Offline Markey
#1 Posted : 01 January 2024 10:11:58(UTC)
Markey
Ireland
Hello
I have a number of locos in my Collection with C-Sine Motors.
One ref 39832 is up on 20yrs old now i run them from time to time.
For people useing locos with csine motors on regular basis how did they last long term for them.
thanks 2 users liked this useful post by Markey
#2 Posted : 01 January 2024 10:24:28(UTC)
I have the ICE 39710 released in 1999.
It still worked when I tried it 6 months ago.
The Märklin website has only this reference:
"1999 Club model powered rail car train ICE-S (art. 39710): Märklin uses a C-sinus motor for the first time"
Offline mvd71
#3 Posted : 01 January 2024 10:43:24(UTC)
First generation c-sine motors have never failed for me, but the SDS units are not so good.
thanks 4 users liked this useful post by mvd71
Offline bph
#4 Posted : 01 January 2024 11:54:38(UTC)
The motors are quite good, but sometimes the driver electronics fail.
Had to replace the driver electronics in my 39710, but kept the original motor.
Online marklinist5999
#5 Posted : 01 January 2024 12:03:33(UTC)
I have two with the first generation Csine. A BR 103, and a Taurus. Both still run flawless.
Offline The Crocodile
#6 Posted : 02 January 2024 13:31:27(UTC)
The Crocodile
Iceland
I too own the 39710 insider ICE-S set, it has been working very well for me and is showing no signs of breaking down on me anytime soon.
If I may sneak in a question here, I was wondering how often you guys lubricate it, if at all?
I know there are a lot of different opinions regarding oiling Märklin locos, and most 39710 material claims the C-sinus motor is “maintenance free”, but I am guessing that is referring to the fact that it is brushless, but still requires oil lubrication.
So how often, how much and where do you oil your C-sinus motors?
C-track, temporary layout. I try to run my locos as much as possible:)
thanks 1 user liked this useful post by The Crocodile
#7 Posted : 02 January 2024 15:05:25(UTC)
No oil very often. We don't want oil geting into the rotor/stator. A tiny drop of gear oil on the bogie gear.
#8 Posted : 02 January 2024 17:31:13(UTC)
Hi Markey
I have over 10 C-sine / SDS (Soft Drive Sinus) locos. A very old one is a E94 issued in 2004 with a full size sinus motor
They are well better than newer ones when it comes to silence, slow speed etc.
They are not maintained by Märklin anymore so beware of electric shock when opening one
NEVER service the motor (oil the ball bearing).
Sadly also they come with simplified sound decoders or nearby cheap sound module.
I just upgraded a SDS loco I love the SNCF CC 40108 using a mSD3 and it runs as well but with all the sounds I wanted using mDecoderTool3 and my CS3.
The SDS and C-Sine locos are very praised because of their magnificent rolling properties
Offline Mark5
#9 Posted : 04 January 2024 08:13:48(UTC)
Mark5
I have the insider model grey Franco-Crosti 39160 BR 42 with C-sine motor and it appears the decoder was fried. Some years ago I sent a a query to Marklin about fixing it but never followed through. What is the simplest way to replace the decoder with a newer one, are there decoders that would be simple/complex enough to use in replacement?
#10 Posted : 04 January 2024 10:51:12(UTC)
Hi Mark
This loco was released in 2000-2001 with a Sinus motor (Full size early model) not a Compact Sinus (C-Sinus), not a Softdrive Sinus (SDS)
Here is the motor and loco part
Here is the electronics in tender
So from what I see (I may be wrong, it must be checked) the electronics is all in one piece and if EITHER the motor is bad OR the ELECTRONICS is bad, then no simple repair can be made. No repair from Märklin to be expected.
There is a company in Switzerland providing replacement drive electronics
There is a company in Germany to replace Sinus motors with DC ones (then a mSD3 will do to drive it
Sadly I don't remember their names. Maybe someone can help?
Offline ktsolias
#11 Posted : 04 January 2024 12:18:23(UTC)
ktsolias
Originally Posted by: Markey Go to Quoted Post
Hello
For people using locos with csine motors on regular basis how did they last long term for them.
Hi have a look here
https://www.sb-modellbau...ES64U_Flachlaeufer_22161
They sell the motors and they provide and full replacement service. Excellent but a bit to slow the repairs due to much work.
I have done some by myself with excellent results, but experience is needed.
Costas
thanks 3 users liked this useful post by ktsolias
Offline Mark5
#12 Posted : 04 January 2024 13:22:19(UTC)
Mark5
I am wondering if buying a new one on ebay would be easier, but leaving it without fixing it really goes against my nature. I will take a closer look at it first. I did really like how it seemed to have a very smooth running ability.
Offline Kiko
#13 Posted : 09 January 2024 22:32:02(UTC)
Kiko
Hello Markey,
I have a few C-Sine locos: BR01.10 #39103; BR151 #39581; V200 #39821. All are original from the early 2000s. After 20+ years, they run really-really well with hardly any maintenance. My only complaint is that the sound is pathetic. For such beautiful locos with great running characteristics (even at crawl speed), it's a shame that we can't easily upgrade the sound.
I've added capacitors to the three locos in order to help the sound module from cutting in and out whenever there's a slight power drop. This helps somewhat, but the sound electronics sometimes just forget to output any sound. Then, all of a sudden, they start outputing sound! There's also a noticeable delay when sound is activated (i.e., horn should sound before a bridge, but it's delayed until half way accross or just does not sound at all). The C-Sine motor itself does not care if there are short power interruptions. -- it just keeps rolling along.
I hope this helps.
Andry
thanks 3 users liked this useful post by Kiko
Offline franciscohg
#14 Posted : 10 January 2024 03:09:34(UTC)
franciscohg
Chile
Hello
For the old sine motors in wich the electronic of the motor and decoder are inetgrated in the same PCB for repairing and/or upgrading to newer sound (or not) decoders, you can get the electronic board with Mr Erich Iten in switzerland at www.rail4you.ch
Of course you will also need a suitable decoder also. For this particular loco wich has not a flex strip to connect the motor to the board but cables, you will also need an adapter wich is also provided by Mr Iten.
I have used them in several locos to upgrade to better sound decoders, and the work great.
here you can see the results with an old 39221
?si=9CuYWLr3JXI7VeXc
and a thread about such conversion here
https://www.marklin-user...-ch-DsM-2-0-driver-board
thanks 6 users liked this useful post by franciscohg
Offline Bryan
#15 Posted : 10 January 2024 20:50:00(UTC)
Bryan
There is a company in Germany that specialises in repairing Marklin C - Sine locos.
It is called DR Feurst - https://www.drfuerstgmbh.de
They promote that anything can be repaired. They are also a registered Marklin Service Provider, which is quite rare, so should be good.
It has been stated they can repair the original driver boards with SMD installation capabilities.
David
thanks 5 users liked this useful post by Bryan
Continuous disappointment w. compact c-sine motors (Digital)
by svgeorgiad 17/03/2007 11:58:27(UTC)
This page was generated in 1.149 seconds.
