Offline 1borna
#1 Posted : 03 March 2024 20:59:54(UTC)
1borna
Croatia
Recently, I arranged several level crossings with a ramp
The first is a 60-year-old Faller (made since the beginning of the 60s), I got it partially assembled several decades ago.
The raising and lowering is driven by this unusual motor which creates a fluttering of the piston by oscillations of alternating voltage. He then hits the a round rubberized wheel on an axle with a worm
There are also contacts that turn the drive on or off in the upper and lower positions
The first attempts were not very successful, but when I put the thread in the right way, it got better
Later I will paint the road and other surfaces, sow grass and put up traffic signs
I will have to find a place somewhere on the layout to place it?
I slightly painted the road and the stone base around the house and planted grass and flowers
thanks 7 users liked this useful post by 1borna
Offline 1borna
#2 Posted : 13 March 2024 21:39:06(UTC)
1borna
Croatia
I assembled a Primex ramp for a friend
Someone careless damaged it with a soldering iron, so he couldn't assemble it
The bearing of this relay was damaged
I managed to put it together by melting the metal end of the relay into the plastic
Then I planted grass and flowers and glued foils with road and boards
thanks 3 users liked this useful post by 1borna
Offline 1borna
#3 Posted : 29 March 2024 21:49:20(UTC)
1borna
Croatia
I found another old Kibri ramp, it is certainly over 50 years old
In each half there is a drive
At first there was no reaction, but after treatment with contact spray and a little cleaning, it worked
There was more work to do
UserPostedImageAnd finally, some coloring and gluing
I also edited one N ramp without drive
There is also one H0 crossing next to it
Another damaged H0 was found
thanks 2 users liked this useful post by 1borna
This page was generated in 0.290 seconds.
