution is to wait for the new mLD decoder 60942 or 60962 from Märklin. I think the price is quite good.
Suggestions, anyone?
Edited by moderator 24 September 2018 01:15:20(UTC)  | Reason: Realigned the link to the new home of Intruder's site
#5 Posted : 16 April 2011 16:59:58(UTC)
I haven't tried it.
The capacitor is an "Anti Alzheimer" measure to prevent the loco from starting at speed step 0 and accelerating slowly with ABD whenever it finds a tiny bit of dirt on the rails.
It only buffers the "brain", but doesn't supply power to the motor.
A capacitor that supplies motor power would require a different wiring (diode plus resistor) and would be a different type (35 V for digital operation only). And you'd need 2,200 µF or more to see an effect.
Offline efel
#6 Posted : 16 April 2011 22:07:53(UTC)
efel
The wiring diagram:
Hi svein,
I don't know the 60760 decoder, but I can tell what I made on my loksound 3.5 to avoid alzheimer.
I used a 47000uF 6V "gold cap" (small size in spite of its large value). In order to protect the decoder, I included a 220 Ohm series resistor, that limits the load current. A shotky diode is connected in parallel with that resistor, to supply the decoder with a small drop voltage when necessary.
The connections are as follows, on the 21 pins connector
-Gold cap: "-" wire to Pin 20; "+"wire to the 220 Ohm resistor.
-220 Ohm resistor between "+" wire of the cap and Pin 12
-shotky diode in parallel to the resistor; cathode to Pin 12 and anode to the "+" of the cap.
Alzheimer has completly disappeared.
Fred
thanks 1 user liked this useful post by efel
Offline GSRR
#7 Posted : 16 April 2011 23:02:28(UTC)
GSRR
Is the new ESU 4.0 decoder with the battery backup, in part a fix for this sort of issue?
Have a look at these threads, may be informative.
https://www.marklin-user...g-a-330uF-capacitor.aspx
https://www.marklin-user...g-a-2nd-pickup-shoe.aspx
https://www.marklin-user...ly-at-higher-speeds.aspx
r/Thomas
#8 Posted : 17 April 2011 00:33:28(UTC)
That's how ESU seem to be portraying them.
#9 Posted : 19 April 2011 23:05:05(UTC)
Based on the some information here (thanks, Fred!), I will first of all try a smaller resistor.
Offline scraigen
#10 Posted : 03 April 2012 17:33:02(UTC)
scraigen
Hi, does anyone know where the excellent x-train info now resides? I'm having a lot of difficulty finding the extremely useful info that used to be there. eg http://decoder.x-train.d...ecoder/digipic/60760.php now is a 404.
I'm trying to find the layout of the 60760 board so that I can locate the pin's referred to above for the Alzheimer's solution.
Photo of 60760...
but which solder pads are the ones referred to above? the description implies that + is orange whereas the board has clear + signs in the corner next to where the yellow wire connects, there is a spare solder pad in the middle next to the orange wire and there are also 5 solder pads on the opposite side of the board - any ideas anyone?
Stu
Must build something
Offline scraigen
#11 Posted : 03 April 2012 22:19:13(UTC)
scraigen
Hi, found my answers here Modify a 60760 decoder.
I tried a 10,000 uF capacitor and a 5K resistor
+ solder pad (furthest in on the batch of 5) to resistor
resistor to the + of the capacitor
- of the capacitor onto the - solder pad (nearest to the edge in the group of 5).
The capacitor is huge so good job its a tender loco.
Seems to work, but then the track is pretty clean and as always with these things now that I've come to modify it it didn't seem that bad in the test run before the mod.
Loc is still running both in analog and digital so hopefully all good.
Stu
#12 Posted : 03 April 2012 22:24:18(UTC)
I have most of the x-train content and can provide pdf views of pages...
File Attachment(s):
60760.pdf (580kb) downloaded 535 time(s).
Offline pa-pauls
#13 Posted : 05 April 2012 21:57:45(UTC)
pa-pauls
Well, Reinhard Bobzin, the man behind X-train died last january,,,
Pål Paulsen
thanks 1 user liked this useful post by pa-pauls
Offline franciscohg
#14 Posted : 07 April 2012 00:50:51(UTC)
franciscohg
Chile
Sad news.........
the site was excellent, even if you dont know much german.....like me :)
Offline Olav
#15 Posted : 08 April 2012 19:29:36(UTC)
Olav
Are you entittled to "publish" the content somewhere?
Olav
Offline franciscohg
#16 Posted : 09 April 2012 02:09:32(UTC)
franciscohg
Chile
Olav
of send it by email?
#17 Posted : 17 July 2012 01:28:17(UTC)
I have done some more testing with the 60760 decoder installed in my 3044.
