Offline ixldoc
#1 Posted : 31 August 2016 04:24:59(UTC)
ixldoc
I made the searchlight and the snowplough a few years ago and the steam tractor wagon just recently. All good fun.
The searchlight is by Pocher in 3 rail ( I have a 2 rail version too by pure luck) and was presented around 1958. Hard to find now.
Any mods I made are reversible and original parts were kept.( for the horrified Pocher fans). The train is a joint venture of DB, FS and SBB!
The dim light bulb is now an smd LED. The decoder is a TCS micro ( I think). The guard van is a Liliput "sputnik" with diesel drums for the searchlight generator.
Out of interest the photo below shows two versions of a wagon shoe, top is Pocher, bottom is Electrotren.
A short video:
The snowplough is built on a Marklin chassis with a Kleinbahn body. SBB didn't think much of the original rubber band drive from the axle so a Maxon motor was installed for the snow rotor. ESU decoder. The small red tail light is a fibre optic from inside. The rotor is driven by the throttle.
Some photos and a video.
A short video:
I have had the Marklin steam tractor model for a few years and decided to use it on a wagon instead of sitting on the layout.
The wagon is a Hornby Dublo 3 rail cast chassis from which I removed the tinplate sides. (The Hornby 3 rail bogies run through C track points without problem which is handy.) I drilled the bogie mounts out and also the coupler rivets and replaced the Hornby couplers with Marklin.
The other bits were scratch built.
Some photos:
The best part of model railway is the diversity of interests.
Howard.
thanks 16 users liked this useful post by ixldoc
#2 Posted : 31 August 2016 07:17:06(UTC)
Hi Howard,
You are a mechanical whizz.
I note the lovely lathe metal work, on the securing mech for the traction engine.
Certainly a great way to be occupied.
Offline waltklatt
#3 Posted : 31 August 2016 14:18:10(UTC)
waltklatt
Howard,
Wow, awesome looking conversions.
Who made the orange TE 215 locomotive?
Would like to add one to my collection.
I also have a modified Kleinbahn and Marklin Triebzugwagen set.
Will take some pictures as soon as I can unpack them again.
Keep up the cool conversions.
Walter
Offline ixldoc
#4 Posted : 31 August 2016 14:27:03(UTC)
ixldoc
Hi Kimball and Walter,
Thanks for the interest and comments.
The TE 215 is a Brawa model. Not sure if it is current but may be obtainable on eBay?
Like to see your mods too Walter!
Howard.
This page was generated in 0.360 seconds.
