Offline Timnomads
#1 Posted : 14 December 2020 14:58:44(UTC)
Timnomads
Hi All
I would like to put a double Y junction onto my layout, I need help with the design using C track components.
Does anybody have the solution.
Tim
#2 Posted : 14 December 2020 15:23:37(UTC)
Didn't try yet.
Some notes:
  • If you replace the 24230 near the gap with 24215+24207 then the angle should nearly match; use 24115+24107 instead of the 24130; small gaps on the CAD usually do not matter as the tracks have some elasticity
  • Otherwise, to get a full 90° turn add 24206 pieces at the turnout and crossover on top; then you can also add 24206 to each other turnout/crossover and fill the gap with a 24230 to get to full 90°
#3 Posted : 14 December 2020 15:43:41(UTC)
How large can we go?
I do not like the s-shaped curves, but it can easily be built without cutting C track pieces:
#4 Posted : 14 December 2020 15:53:07(UTC)
A bit smaller, but I'm not sure if you can squeeze it together:
Offline Timnomads
#5 Posted : 14 December 2020 18:26:16(UTC)
Timnomads
thanks for your help, i like the smaller version, as in this case, size matters. i think C track may have the wiggle room. i will build it in scarm, and see how many mms i have to wiggle. The important bits are the angles.
Tim
thanks 1 user liked this useful post by Timnomads
Online Alsterstreek
#6 Posted : 14 December 2020 19:12:04(UTC)
How about swinging (and space saving)?
Offline Timnomads
#7 Posted : 16 December 2020 18:52:55(UTC)
Timnomads
Thanks i will try to incorporate this into my track design, and put it up later for commumity input BigGrin
Tim
Online Alsterstreek
#8 Posted : 17 December 2020 11:51:36(UTC)
Perhaps - see below link (not my work):
https://abload.de/img/cgleisdreieckep1uth.jpg
This page was generated in 0.461 seconds.
