Offline monster134
#1 Posted : 27 January 2013 19:42:13(UTC)
monster134
Hi guys,
I recently purchased a 60215 CS2. I am going to throw it. Not long from now. It works fine, but just now my LUX vacuumcleaner derailed on a switch and shorted. The CS2 switched off completely, and then, after rebooting, froze up. Am I missing something? A setting somewhere maybe?
Safe it's life. I have a terrible temper. It will fly to a wall.
Thank you.
#2 Posted : 27 January 2013 19:45:59(UTC)
Wait with throwing it against the wall until you've got some more answers...
Let it rest for a while, and meanwhile check if the Lux derailment did not cause some kinda permanent short on the rails first...
My 60215 has survived shorts by a faulty decoder/wiring and still boots up normally...
Offline monster134
#3 Posted : 27 January 2013 19:59:41(UTC)
monster134
I got it two weeks ago. It has been doing this from the start. If you short something, it switches off and reboots. And that takes time. Now, it just froze.
#4 Posted : 27 January 2013 20:03:39(UTC)
Well, my 60215 just reports a "short on track" and does not freeze/reboot at all... Confused Confused Confused
Offline monster134
#5 Posted : 27 January 2013 20:16:42(UTC)
monster134
Now it says "there is no track protocol for this unit. You cannot run locomotives or accessories. Now what?
#6 Posted : 27 January 2013 20:38:20(UTC)
I heard similar stories a few times now. It seems the power supply switches off faster than the CS2.
Check you configured the correct power supply in the CS2 settings.
Could be a faulty power supply. If the problem persists with the correct power source setting, contact your dealer or Märklin.
Offline monster134
#7 Posted : 27 January 2013 21:28:46(UTC)
monster134
Where do you get the setting screen for the power supply?
Offline NZMarklinist
#8 Posted : 27 January 2013 22:40:48(UTC)
NZMarklinist
This sort of problem Blink is one of the reasons I will be powering my layout thru boosters, and only having the points, signals, Turntable maybe, and other accessories directly connected to the CS, obviously thru their respective decoders. Wink Smile
Sorry thats no help to monster, but when your CS is sorted you should consider boosters, you obviously have a reasonable layout if your using the lux machine Huh
Talking about power supply settings, which of the switched mode power supplies, are you using monster ?
I have a CS1, but I believe with the CS2 you go to settings, then press on the spanner, and then probably look for "power supply or something relative, to set the CS2 to the one you have. Perhaps Juhan will know the correct steps ? Smile
Glen
Auckland NZ
Offline jeehring
#9 Posted : 27 January 2013 23:44:00(UTC)
jeehring
Originally Posted by: monster134 Go to Quoted Post
Hi guys,
Thank you.
as you bought then installed your new CS2, have you replaced any cables on your layout ?... some part of the wiring ?....the whole wiring ?
Offline monster134
#10 Posted : 28 January 2013 07:09:35(UTC)
monster134
Hi guys,
Thank you.
Nope, the only wiring I changed was from the CS2 to the track. Checked that out first, and all is fine. I will redo that bit tonight, and see what is up. I updated the CS2 to the newest software last night without any troubles. It still gives me the 'no track protocol' message.
Piece of shit. My 60212 ran here for seven years and never skipped a beat. I have sadly sold that. But if this carries on, I will buy something else.
Offline tulit
#11 Posted : 29 January 2013 02:33:18(UTC)
tulit
Views messages in topic : 400
Hi guys,
Thank you.
See this thread : https://www.marklin-user...stst23537_CS-2-Dead.aspx
It's likely shot and needs to go back into Marklin.
If you were having the CS2 reboot everytime you had a short, either the power supply wasn't working correctly (which one are you using?) or you had the wrong power supply selected. The CS2 should current limit before the power supply does, thus preventing it from rebooting.
#12 Posted : 29 January 2013 03:39:52(UTC)
It's one of the settings in the CS2 setup tab, but I can't remember which one. You should see either 60061 or 60100 depending on which power supply you have.
Offline jeehring
#13 Posted : 29 January 2013 11:08:24(UTC)
jeehring
Hi guys,
Thank you.
Nope, the only wiring I changed was from the CS2 to the track. (...)...
maybe you should have done it ...Confused ...
You should have replace the cables or parts of the wiring , mainly on the track feeder ....
CS 60212 = 3 amps
CS 60215 = 5 amps
With 60215 it is mandatory to have sufficiently thick cables, otherwise you may have problems in case of short .I'm not good enough into electronics, to know at which degree the electrical power of the power device has an influence, all I know is that on the CS2 it is installed behind a 5 amps booster.
have you bought a new power supply ?
If the cross section of the feeder is not wide enough, the switch off of the CS is not going fast enough and vital organs of the devices can be affected/destroyed.....May be this could explain why a power supply switched off before the CS...( depending on internal architecture and sensitivity of both devices...)
#14 Posted : 29 January 2013 11:37:50(UTC)
CS 60212 = 3 amps
CS 60215 = 5 amps
Not with a 60 VA power supply or a 60 VA transformer (only 3 A output, no new wires required).
Offline jeehring
#15 Posted : 29 January 2013 12:26:55(UTC)
jeehring
CS 60212 = 3 amps
CS 60215 = 5 amps
...pfff..Bored... .
monster 134 didn't tell which power supply is installed, nor if he bought a new one or not....
Marklin 60215 CS2 problem (Digital)
by daimonion 15/02/2015 14:58:59(UTC)
This page was generated in 0.804 seconds.
