Offline Chris6382chris
#1 Posted : 06 September 2023 23:59:24(UTC)
Chris6382chris
In the past I had my MS1 connected to my ECOS. I would then be able to load up a limited number of engines and use the MS1 to control them. This was a great set up for my daughter. Now I have added a total of 5 ECOS detectors to the layout and an ECOSLink Terminal. Four of the ECOS detectors plug into the ECOSLink Terminal and the Terminal is plugged into the ECOS. I have two open plugs on the face of the EcosLink Terminal available and was planning on plugging the MS1 into that. However, once I plug into the EcosLink Terminal the MS1 comes on but I do not see it on the ECOS and I am no longer given any option to load engines into the MS1 from the ECOS. I know get the same response when I try and plug the MS1 directly into the ECOS.
The MS1 worked before but it no longer is seen by the ECOS, what am I missing? Everything runs as it should. The ECOS has the latest software on it. I am running my ECOS as the primary controller. I have one 7A Booster, 5 ECOS Detectors, 4 of which are running through the ECOSLink Terminal. The MS1 is a 1.9A controller that was working before perfectly with the ECOS before.
Any advice would be appreciated.
Chris
This page was generated in 0.184 seconds.
