Offline Drongo
#1 Posted : 23 July 2016 12:29:12(UTC)
Drongo
I have the loco 37370 and I can't turn the sound off !!Cursing
I have checked all the functions and they are off, however, the loco still makes the random sounds. Can someone please help me to turn the random sounds off when the sound function is off.
Greg
Online H0
#2 Posted : 23 July 2016 14:00:11(UTC)
Hi, Greg?
Which controller?
Have you tried a decoder reset?
Offline Drongo
#3 Posted : 23 July 2016 14:17:26(UTC)
Drongo
Hi Tom,
I'm using an Ecos. How do I reset a decoder?
Greg
Online H0
#4 Posted : 23 July 2016 15:38:40(UTC)
There should be a "Reset" button somewhere on the loco properties screens, third tab "Advanced" on the top menu (assuming the loco registered with the M4/mfx protocol).
Random sounds should be off when operating sound is off.
Is there a "pattern" with the sounds? Sounds can also be activated when changing the direction or when loco starts moving or stops. Maybe they are not random, even though they play at the wrong time.
Offline Drongo
#5 Posted : 24 July 2016 01:06:11(UTC)
Drongo
Thanks Tom, I won't be able to access the layout until Tuesday and then I'll let you know what the result is.
Greg
Offline Drongo
#6 Posted : 26 July 2016 11:39:29(UTC)
Drongo
Hi Tom, I reset the decoder, re-profiled the loco in TrainController, however, the random sounds are still there. Cursing Cursing
Offline Drongo
#7 Posted : 08 August 2016 12:32:23(UTC)
Drongo
I'm still having the problem with the random sounds working when all the functions for the loco are turned off.
My thought is, that there's a CV which controls the "random" function. Is this correct? If so, what number is the CV and how do I turn the CV to "off"?
Greg
Offline Drongo
#8 Posted : 10 August 2016 13:42:58(UTC)
Drongo
Can anyone help? I'm going crazy Cursing Cursing Cursing Cursing
#9 Posted : 10 August 2016 13:58:01(UTC)
Sounds like you need to replace the decoder?
If the sounds bother you just remove the speaker...
#10 Posted : 10 August 2016 14:38:53(UTC)
The same problem i did had with the Trix bayern steam locomotive.
The decoder are mfx and they are stupid.
The real problem are default with the program in the decoder.
I did first tested by reset decoder at CV 8 adress by write 8.
Not sure if this is correct with the value 8.
If this does not work,your decoder are crap!
By the way...my problem was keep going on.
I sold my locomotive. ThumpUp
Offline utkan
#11 Posted : 10 August 2016 14:48:19(UTC)
utkan
Turkey
Please allow me to ask, Goofy;
Did you tell the buyer about the problem? Blink RollEyes
#12 Posted : 10 August 2016 14:55:47(UTC)
No the warranty was over and i did used locomotive.
Not sure if somebody did bought the model.
I did sold the locomotive to an hobby store.
Offline utkan
#13 Posted : 10 August 2016 14:57:12(UTC)
utkan
Turkey
ThumpUp ThumpUp
Offline Drongo
#14 Posted : 11 August 2016 12:07:24(UTC)
Drongo
Removing the speaker is not an option - I guess I need to replace the decoder. The loco is still under warranty, however, the cost to post it back to German and then wait for its return . . . .
Thanks for the tip,
Greg
Offline Alberto Pedrini
#15 Posted : 11 August 2016 15:14:19(UTC)
Alberto Pedrini
Can you test the loco with an analog transformer?
Sometimes happen that this wake up the decoder.
You must consider if order a new decoder is cheaper than send and return the loco to the seller.
Alberto
Marklinfan Club Italia
www.marklinfan.net
#16 Posted : 11 August 2016 18:50:17(UTC)
Thanks for the tip,
Greg
It may be worth investing in the Marklin decoder programmer and looking at the function mapping. I am getting the impression that Marklin have produced a decoder that is very close to the ESU v4 decoders in flexibility of programming and it would not be hard to have someone set the master sound file up incorrectly so the result is what you see.
This page was generated in 0.771 seconds.
