Offline YuLunWu
#1 Posted : 26 July 2016 02:11:53(UTC)
YuLunWu
Taiwan, Province Of China
I've followed the manual and choose DCC then tried to read the address, I am pretty sure this is a DCC loco because I just operated it via ROCO Z21 and all functions works.
However when I switch to CS2, it couldn't be recognized anymore, does anyone know what's going on?
Offline franciscohg
#2 Posted : 26 July 2016 03:43:31(UTC)
franciscohg
Chile
Hello, did you put it in the programming track?
#3 Posted : 26 July 2016 08:08:36(UTC)
Welcome to the Forum!
Which loco?
DCC address detection must be done with the loco on the programming track, as Francisco already mentioned.
It does not work for all locos - e.g. small locos that draw very little current.
If it worked with the Z21 then the address is known. Just enter the address into the CS2 and it should work.
Offline YuLunWu
#4 Posted : 09 March 2017 06:02:38(UTC)
YuLunWu
Which loco?
Hi, sorry I have been long time couldn't able to play it, I just input the original cv address(which was set to 03) and then it showed " the transfer of CV values is not possible at the moment. Please try again later."
Anyone have idea for it?
#5 Posted : 09 March 2017 07:43:43(UTC)
Don't try this when the red STOP light is on.
Offline YuLunWu
#6 Posted : 09 March 2017 08:01:51(UTC)
YuLunWu
Hi, just tried with red stop off, but it pop out "The locomotive address could not be recognized within 4 seconds" as the pic attached.
It seems CS2 cannot recognized DCC decoder as it announced.
#7 Posted : 09 March 2017 08:09:28(UTC)
DCC works generally with the CS2.
The DCC loco must be on the programming track - alone, nothing else connected to the programming track.
And DCC must be activated in the CS2.
And still DCC reading may fail for some locos - e.g. if they draw very little current or very much current.
Do you have other DCC locos you can try?
And when using H0 locos: With three-rail track connected to the CS2 you can read three-rail locos only (no reaction with two-rail locos on the track). With two-rail track connected to the CS2 you can only read two-rail locos (three-rail locos cause a short in that case).
When the address is known, just type in the address and run the loco. Reading CVs is not required to operate locos with a known address - it is required to make any changes, so reading CVs is quite important).
Offline YuLunWu
#8 Posted : 09 March 2017 08:16:48(UTC)
YuLunWu
Yes, I did connect the 2-rail track on the program port only, and only one dcc loco on it which has been successfully detected with roco z21.
right now I don't have any other dcc loco for test.
I just don't understand why CS2 cannot recognize it easily as z21 did: just put it on and press detect, then the system will recognize it and automatically read all functions just as CS2 recognize the locos with mfx decoder.
#9 Posted : 09 March 2017 15:06:20(UTC)
The z21 may have used railcom to recognise the loco. The cs2 does not have railcom, but I still do not understand why it cannot find the loco.
Offline YuLunWu
#10 Posted : 09 March 2017 16:00:40(UTC)
YuLunWu
The decoder is loksound m4, quite normal decoder, don't know why CS2 couldn't read it.
#11 Posted : 09 March 2017 16:59:06(UTC)
If you have mfx enabled on the CS2 and in the decoder, then the decoder will register using mfx.
It is by design that DCC is ignored in the presence of mfx.
M4 is ESU's name for mfx.
#12 Posted : 09 March 2017 18:29:07(UTC)
Before to call up an DCC loco with the adress manually,you must be sure first that CS2 do stand with DCC protocol.
Offline franciscohg
#13 Posted : 09 March 2017 22:28:10(UTC)
franciscohg
Chile
Even so, with an M4 (mfx) decoder DCC will be completely ignored if mfx is activated on CS.
If you want to run your M4 decoder as DCC, you must first disable mfx protocol on the CS2
Online dickinsonj
#14 Posted : 12 March 2017 01:57:02(UTC)
I have the same problem trying to talk to a couple of DCC locos with my CS2. When the first one happened I thought that it must be the loco. But after more of them I now think that it is an issue with the CS2 and DCC locos. And WTF does "Please try again later" mean? If it doesn't work now it is unlikely to work later.
Offline daafies
#15 Posted : 19 September 2017 02:08:31(UTC)
daafies
Good tip. I was not able to change dcc address until i set the cs2 to dcc mode only. When set to auto you get the error popups as reported in this thread
This page was generated in 0.465 seconds.
