6 Pages«<456
#251 Posted : 18 October 2023 02:14:18(UTC)
And a video about "Breemburg Hauptbahnhof" (= Big City Station on 1.35 sqm mentioned in the previous post #250):
Offline Jimmy Thompson
#252 Posted : 18 October 2023 11:44:41(UTC)
Jimmy Thompson
Your posts 250 and 351 reminds me of this from Faller Gleisbaupläne 840
p. s. as well as Post #201 on the previous page.
p. p. s. faller-ams.se link no longer works - removed references
Edited by user 06 November 2024 23:32:47(UTC)  | Reason: add postscript
Jimmy T
Analogue; M-track; BR 111; KLVM; Primex; Sarrasani Zirkuswelt
#253 Posted : 30 December 2023 22:15:17(UTC)
L-shape mind game on 2 x 2m with transition curves, maximum track elevation 18 cm, length of track 15.5 m
#254 Posted : 31 December 2023 05:53:40(UTC)
Hello Ak,
I like your last post #253, a very ingenious track plan indeed.
I may be missing something, but would it be possible to indicate the Zero elevation datum on that layout please?
Edit:
Don't worry I found it - the little markers alongside the track showing elevation - thank you.
I missed them until I clicked to enlarge the image.
#255 Posted : 31 December 2023 13:55:03(UTC)
Thank you Kimball. Even though you already detected the 0 elevation, I marked it in below image.The gradients can be chosen in such a way that they reinforce the impression of a mountain railway. The gradients could be harmonized and standardized at 3% to extend the 0 elevation range.
The absolute minimum in terms of elevation would be 8 cm height - see image below. Then there would also be room for crossovers to change the direction of travel. However, this would make the concept look less dramatic.
#256 Posted : 07 April 2024 11:52:11(UTC)
Two German brothers' H0 scale Model railroad under a billiard table
Photos with English narrative:
https://www.noch.com/new...nder-the-billiard-table/
Video:
#257 Posted : 03 August 2024 16:46:29(UTC)
Dunno if I shared this before - one of my favourite designs:
Description:
"By eliminating virtually all trackage except a winding double-track main line, Robb Thomas, from Walkerton, Indiana USA, has managed to squeeze both a credible country scene and a bustling port metropolis into a 5x3ft (150x90cm) baseboard. The port is located in eastern Ohio on Lake Erie, and the countryside represents an Appalachian valley in Pennsylvania. A diagonal backdrop separates the two scenes on this N scale railroad."
Source with some photographs (scroll down) in this 2007 publication:
https://www.carendt.com/...special-mid-month-issue/
Offline rbw993
#258 Posted : 04 August 2024 13:30:41(UTC)
rbw993
Was this an inspiration for Density or just "great minds think alike"?
#259 Posted : 04 August 2024 13:48:20(UTC)
Well, I cannot speak for anybody else, but I consider myself a genius in my own mind.
Wink
#260 Posted : 04 August 2024 14:00:38(UTC)
Above N scale design transferred to H0 scale:
A ruling grade of 3% is feasible on an area of 4 x 8 feet (ca. 1.2 x 2.4 m) as well as a depressed harbor basin. Between the scenic divider and the harbor basin there is still space for sidings on the top level. Each loop measures 10 m in length, so 20 m track length in total. Theoretically, the footprint can be reduced to 1 x 2 m, but then there is no room for the harbor basin or rail curve easements.
Offline hermanvk
#261 Posted : 04 August 2024 15:53:25(UTC)
hermanvk
Amazing actually, that I also own the same four locs... even the set AND the panorama car..ThumpUp
Both electric ones.
I just learned how to have trains (same two of the video ) running on catenary..ThumpUp
thanks 6 users liked this useful post by hermanvk
Offline hermanvk
#262 Posted : 04 August 2024 17:32:12(UTC)
hermanvk
Both electric ones.
red_3021_img_2364.jpgred_3016_4018_img_2367.jpgred_3054_img_2360.jpgred_3036_img_2362.jpg
thanks 4 users liked this useful post by hermanvk
#263 Posted : 06 August 2024 19:13:35(UTC)
Please note that this is the track plan forum.
Hence another twisted "dogbone" track plan on a 186 x 106 cm footprint:
With a limited supply of land and at the same time high demand for MRR space, the only option is to go up.
R1 curves are preferably hidden in tunnels, ruling grade is 3%, total track length just under 20 m, height difference from bottom to top is 24 cm.
Offline rbw993
#264 Posted : 07 August 2024 02:31:11(UTC)
rbw993
Why stop here? How up can you go? Sorry, I've been drinking Cava with dinner.
Roger
thanks 3 users liked this useful post by rbw993
#265 Posted : 15 August 2024 20:05:24(UTC)
Well, one could cave in to reach four levels equalling an elevation of 32 cm on a 100 x 170 cm surface (when accepting a ruling grade of 4% and and the omitting of subtleties such as transition curves).Unsure
The lower return loop is inverted.
A valley with bridges would be ideal here, with scenery obscuring some trackage in the rear.
#266 Posted : 29 November 2024 19:41:03(UTC)
This NMRA description of a basic freight classification yard caught my attention. Amalgamating the NMRA scheme ...
... with an earlier twisted dogbone concept ...
... I came up with this 4x8 ft idea:
The proximity of a big city serves as a pretext for the dense trackwork and operations of various trains. For ease of operation and minimal fouling of the mainline, the yard operates in a one-way mode. Assuming that the small classification yard is located between two larger ones (yard A and yard B) explains this arrangement: Trains originate from the distant yard A and are then hauled to the distant yard B. Freight destined to yard A is turned around - out of sight - in yard B.
The layout allows to break up a long US type freight train and serve various industries, while a passenger train could serve a suburban station (the upper deck trackage is open for interpretation and adjustments). A round trip for a train traveling the entire dogbone route measures 20 m and the arrival/departure ("A/D") track can hold a 4 m long freight train. A yard switcher can be parked on the yard lead tail track. With right-hand traffic, the uphill gradients are 3% steep and downhill slopes up to 4%
Edited by user 30 November 2024 10:11:49(UTC)  | Reason: Not specified
Offline rbw993
#267 Posted : 01 December 2024 14:27:15(UTC)
rbw993
The world wants to know - are you going to build it?
Roger
thanks 4 users liked this useful post by rbw993
Offline Willem99
#268 Posted : 01 December 2024 15:05:16(UTC)
Willem99
Never in the history of Marklin have I seen so many tracks on such a small space with so few houses.
Or something like that.
Tim
thanks 4 users liked this useful post by Willem99
#269 Posted : 02 December 2024 15:33:35(UTC)
Roger
This can happen. It all depends on whether and how I manage to adapt the MRR collection to my hybrid living situation, namely whether I manage to transport the ATSF rolling stock and excess track inventory across several national borders. The aforementioned design would be suitable for ATSF, inspired by e.g. suburban Kansas City, Oklahoma City or Illinois City, I mean Chicago.
Offline rbw993
#270 Posted : 02 December 2024 23:16:03(UTC)
rbw993
I am looking forward to seeing it...If it happens.
#271 Posted : 10 January 2025 18:25:39(UTC)
For entertainment purposes, industrial switching on a simpler basis in the meantime (195 x 95 cm), curvy but no S-curves.
Offline rbw993
#272 Posted : 10 January 2025 18:30:05(UTC)
rbw993
Looks like what happened to my glasses once AK! I like how you worked that extra crossing in there. It makes use of an otherwise empty circle.
Roger
6 Pages«<456
This page was generated in 1.059 seconds.
