Offline daive
#1 Posted : 12 July 2016 11:28:19(UTC)
daive
hi guys am new in this trade so i have my layout so i just bought the new L88 60883 can someone help me out on how to wire it up (do i need the reed switches or not )
Offline NS1200
#2 Posted : 12 July 2016 15:32:47(UTC)
NS1200
Also in English further down the road:
https://static.maerklin....887203d2681464362779.pdf
#3 Posted : 14 July 2016 00:00:57(UTC)
Link 88 doc.pdf (3,956kb) downloaded 47 time(s).
Hi Daive,
The 60883 (Link S88) is to feed a CS2 with contact information. It cannot be used without a CS2 and a separate power supply.
So after having plugged the Link S88 to its power supply and to your CS2 you must:
  • On the Link S88, set the switch to work in 5 volts (if you have old S88) or in 12 volts
  • on the CS2, on Setup zone do exactly as per page 18 of attached document. The purpose is to declare the new unit to the CS2 and indicate how many slave S88 you connect on this Link S88.
Hope this helps
Offline daive
#4 Posted : 21 July 2016 10:05:43(UTC)
daive
hi
i have connected as per the link but am not getting this right. i can configure the l88 on my cs2 and i did all the setting as from page 14 to page 18.tell me something i have decoders on my turnouts and the motor so no if am going to use the s88 and the l88 should i remove those decoders on the turnouts and leave the omto alone
This page was generated in 0.421 seconds.
