Offline Mille
#1 Posted : 24 October 2023 17:49:57(UTC)
Mille
Do i need booster?
I have 50 meter track,10 digital turnouts
10 locos and some signals
My new layout is still under construction
so it would be good to know
Offline PeFu
#2 Posted : 24 October 2023 18:43:17(UTC)
PeFu
This depends on the number of locos that you intend to move simultaneously, and how much current they consume. If only 4-5 locos move, your CS would probably be enough. If all 10 locos move, you will absolutely need an additional booster.
Your track length is no issue, but make sure to have short feeder cables approx. every 2nd meter, and connect the feeder cables to a fatter cable bus (maybe 1.5-2 mm2).
Smile
thanks 2 users liked this useful post by PeFu
Offline mvd71
#3 Posted : 24 October 2023 19:32:11(UTC)
Originally Posted by: Mille Go to Quoted Post
Do i need booster?
What controller are you using?
A common starting point is to use a booster to supply the turnouts and signals independently from the locos.
Offline Bill L
#4 Posted : 25 October 2023 06:09:10(UTC)
Bill L
If you plan to run a lot of passenger cars with lights in each car, a booster is highly recommended, otherwise you will notice the trains run slower, and when you switch off the passenger lights, your train will speed up.
Offline Mille
#5 Posted : 25 October 2023 10:43:50(UTC)
Mille
Im using cs3
Atleast 6-7 locos gone run at same time
So booster would be needed?
#6 Posted : 25 October 2023 12:56:16(UTC)
Do i need booster?
Hi Mille
The current need depends on:
- how many locos
- how recent they are (older locos need 8 to 15 VA) when recent ones draw 1,5 VA. Bulbs, old "HDLA" motors draw much more than recent CAN motors
- how many smoke units you have (1 to 1,5 VA for normal ones, 3 VA for pulsating ones
- how many bulbs you have in locos, wagons, signals, M-Track turnouts. Each is about 1 VA
The current does not depend on
- what length of track you have
- how many turn-outs you have: In digital, only ONE is activated at any given time (100 mS time slots)
- how many turn-out lanterns you have (their current need is insignificant.
My choice on my layout was to use a CS2 (later a CS3) with one 100 W power supply (5A of digital power).
With this, recent locos, many (30 cars approx.) illuminated cars (All LEDs), 50 switch lanterns and 26 locos the current is 2.9 Amp wgen idle and up to 3.5 in full operation. So I have a reserve in excess of 1.5 Amps
This choice is discouraged by Märklin because they want to sell boosters and power supplies, they don't want to bear any legal responsibility in case of fire. This works extremely well (over 10 years in my case without any side effect). ESU provides an ECOS with 8 Amps available power, so it is not THAT dangerous.
Note: Märklin signals and relays are rated for 2 Amps which already above the standard 3 A limit of a CS2 / CS3 for HO gauge. In my case, using Rocrail, there is not a single insulated stop zone (so no 2 Amp contacts to worry about).
To give you a flavour, here is a video of my layout in operation (remember it is 3 levels with the lower one with shadow stations for 14 trains):
At all times, I may have 5 to 7 trains in operation (many in the hidden section)
Booster is needed as layout grows (Digital)
by petestra 01/08/2023 14:39:57(UTC)
CS2 : s88Link and Booster use same port : how do I connect them both ? (Digital)
by Johnvr 06/07/2023 13:04:58(UTC)
Booster (H0-scale)
by Heinz 30/01/2023 21:17:24(UTC)
Recall of Märklin boosters 60175 (Digital)
by Unholz 29/07/2022 15:08:29(UTC)
Using boosters with MS2 (General MRR)
by Sean McClaymore 08/04/2022 11:32:08(UTC)
power booster options (Digital)
by augieo 07/01/2022 22:02:22(UTC)
