Offline zev kahn
#1 Posted : 10 July 2023 00:06:33(UTC)
zev kahn
I've had a Magnorail bicycle setup for several years. I only run bicycles on the track. I have two medium motors and 8 bicyclists. In the early days of my layout all bicyclists would properly move their legs. However, for the last few years some bicyclists move their legs and some don't. It is evenly a problem between bikes I put together and those I bought pre-assembled.
Does anyone have any sure fired tricks that will work?
Thank you
#2 Posted : 10 July 2023 14:18:52(UTC)
I would try cleaning them with canned air, and or using a very light plastic safe oil like Hetman synthetic bearing and linkage rotary valve lubricant for musical instruments. i use it on plastic coupler guides, etc. with excellent results. Amazon has it. Otherwise, check if the tries are contacting the r trail/road beds.
Edited by user 10 July 2023 19:29:15(UTC)  | Reason: Not specified
This page was generated in 0.303 seconds.
