Offline poppa-7
#1 Posted : 17 November 2018 04:26:00(UTC)
poppa-7
Hi Members
I have a Marklin 3072 BR21 and a ESU 52610 decoder. The loco has a small flat face commutator and lights that are on their own twin wire circuits, is it possible to fit this decoder to the loco without changing the motor parts with a 60943 conversion kit? If so can any one provide me with a wiring diagram
Russell
Confused
#2 Posted : 17 November 2018 07:21:46(UTC)
Yes, I have done it, BUT you need a lokprogrammer to set the motor type correctly. Otherwise it will not run well.
You also need to have a very good look at the motor and give it a good clean and new brushes..
Lokprogrammers are not very expensive and they are one of those things, along with a decoder tester, that should be in your toolbox if you are going to do a few digital conversions.
Offline Dave Banks
#3 Posted : 17 November 2018 07:29:13(UTC)
Dave Banks
Sorry it is not in English but just for you to look at: https://www.youtube.com/watch?v=4IZ6sZD9Z9w
D.A.Banks
Offline Markus Schild
#4 Posted : 17 November 2018 08:50:35(UTC)
Markus Schild
Hi Russell,
No, that decoder does not work with that motor. It must be converted to a DC-Motor. There are decoders on the market which works with field-coil motors like yours, but not that ESU 52610. Instead of buying a motor - set you can also just replace the field-coil with a HAMO - magnet. But the results are not as good as with the conversion-kit.
Markus
#5 Posted : 17 November 2018 10:18:16(UTC)
The decoder works with the motor if you disable the load regulation in the decoder (this can be done without a LokProgrammer).
The LokSound 2 decoder was the last ESU decoder where ESU described in the manual how to wire this up. IMHO it makes no sense to do this.
IMHO you should at least get an ESU permanent magnet for the motor.
Offline poppa-7
#6 Posted : 18 November 2018 09:29:59(UTC)
poppa-7
Thanks for all your posts on my problem, but it looks like my cheapest and best option is to purchase and fit a permanent magnet ESU51961.
Russell
#7 Posted : 18 November 2018 09:50:44(UTC)
If you do need a Lokprogrammer Russell, I have one and can bring it to Railex.
3054 digital conversion and magnet mount problem (Digital)
by lpesce 05/05/2024 00:30:07(UTC)
Digital conversion of 4-6-2 steam loco from 1961 (Digital)
by Bcur 28/02/2024 17:56:38(UTC)
Digital Conversion of a Delta Ae 8/14 - PC Board Part #? (Digital)
by 5HorizonsRR 06/02/2024 20:39:15(UTC)
ICE 3370 or 3770 digital conversion (H0-scale)
by StanN 21/12/2023 22:59:50(UTC)
Hag digital conversion (General MRR)
by mvd71 06/05/2023 05:58:50(UTC)
Digital conversion of Märklin 3511 (Digital)
by Martti Mäntylä 04/12/2022 17:36:42(UTC)
New to digital conversion- seeking guidance on wiring (Digital)
by BurritoJoe 10/06/2022 04:44:16(UTC)
Analog to Digital Conversion Marathon (Digital)
by Paul24 02/02/2022 23:27:03(UTC)
Digital conversion of 89 series (Digital)
by Jay 11/06/2021 19:17:52(UTC)
Digital Conversion: Part list needed (Digital)
by madhu.gn.71 30/03/2021 11:47:44(UTC)
Digital conversion of 3060 Santa Fe with mfx60760 (H0-scale)
by Spirre 15/02/2021 21:48:54(UTC)
Digital Conversion (H0-scale)
