#1 Posted : 08 June 2009 12:23:24(UTC)
I thought that I would provide some typical Swiss Train consists using Maerklin and other models available on the market.
MA=Maerklin
RO=Roco
LI=Lima
LP=Liliput
RT=RailTop
HA=Hag
TR=Trix
Typical Light Pendelzug as found on the Gotthard and other routes in the 1980s:
MA39421-MA43401-MA43370-MA43370*-MA43410
* For alternate coach numbers, you can use the matching Trix coach or one from the 26534 Set.
Typical EC 1990s-today (Zuerich-Munich):
MA37345-MA4266-MA4368-MA42173-MA4369-MA4369-MA4369
or
MA37345-RO44669-RO44771-RO44962-RO44770-RO44770-RO44770
1960s/70s Gotthard Schnellzug
MA37366**-MA43401-MA43361-MA43391-MA43371-LP334960-MA43381
** Any green Ae 6/6 can be used for this train. You can also add some FS or DB Coaches (ACME, LSM or Roco) or even a single TEE coach.
TEE Roland (Bremen-Basel-Luzern-Milano) (Swiss Portion)
MA37343-TR23477 Coach Set (6 Coaches)
Modern Intercity
MA37460/HA280-MA42166A-MA42168A-MA42168WR-MA42168B-MA42166B-MA42166B-MA42168Bt
or
MA37460-RO45188-RO45326-RO45237-RO44963-RO45238-RO44972-RO44965-RO45235
IC2000 (Roco or Hag Coaches)
Re 460-AD-A-WR(or Bistro)-B-B-B-Bt
Local Pendelzug (1960s/1970s)(BDe 4/4-B-ABt)
HA152(15-003)-MA43370-RT21301***
*** You can also use MA43410
1990-today IR/Regio Pendelzug (Re 4/4II-A-A-B-B-B-BDt)
RO69845-RO44495-RO44495-RO44496-RO44323-RO44496-RT21401
Classic Gotthard Freight Train
MA39563****-Miscellaneous Freight Cars
**** Any green Be 6/8III or even a Ae 6/6 pulling an assortment of freight cars. Before the modern era with it's unit trains, freight trains used to consist of a variety of cars from many countries. Maerklin and other manufacturers often forget this when releasing Swiss freight sets like the 29680 or other products. I solved this by taking my 26730 Crocodile Set and adding the 47878 FS Car Set and a few DB cars to complete the train. The wonder of those trains and the passenger trains too was watching all the different types and colors passing by and trying to identify them. The Italian box cars with the angled roofs was a frequent sight in these trains.
Current Swiss consists can be seen at www.reisezuege.ch
You can also find some interesting ideas at the following sites: http://e.bournez.free.fr/Eurocity.html
http://www.fernbahn.de/
http://www.zugbildung.de
http://www.heinrich-hank...ahn/zugbildung/index.htm
I hope that this info is of interest to you
#2 Posted : 08 June 2009 13:30:34(UTC)
Great info, Mike. This is a valuable reference for Swiss train enthusiasts.
One question - Are there any problems involved in mixing different manufacturers coaches? I'm thinking in terms of roof heights and colour variations here, not so much about couplings.
Offline Guus
#3 Posted : 08 June 2009 13:53:20(UTC)
Guus
Thanks for the great information Mike.
You specifically mention the cargo version of the Re 4/4II as the locomotive pulling an EC train. I'm not quite sure but wouldn't any green or red Re 4/4II also be possible? Like the MA 37342 and MA 37344 for instance.
[size=1" face="Verdana" id="quote]quote:Typical EC 1990s-today (Zuerich-Munich):
or
Kind regards
Guus
Kind regards,
Guus
Offline TimR
#4 Posted : 08 June 2009 14:30:08(UTC)
TimR
Indonesia
I thought an Re 6/6 or a double headed Re 4/4 II can sometimes be used for this consist?
Thanks for posting the list, Mike.
I desperately need more EW II and EW IV coaches.
Now collecting C-Sine models.
#5 Posted : 08 June 2009 19:00:44(UTC)
Thanks for the info, Mike.
#6 Posted : 08 June 2009 20:07:23(UTC)
SUPER helpful! Especially since I have a lot of these models :)
#7 Posted : 08 June 2009 21:09:48(UTC)
Good job Mike...it looks exactly like what's going to run on my layout! wink
And we could go on for ever...
I would add a Steam freight with a Roco C 5/6 (latest version) and a dozen and a half of the historic Swiss freight car, where the dominant color was grey!
Also let's not forget a Roco or a Liliput Sputnik ("the Swiss caboose") at the head or the tail of the era III freights!Cool
Fun!
#8 Posted : 08 June 2009 21:34:14(UTC)
<br />Great info, Mike. This is a valuable reference for Swiss train enthusiasts.
I have not had any problems with mixing most brands of coaches. For example, I have a few trains that mix Roco EWII and EWIV, Lima EWI, Hag EWI and Liliput Lightsteel coaches. I have also used the new Maerklin lightsteel coaches.
I have also combined Roco, LSM, RailTop, ACME, Heris and other coaches without problem. I was disappointed to see that the Tillig/Sachsenmodelle DB Era V ICE livery coaches had the wrong height of the red stripe. That is really visible.
Tim: The Re 6/6s came into service starting in 1972. By 1975, it was common to see Gotthard trains being pulled by these loks as well. I have several Hag and Roco models, and they pull trains like my DB IC and FS Intercity Trains or a non-pendelzug set of EWIV coaches.
The double headed Re 4/4II consist is more something that I have seen on more recent trips, so with a Cisalpino or modern EC consist.