Initially I used a 1000 uF capacitor. With the 10 Kohm resisitor, the charging time seemed to be too long.
Later I changed to a 470 uF capacitor, still using a 10 Kohm resisitor.
The new wiring diagram:
A photo of the decoder, with the black and purple wires to the capacitor and resitor unit:
A home made "Anti-Alzheiner" circuit board in the locomotive:
I am satisfied with this capacitor and resistor combination.
Edited by moderator 24 September 2018 01:31:27(UTC)  | Reason: Realigned the image link/s to the new home of Intruder's site
thanks 3 users liked this useful post by intruder
#18 Posted : 16 September 2017 09:29:25(UTC)
Hello again Märklineers,
A long time ago I converted this old treasured 3053 Wub :
to digital:
I am not sure which Märklin conversion set I used but I think it was 60904
It runs well but has the Alzheimers whenever it goes over a Märklin “switching track” RollEyes e.g. :
I put the problem on the “backburner”, understanding that it must relate to the decoder re-setting after a momentary loss of digital current/signal and wondering if a gadget similar to the ESU "Power pack" would help but did not know how to specifically fix it myself until coming across this thread recently.
Thus I was keen to correct the problem with an electrolytic capacitor and a resistor, however I cannot see any points to which I should connect them like in the description for 60760.
The decoder :
I would be grateful of any advice you may care to give me if anyone has any ideas.Smile
PJ
Offline French_Fabrice
#19 Posted : 16 September 2017 12:21:39(UTC)
French_Fabrice
Hello PJ,
Your decoder looks like an ESU lokpilotV4.
If it is the case, then download the english doc (edition 6) of LPV4 decoders at ESU web site, and look at chapter 6.10.2.
Be sure your decoder is a LPV4...
Note: soldering points for power pack are tiny, and you need a magnifier (or good eyes !) and a soldering iron with a fine tip... you also need to remove a small part of the protective sheath, in order to access the soldering points.
Good luck
Fabrice
PS: just re-read your post. You said "a long time ago", so it may not be a lpv4... lpv3.5, lpv3 ??? I've started to convert my own locos with lpv4 in 2011.
#20 Posted : 17 September 2017 05:37:05(UTC)
Hello PJ,
Good luck
Fabrice
Hi Fabrice,
Thank you for your kind information, I will look at the ESU website,
PJ
Offline einotuominen
#21 Posted : 20 January 2023 18:53:01(UTC)
einotuominen
An old thread, but since it covers the power for the decoder very well, I’d like to ask for powering the motor also.
So I still have a few locos with 60760 (those that are inside the ”shrink tube” sort of isolator cover. I’ve yet to open one up)
Anyways my slow speed yard operations are somewhat ruined because locos stop on some turnouts (threeway especially).
So does powering the motor differ in someway?
I’ve succesfully made 1-2 Farad powerpacks with 100 ohm resistor and a diod for mLD3 and mSD3.
I’d wish to add same kind to 60760, so are the connections different than for the alzheimers solution?
-Eino
#22 Posted : 20 January 2023 19:06:40(UTC)
The circuit shown here buffers the 5 V used by the processor chip to prevent memory loss (between black and violet).
Buffering motor power would occur between orange and violet and requires capacitors for a higher voltage.
It can't harm to add both capacitors (5 V and motor power).
I assume you mean 0.001 to 0.002 Farad.
#23 Posted : 20 January 2023 19:50:56(UTC)
einotuominen
So 25V to these purple and yellow connections right? That will power the motor. It of course won't do much if the decoder shuts down, so then I would need another powepack around 470uF of 5V that would connect minus to the black circle and plus again to the purple? Would the power pack that powers the decoder be built the same way as for motor? 100 ohm resistor and a diod?
That's what I wrote ;) sorry my bad. 1000-2000uF.
Thanks!
-Eino
Edit/Add
These decoders I have do not suffer the alzheimers though… I just want to get slow moving locos over bad spots.
#24 Posted : 20 January 2023 20:27:13(UTC)
Purple and orange.
I assume you will need 50 V capacitors if analogue operation shall be possible. 25 V or 35 V should be enough for digital only operation.
HGH also recommends 50 V:
https://moba-hgh.de/mode...maerklin-trix-power-pack
#25 Posted : 20 January 2023 21:23:51(UTC)
einotuominen
Purple and orange.
Yes, orange not yellow, sorry.
Is polarity correct, minus to the orange?
Only digital, no analog.
I’ll check that link.
Thank you for your help!
-Eino
#26 Posted : 20 January 2023 21:40:01(UTC)
Orange is plus and purple is minus, as shown in the diagram above.
#27 Posted : 20 January 2023 22:17:07(UTC)
einotuominen
Ah, plus of course to the common wire.
This page was generated in 1.475 seconds.
