Offline geir
#1 Posted : 20 March 2024 17:23:47(UTC)
geir
have anyone tryed to make a contact track,similar to marklin 24995?.Just cut the rail on 2 places ,5 cm between ,with a thin cutting disc.Solder the cable on the isolated track piece.?
The 24995 works great but are too expencive.
The Marklin Contact Track 24994, is unstable and sometimes fails.Maybe due to dirt.
#2 Posted : 20 March 2024 17:44:44(UTC)
You don't need to cut the rail, just cut the links between the two rails under the track, and use the red C track insulators on the side you want to isolate. Then make the connection to the appropriate tab under the track, no soldering to the rail itself, which risks damaging the roadbed.
Offline geir
#3 Posted : 20 March 2024 21:04:02(UTC)
geir
.I have cut the links between the two rails ,on many tracks and I use heat shrink tubings,to isolate the track.My favorite contact track is 24995 works great but are too expencive.The insulators are expencive too
thanks 1 user liked this useful post by geir
Tie
#4 Posted : 20 March 2024 21:29:31(UTC)
I use circuit tracks for most events and not had any problems. They can be used in one or both directions.
Offline garben
#5 Posted : 24 April 2024 16:25:53(UTC)
garben
I use the method outlined on page 6 of the attached Digital Newsletter. Very easy and works great.
Hope this helps.
Marklin Digital Newsletter Sept-Oct_Vol 27 No 2 2015.pdf (995kb) downloaded 46 time(s).
thanks 1 user liked this useful post by garben
This page was generated in 0.447 seconds.
