Offline Gregzim
#1 Posted : 06 August 2016 10:34:55(UTC)
Gregzim
Hi. I entered '08' into CV8 on a loksound V4 decoder on Ecos and it says "OK".
THe loco however now has no response. I re read CV8 and its now reads address "151" whihc I ressed check on - but no difference so I assume there are now other steps to do?
All help appreciated thanks.
Rgds
Greg
#2 Posted : 06 August 2016 16:43:24(UTC)
Hi Greg,
The default address for Lokpilots is "03" I believe. Have you tried entering that address for the loco?
#3 Posted : 14 August 2016 10:31:31(UTC)
Greg, CV 8 is resetting the decoder but you have to put in Value 8 as well , that is if you have a lokprogrammer. also if RailComPlus is activated you may have to re-register the loco on your test track.
#4 Posted : 14 August 2016 10:33:36(UTC)
If yours loco adress are 3,put the loco on the programming track and go to the CV adress 8.
Write value 8 and confirm it by press enter.
This page was generated in 0.407 seconds.
