Offline Barby & Stan
#1 Posted : 15 August 2021 23:07:02(UTC)
Barby & Stan
I have a 2008 Central Station 2.
I would like to run a software update which has never been done on this unit.
How do I do this?
As I am a novice at this please supply step by step instructions.
Thank you all out there,
Stan K
#2 Posted : 15 August 2021 23:33:17(UTC)
Hi Stan
You have basically 2 ways
ONE is to connect your CS2 to the Internet (the auto mode is preferable to manual mode as it leaves your router or Internet box assign the IP address to your CS2.
Then power-up
Then select SETUP and then UPDATE and Network to start the update
Note: because no updates were made for a long time, be prepared for multiple reboots and updates. Also do this only if you have a good internet connection. Otherwise the USB memory solution is better.
TWO, using your computer and a USB memory stick, go to the Märklin website https://www.maerklin.de/en/service/downloads/cs2-updates/
Agree to the software licence to get the update download.
When finished copy the download to your USB
When finished, plug your USB to your already-started CS2
Then select SETUP and then UPDATE and USB Stick to start the update
WARNING: be patient because a normal Update can last 30 to 45 minutes and in your case even longer. If the CS2 reboots let it alone until the success is displayed
I hope this helps
#3 Posted : 16 August 2021 01:23:27(UTC)
I hope this helps
If the cs2 is that old then the update is a two stage process and there are two files that need to be downloaded. The reason for this is that they have changed the format of the update file at version 3.something and old machines need to update to that version before the newer update will work.
If you can do the update connected to the internet this will all be done automagically for you, and is the method I would recommend if you use it. As Jean mentioned there will be multiple reboots of the cs2 as it does the update, whichever method you use.
#4 Posted : 28 August 2021 22:23:55(UTC)
Barby & Stan
Hi Stan
Then power-up
I hope this helps
Problem solved!! I purchased a cross over cable from our local electronics outlet.
Eventually took it to a a reputable electronics ouitlet that tested the cable and discovered it was a faulty product..
Bought a quality cable from these folks and the download proceeded faultlessly exactly as John jean and Kiwi Alan said it would.
Take home message: Buy your electronic needs at reputable, professional outlets
#5 Posted : 28 August 2021 23:59:18(UTC)
Don't bother to purchase an Internet crossover cable. Why?
Because since years, when dealing with the protocol (TCP/IP) recent Internet interfaces check the connection and swap entry and exit if the need arises making the need for crossover cables useless (but they also work.
So ANY internet cable will do.
Central Station 2 stuck on STOP (Digital)
by mattj70 25/02/2024 12:58:53(UTC)
New software: TrainControl for Marklin Central Station 2 and 3 (Model railroad software)
by moman2 10/11/2023 23:20:03(UTC)
Central station 2 (Digital)
by Antonio21 16/03/2023 16:50:54(UTC)
MU Consist on Central Station 2 (H0-scale)
by Jan Havenga 03/11/2022 18:47:05(UTC)
TCP ports in the Central Station 2/3 (Digital)
by fosuna 18/02/2021 07:27:43(UTC)
New hear- Central Station 2 and my 1 gauge locomotives (Big scale)
by Simone458 26/09/2020 02:23:22(UTC)
Solved - Will a Central station 2 or 3 automatically recognize a Loksound V 4.0 decoder (General MRR)
by river6109 11/03/2020 03:57:58(UTC)
central station 2 for DCC 2 rail (Digital)
by daafies 18/09/2017 20:27:01(UTC)
Central Station 2 (Digital)
by loderunner 18/09/2014 23:12:54(UTC)
Compatibility between Central station 2 (60125) and Trix Mobile Station 1. (Digital)
by Gustavo Villa 11/09/2012 16:27:02(UTC)
Ipod Touch + Märklin Central station 2 (Digital)
by Christoffer 03/01/2012 15:27:38(UTC)
Central Station 2 Overload (Digital)
by Brian Sprowell 26/06/2011 07:57:17(UTC)
Ha Noi - Vietnam, Hanoi Central Station 2011 (Prototype)
by Yumgui 11/06/2011 23:35:04(UTC)
new images on the central station 2 (H0-scale)
by FPMarklin 02/01/2011 01:21:36(UTC)
Buy or not Central Station 2 (60214) ? (Digital)
by anthpao 29/07/2010 20:41:03(UTC)
Central Station 2 CAN View Window (Digital)
by johnhmccauley 19/04/2009 01:36:08(UTC)
Update for Central Station 2 ?????? (Digital)
by TomB 26/03/2009 20:44:28(UTC)
Central Station 2 Upgrades (Digital)
by James 28/01/2009 02:48:03(UTC)
Is Central Station 2 ready for prime time??? (Digital)
by Larry 29/09/2008 20:17:29(UTC)
This page was generated in 0.444 seconds.
