Offline mramstedt
#1 Posted : 29 October 2022 19:26:01(UTC)
mramstedt
I have a possibility to get this set, but cannot find the number and the seller has lost the cover.
Anyone recognise this set?
Offline mramstedt
#2 Posted : 29 October 2022 19:36:02(UTC)
mramstedt
Found it... seems to be https://www.maerklin.de/...s/details/article/29184?
Would this work with and MS2 system and should/could the Base Station be connected without the controller?
Thanks!
-Marko
Offline thomasm
#3 Posted : 29 October 2022 20:18:23(UTC)
thomasm
Yes, you can use this set with MS2, but be aware that you won't be able to use both the MS2 and the IR-controller included in the set.
.thomas
Märklinist, hobbyist and collector. || Trains are meant to be driven.
Offline mramstedt
#4 Posted : 29 October 2022 20:21:43(UTC)
mramstedt
Thanks, would it be worth connecting the base station for added power, but leave the controller out? I have 5 locomotives at the moment to setup.
#5 Posted : 29 October 2022 20:22:16(UTC)
Would this work with and MS2 system ...
Well, under the 'digital functions' part of that page it lists the functions that an ms2 will control.
Thanks!
-Marko
Not sure what you are asking here. If you are wanting to use the infrared controller that comes with the set at the same time as the ms2, no you cannot do that.
If you want to use the piece of track that has the infrared receiver in it then you need to disconnect the brown and red wires underneath the track. The block with the infrared receiver may then come off the track piece without too much trouble.
It would be a nice set to get. These locos are little gems and run very nicely.
#6 Posted : 29 October 2022 20:29:30(UTC)
Actually on further investigation it is this one. Notice the loco is different.
#7 Posted : 29 October 2022 22:04:42(UTC)
A little googling of Maerklin Start Set mit Kran yielded the result of 29180: https://www.maerklin.de/...te/details/article/29180
I also found similar sets with the number 29181 and 29182, which have infrared remote control, albeit slightly different from the one in your photo.
The remote in the 29183 corresponds to the one in the photo of your set, but the locomotive is different.
The locomotive number (195) of the 29182 is the same as in the photo of your set.
https://www.maerklin.de/...te/details/article/29181
https://www.maerklin.de/...te/details/article/29182
https://www.maerklin.de/...te/details/article/29183
My guess would be that you got a 29182 with the remote, power supply and contact track from a 29183 set.
#8 Posted : 30 October 2022 01:09:46(UTC)
I picked up on the loco being different to the set originally identified, but didn't pick up on the control unit.
Looking at the photo again I'm not sure how the track with the IR receiver would fit in the box anyway, unless it should be the bottom track on the stack of straights. maybe the big lump fits under the point or somewhere.
#9 Posted : 30 October 2022 02:36:02(UTC)
I've got 29181, but got it with just the box and train. I've since added all the track and a MS1, I carved out the polystyrene to fit the MS1.
The train is a great themed set, and I run it reasonably often. There were also add on sets available which added a bit of track with extra wagons and vehicles.
https://www.maerklin.de/...ts/details/article/78080
There was also the 00777 set which had 12 'CAT' (Caterpillar) construction machinery models - 4 types, 3 of each.
https://www.maerklin.de/...ts/details/article/00777
I purchased some extra CAT vehicles locally and run them with the train.
This page was generated in 0.581 seconds.