Quick question about adding a booster to the layout (Digital)
by Chris6382chris 15/12/2021 00:56:33(UTC)
How to connect boosters please (Model railroad wiring)
by DV 25/11/2021 04:07:24(UTC)
Wiring my layout for future booster (Model railroad wiring)
by IBtrain 22/11/2021 20:23:43(UTC)
Booster to protect Central command unit. (Digital)
by franciscohg 15/10/2020 16:34:56(UTC)
CS3 with multiple boosters (Digital)
by Klarsyn 17/09/2020 17:01:47(UTC)
Digital booster on Spur 1 (Big scale)
by pa-pauls 22/07/2020 09:02:34(UTC)
60173 booster with which transformer? (Digital)
by gauravk84 09/06/2020 17:56:25(UTC)
Booster for Mobile station 2 (Digital)
by kytumba@gmail.com 09/06/2020 11:41:18(UTC)
Sparking at the junction of the Booster connections (Digital)
by Drongo 25/06/2019 01:39:34(UTC)
Problem with Booster 60174 and CS2 (Digital)
by PeFu 02/05/2019 21:59:20(UTC)
Booster 60175 (Model railroad wiring)
by Thewolf 03/03/2019 18:30:52(UTC)
Ecos2 Märklin booster (Digital)
by PkMärklin 31/01/2019 19:32:49(UTC)
Old Transformers and boosters (Digital)
by Drjoe11 25/08/2018 19:59:56(UTC)
Cs2 and booster (Digital)
by eurotrain 05/06/2018 18:03:17(UTC)
Marklin Turntable & 60175 Booster (Digital)
by chrisisrang 05/04/2018 10:33:05(UTC)
Large Layout with MS2 - do i need booster (Digital)
by Deepak 26/02/2018 08:23:02(UTC)
Isolating Booster Circuits (Digital)
by dickinsonj 26/01/2018 22:02:53(UTC)
connecting a third booster to a CS2 (Digital)
by craigericks 03/01/2018 00:31:41(UTC)
Booster strategy? Amps required... (Digital)
by PeFu 24/10/2017 23:16:53(UTC)
Problems with Marklin 60174 Booster and New Installation Decoders and some Locomotives/Decoders (Digital)
by Hhjg2y 25/09/2017 00:57:47(UTC)
Marklin 60174 Booster, CS2, S88, and viessmann 5233 (Digital)
by Hhjg2y 17/08/2017 14:54:31(UTC)
M83 power supply via booster (Digital)
by antazio 28/04/2017 20:51:41(UTC)
Transformer 60055 with booster 60174 (Digital)
by Incognito 15/04/2017 23:08:41(UTC)
L88 60883 connection to CS2 + booster (General MRR)
by antazio 25/02/2017 02:13:01(UTC)
Use CS1 as a Booster (Digital)
by rbw993 21/02/2017 17:08:40(UTC)
Connecting CS2, L88, Boosters (Digital)
by Harvey 20/02/2017 16:32:03(UTC)
Booster Problem? (Digital)
by NewMB 02/02/2017 17:52:43(UTC)
Cs 2 - Litfinski booster DB-2 (Digital)
by Nils Gullhav 26/01/2017 11:43:58(UTC)
Boosters and free booster recall/upgrade (General MRR)
by baggio 24/01/2017 05:37:59(UTC)
CS3 plus and booster 60174 (Digital)
by MSanches 10/11/2016 20:26:54(UTC)
76491 - Connecting to M track with booster circuit (Digital)
by Harvey 29/05/2016 18:29:07(UTC)
Booster and K84 (Digital)
by Harvey 03/03/2016 02:49:15(UTC)
LDT or Märklin booster? (Digital)
by Hackcell 21/10/2015 02:50:33(UTC)
eCos 2 and 6017 Booster (Digital)
by xxup 24/09/2015 01:25:30(UTC)
Booster 60174 when do I need one (Digital)
by Timnomads 16/09/2015 14:38:58(UTC)
Grounding one wire of booster to signal a short to Intellibox? (Digital)
by DaleSchultz 13/01/2015 16:42:54(UTC)
Boosters, power supplies and overload situations (Digital)
by sjlauritsen 15/11/2014 10:30:33(UTC)
Rocker insulator(s) needed for separate boosters (Model railroad wiring)
by michelvr 30/10/2014 15:51:44(UTC)
Booster/ Transformer (Digital)
by charles Sharpe 17/10/2014 04:52:56(UTC)
Boosters and emergency stop (Digital)
by sjlauritsen 10/09/2014 10:04:06(UTC)
Exchange Program for 60173 Booster (Digital)
by Shamu 05/04/2014 02:31:41(UTC)
LDT mfx compatible booster (Digital)
by Hackcell 21/03/2014 02:57:03(UTC)
60215 compatible Boosters (Digital)
by Hackcell 27/01/2014 00:00:01(UTC)
Booster cable For Marklin 6015 (Digital)
by klafleur3 22/10/2013 00:38:04(UTC)
This page was generated in 0.524 seconds.