by fossie 06/02/2021 18:45:33(UTC)
Better digital conversion BR128 (Digital)
by siroljuk 05/02/2021 09:52:32(UTC)
Help with Digital Conversion (Digital)
by waterslip 05/12/2020 03:49:42(UTC)
digital conversions (Digital)
by MHJ87 05/07/2020 02:56:05(UTC)
3046 digital conversion (Digital)
by MHJ87 31/05/2020 07:55:48(UTC)
by MHJ87 08/05/2020 02:33:56(UTC)
A simple little trick to make your digital conversion easier (Digital)
by Johnvr 27/04/2020 12:57:43(UTC)
Minitrix ICE 3 Digital Conversion (Digital)
by thanos339 16/04/2020 22:07:12(UTC)
analog to digital conversion (Digital)
by hangle718 09/04/2020 01:31:26(UTC)
Märklin 3462 EMD F7 "ALASKA" Digital conversion (Digital)
by ktsolias 27/03/2020 12:16:26(UTC)
BR80 digital conversion (Big scale)
by mvd71 26/02/2020 06:42:32(UTC)
Advice sought for digital conversion / upgrading (Digital)
by Martti Mäntylä 24/10/2019 16:32:18(UTC)
digital conversion newbie help (Digital)
by quarkhirad 05/09/2019 08:24:48(UTC)
Märklin 3111 Digital Conversion with 60906 Decoder (Digital)
by ktsolias 28/05/2019 11:16:31(UTC)
3015 Digital Conversion & Lighting Tips? (H0-scale)
by 5HorizonsRR 11/02/2019 16:24:15(UTC)
3074 digital conversion issue (Digital)
by Donb 31/12/2018 19:18:02(UTC)
Digital Conversion Märklin 3448 E 70 21 (Digital)
by ktsolias 09/11/2018 11:26:46(UTC)
Digital Conversion Question: Marklin Z Class 50 Steam Loco (Small scale)
by JD3 01/06/2018 21:46:25(UTC)
60760 digital conversion kits (Digital)
by Bryan 11/03/2018 20:39:09(UTC)
Märklin 3031 BR 81 Digital Conversion (Digital)
by ktsolias 02/03/2018 11:29:53(UTC)
3074 Digital conversion, motor buzzy (Digital)
by db60 15/01/2018 00:44:30(UTC)
Why do the digital conversion sets include the Chokes ? (Digital)
by Johnvr 29/10/2017 19:42:20(UTC)
3046/3047 BR 44 Digital Conversion- Keeping the smoke unit? (Digital)
by 5HorizonsRR 20/10/2017 02:25:14(UTC)
Using Original Motor Plate During Digital Conversion-ESU 54631 Kit (Digital)
by 5HorizonsRR 05/09/2017 01:48:27(UTC)
Märklin 3309 DB BR 85 Digital Conversion (Digital)
by ktsolias 23/05/2017 10:03:11(UTC)
more digital conversions (Digital)
by river6109 03/05/2017 04:40:33(UTC)
Please, help for digital conversion. (Digital)
by airsoftrc 27/03/2017 23:05:54(UTC)
Märklin 3352 Ce 6/8 Crocodile, Digital Conversion (Digital)
by ktsolias 01/03/2017 11:03:08(UTC)
by Pierrenicolas 28/01/2017 03:00:53(UTC)
3048 Digital Conversion (Digital)
by ktsolias 05/12/2016 19:26:33(UTC)
Trouble shoot 3041 digital conversion (Digital)
by EDWARD MCNALLY 17/11/2016 23:27:18(UTC)
Digital Conversions worth the cost and Hassle? (Digital)
by Collector 31/08/2016 13:26:45(UTC)
digital conversion 3028, 3428 Br 515 (Digital)
by river6109 27/08/2016 07:03:24(UTC)
6 digital conversions (Digital)
by river6109 24/08/2016 15:05:29(UTC)
Marklin 3147 Digital Conversion (Digital)
by MKOpSeattle 09/07/2016 06:33:05(UTC)
Märklin DB BR 85 digital conversion adventure (Digital)
by river6109 15/06/2016 14:49:06(UTC)
another digital conversion DSB My 1134 (Digital)
by river6109 11/06/2016 13:02:48(UTC)
Marklin 3075 digital conversion (Digital)
by fossie 18/05/2016 14:18:25(UTC)
by ktsolias 10/05/2016 19:13:26(UTC)
This page was generated in 0.693 seconds.