Guus: The SBB leases a few Re 421 from SBB Cargo to pull the EC trains from Zuerich to Lindau and back. The reason for this is that the trains travel from St Margrethen to Lindau over OBB and DB tracks, requiring the German pantographs. The SBB no longer has it's own loks with this equipment. I guess that you could model an earlier version (with IC and blue beige coaches) if you have the Hag model of the Re 4/4II 11196, which was at the time equipped with a DB slider.
Jacques: Sorry, I forgot to mention the 'Sputnik' for the freight train with the Crocodile. I do have one of the Roco ones that I use with the 26730 Set. AFAIR (1971) the Sputnik used to be inserted into the train about 2/3 of the way back. This allowed the staff to see the middle and end of the train. I noted this because it was not in the back like in North American freight trains. As electronic control became more common, these cars did end up later being used at the end of the train, as the electronic 'train end' equipment could be permanently mounted in these cars. Having the car at the end of the train also meant that it was easier to uncouple than having to take the whole train apart.
You may also wish to remember that even in the earliest days, international freight travel on the Gotthard was largely composed of German, Italian and other European cars travelling north to south and back. Trains within Switzerland would have seen a greater number of Swiss cars with a foreign car inserted here and there.
Another interesting source of information (for me) was the book "Die Gotthardbahn" by Marti & Trueb. AFAIK FKM modeltrains still has a copy for sale. There are editions from 1969, 1972, 1976 and 1984, so you can see how train consists have changed over the years. The books can be found on ebay (.com and .de) from time to time.
Make sure that you check out LS Models for info on the new production of SBB UIC-X Coaches, including restaurant and baggage coaches.
#9 Posted : 10 June 2009 17:49:37(UTC)
Hi mike
Besides loving the same trains, we read the same books too...Smilebiggrin
Offline rbw993
#10 Posted : 11 June 2009 00:28:04(UTC)
rbw993
Thanks Mike,
Very useful.
Roger
Offline Gustavo Villa
#11 Posted : 11 June 2009 03:52:41(UTC)
Gustavo Villa
Chile
This is also a very good source to find consists:
http://www.lsmodels.com/...positions_de_rames_F.htm
It is organized by years, with different brands for locomotives and coaches.
Actually Im waiting some day marklin/trix will deliver the mistral coaches to build this train.
I already have the locomotivebiggrin
#12 Posted : 06 July 2009 05:09:50(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Gustavo Villa
<br />This is also a very good source to find consists:
Gustavo,
Jocadis.com still has the RT/LSM Cisalpin 86101-86103 Sets listed as in stock. If you want to model the Arbalete (1969-1972), you can use the LSM Sets 41109 and 41112. After 1973, the color of the dining coach was different and beginning in 1974, some of the coaches were replaced by more modern Mistral 69 coaches (see RT/LSM Set 86101).
Both the RT/LSM and Maerklin/Trix coach series are exact 1:87. I have not seen the Maerklin models so I don't know if they offset the bogie to reduce overhang like they have done with most models over 26cm.
#13 Posted : 06 July 2009 06:50:23(UTC)
Gustavo Villa
Chile
Thank you very much for the imformation and the link (very good store).
I wonder if mistral coaches were the only ones Re 4/4 TEE pulled in those times.
And also looks like railtop and LS models haven´t release the first coach of the photo (The one with higher roof at one end).
Offline WelshMatt
#14 Posted : 06 July 2009 14:22:43(UTC)
WelshMatt
That coach has the generator aboard, which powers aircon/heating and lighting on the train. It seems to have been a peculiarly French thing, the later Grand Confort stock also had one and there was at least one design of standalone one. I would guess that it was intended to avoid any problems with different power availabilities from locos that might be encountered while crossing borders.
LS Models have definitely released it, it would have been part of one of the coach packs as it's essential for any train of this stock.
Matt from Wales.
#15 Posted : 06 July 2009 18:43:47(UTC)
Gustavo Villa
Chile
[size=1" face="Verdana" id="quote]quote:Originally posted by jvuye
biggrinbiggrinbiggrin
Thanks Lutz, Do you know if marklin already released those specific Gottard coaches? or they are just regular TEE DB coaches.
As far as I know they have been releasing 2 different TEE compositions.
#16 Posted : 06 July 2009 23:42:52(UTC)
Another nice collection, Lutz.
#17 Posted : 07 July 2009 01:20:20(UTC)
<br />Thank you very much for the imformation and the link (very good store).
AFAIR the Generator coach was part of the first set 86101.
#18 Posted : 07 July 2009 04:58:32(UTC)
The photo on the cover of the 1976 edition of Die Gotthardbahn is one of the Re 4/4II TEE (11158-11161) pulling the TEE Roland on the Upper Meienreuss bridge at Wassen.
The actual TEE Roland is being recreated in 1:93 this year by Trix under number 23477. The set will include 12 coaches, two consists of six coaches each, one with destination signs for the northbound and the other for the southbound trip between Germany and Italy.
Some dealers have announced that the coaches in the set will be available in subsets of 6 and other dealers may sell as individual coaches.
The book "TEE Zuege in der Schweiz" by Peter Willen has some nice photos of this and other TEE trains.
For TEE buffs, the Re 4/4II 11158-11161 were based in Basel and Luzern and were used to haul the Roland on the Gotthard line. These loks were also used to pull the Arbalete and Helvetia from Basel to Zurich and back. The Re 4/4II 11249-11253 were based in Lausanne and were used to haul the TEE Cisalpin (after 1974) and TEE Lemano on the Rhone/Simplon route. (Prior to that those trains had been operated by either the RAe "Gottardo" and Italian trainsets.)
Swiss Train Consists (Reisezuege.ch) (Prototype)
by mike c 05/01/2010 03:11:47(UTC)
This page was generated in 0.887 seconds.
